 Forum index » DIY Hardware and Software » Musical Interfaces
turning old piano into midi keyboard (keyboard matrix)
Page 2 of 2 [34 Posts]
Goto page: Previous 1, 2
Audio files: 353
PostPosted: Sat Dec 12, 2020 8:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
it means that it can not find the function named scanColumn .. you may have mistyped it where it is defined .. for instance as ScanColumn .. as things are case sensitive.
To get some ideas about scoping .. that is where things are to be found in the program text see :: https://en.wikipedia.org/wiki/Scope_(computer_science)
edit: hmm .. it wont do an URL like that here .. you'll need to select/copy/paste it (including the parenthized bit).
floating-water
PostPosted: Sat Dec 12, 2020 8:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's typed as:
Code:
scanColumn(colCtr);
the whole code is:
Code:
#define NUM_ROWS 8
#define NUM_COLS 8
#define NOTE_ON_CMD 0x90
#define NOTE_OFF_CMD 0x80
#define NOTE_VELOCITY 127
//MIDI baud rate
#define SERIAL_RATE 31250
// Pin Definitions
// Row input pins
const int row1Pin = 2;
const int row2Pin = 3;
const int row3Pin = 4;
const int row4Pin = 5;
const int row5Pin = 6;
const int row6Pin = 7;
const int row7Pin = 8;
const int row8Pin = 9;
// 74HC595 pins
const int dataPin = 10;
const int latchPin = 11;
const int clockPin = 12;
boolean keyPressed[NUM_ROWS][NUM_COLS];
uint8_t keyToMidiMap[NUM_ROWS][NUM_COLS];
// bitmasks for scanning columns
int bits[] =
  B00000001,
  B00000010,
  B00000100,
  B00001000,
  B00010000,
  B00100000,
  B01000000,
  B10000000
void setup()
  int note = 36;
  for(int colCtr = 0; colCtr < NUM_COLS; ++colCtr)
    for(int rowCtr = 0; rowCtr < NUM_ROWS; ++rowCtr)
      keyPressed[rowCtr][colCtr] = false;
      keyToMidiMap[rowCtr][colCtr] = note;
      note++;
  // setup pins output/input mode
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(latchPin, OUTPUT);
  pinMode(row1Pin, INPUT);
  pinMode(row2Pin, INPUT);
  pinMode(row3Pin, INPUT);
  pinMode(row4Pin, INPUT);
  pinMode(row5Pin, INPUT);
  pinMode(row6Pin, INPUT);
  pinMode(row7Pin, INPUT);
  pinMode(row8Pin, INPUT);
  Serial.begin(SERIAL_RATE);
void loop()
  for (int colCtr = 0; colCtr < NUM_COLS; ++colCtr)
    //scan next column
    scanColumn(colCtr);
    //get row values at this column
    int rowValue[NUM_ROWS];
    rowValue[0] = digitalRead(row1Pin);
    rowValue[1] = digitalRead(row2Pin);
    rowValue[2] = digitalRead(row3Pin);
    rowValue[3] = digitalRead(row4Pin);
    rowValue[4] = digitalRead(row5Pin);
    rowValue[5] = digitalRead(row6Pin);
    rowValue[6] = digitalRead(row7Pin);
    rowValue[7] = digitalRead(row8Pin);
    // process keys pressed
    for(int rowCtr=0; rowCtr<NUM_ROWS; ++rowCtr)
      if(rowValue[rowCtr] != 0 && !keyPressed[rowCtr][colCtr])
        keyPressed[rowCtr][colCtr] = true;
        noteOn(rowCtr,colCtr);
    // process keys released
      if(rowValue[rowCtr] == 0 && keyPressed[rowCtr][colCtr])
        noteOff(rowCtr,colCtr);
void scanColumn(int colNum)
  digitalWrite(latchPin, LOW);
  shiftOut(dataPin, clockPin, MSBFIRST, bits[colNum]); //left sr
  digitalWrite(latchPin, HIGH);
void noteOn(int row, int col)
  Serial.write(NOTE_ON_CMD);
  Serial.write(keyToMidiMap[row][col]);
  Serial.write(NOTE_VELOCITY);
void noteOff(int row, int col)
  Serial.write(NOTE_OFF_CMD);
edit: it seems to be in the code correctly is what i mean by this
Audio files: 728
PostPosted: Sun Dec 13, 2020 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
floating-water wrote:
When I tried compiling the sketch it gave an error:
'scanColumn' was not declared in this scope
when I get that error it usually means I forget a } somewhere else or maybe added one too many, usually as a result
of having a bunch of nested IF or FOR statements. The problem with that error is that is doesn't really tell you where that actually is.
I'll have a look at the code later,
testing wiki link with html: wikipedia Scope (computer science)
The Golden Shrimp Guild
Audio files: 728
PostPosted: Sun Dec 13, 2020 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Code:
in that section the last } needs to go
floating-water
PostPosted: Sun Dec 13, 2020 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks my guy it worked
floating-water
PostPosted: Sun Dec 13, 2020 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another problem, its stuck on uploading.
Its an arduino nano, its on port COM 5 its looks all set but wont upload, its a clone arduino nano
Audio files: 728
PostPosted: Fri Dec 18, 2020 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
do you get some kind of error message or does it just try to upload and then nothing happens and it keeps stuck on uploading ?
I've had that before but I think my solution was just to switch from windows to linux or the other way around. I guess that's not very helpful.
floating-water
PostPosted: Thu Dec 24, 2020 6:20 am    Post subject: Reply with quote  Mark this post and the followings unread
for anyone that encounters this problem with a clone, i switched to the old bootloader and it worked
PostPosted: Thu Dec 24, 2020 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I’ve had this problem many times, didn’t bother with bootloading but turned to using Atmel studio using an external programmer avr isp2
 Filesize:  44.6 KB
 Viewed:  7042 Time(s)
my synth
