Joined: Apr 03, 2004 Posts: 24864 Location: The Netherlands, Enschede
Audio files: 353
Posted: Sat Dec 12, 2020 8:27 pm Post subject:
it means that it can not find the function named scanColumn .. you may have mistyped it where it is defined .. for instance as ScanColumn .. as things are case sensitive.
To get some ideas about scoping .. that is where things are to be found in the program text see :: https://en.wikipedia.org/wiki/Scope_(computer_science)
edit: hmm .. it wont do an URL like that here .. you'll need to select/copy/paste it (including the parenthized bit). |
floating-water
Posted: Sat Dec 12, 2020 8:46 pm Post subject:
It's typed as:
| Code: | | scanColumn(colCtr); |
the whole code is:
| Code: | #define NUM_ROWS 8
#define NUM_COLS 8
#define NOTE_ON_CMD 0x90
#define NOTE_OFF_CMD 0x80
#define NOTE_VELOCITY 127
//MIDI baud rate
#define SERIAL_RATE 31250
// Pin Definitions
// Row input pins
const int row1Pin = 2;
const int row2Pin = 3;
const int row3Pin = 4;
const int row4Pin = 5;
const int row5Pin = 6;
const int row6Pin = 7;
const int row7Pin = 8;
const int row8Pin = 9;
// 74HC595 pins
const int dataPin = 10;
const int latchPin = 11;
const int clockPin = 12;
boolean keyPressed[NUM_ROWS][NUM_COLS];
uint8_t keyToMidiMap[NUM_ROWS][NUM_COLS];
// bitmasks for scanning columns
int bits[] =
B00000001,
B00000010,
B00000100,
B00001000,
B00010000,
B00100000,
B01000000,
B10000000
void setup()
int note = 36;
for(int colCtr = 0; colCtr < NUM_COLS; ++colCtr)
for(int rowCtr = 0; rowCtr < NUM_ROWS; ++rowCtr)
keyPressed[rowCtr][colCtr] = false;
keyToMidiMap[rowCtr][colCtr] = note;
note++;
// setup pins output/input mode
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(latchPin, OUTPUT);
pinMode(row1Pin, INPUT);
pinMode(row2Pin, INPUT);
pinMode(row3Pin, INPUT);
pinMode(row4Pin, INPUT);
pinMode(row5Pin, INPUT);
pinMode(row6Pin, INPUT);
pinMode(row7Pin, INPUT);
pinMode(row8Pin, INPUT);
Serial.begin(SERIAL_RATE);
void loop()
for (int colCtr = 0; colCtr < NUM_COLS; ++colCtr)
//scan next column
scanColumn(colCtr);
//get row values at this column
int rowValue[NUM_ROWS];
rowValue[0] = digitalRead(row1Pin);
rowValue[1] = digitalRead(row2Pin);
rowValue[2] = digitalRead(row3Pin);
rowValue[3] = digitalRead(row4Pin);
rowValue[4] = digitalRead(row5Pin);
rowValue[5] = digitalRead(row6Pin);
rowValue[6] = digitalRead(row7Pin);
rowValue[7] = digitalRead(row8Pin);
// process keys pressed
for(int rowCtr=0; rowCtr<NUM_ROWS; ++rowCtr)
if(rowValue[rowCtr] != 0 && !keyPressed[rowCtr][colCtr])
keyPressed[rowCtr][colCtr] = true;
noteOn(rowCtr,colCtr);
// process keys released
if(rowValue[rowCtr] == 0 && keyPressed[rowCtr][colCtr])
noteOff(rowCtr,colCtr);
void scanColumn(int colNum)
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, MSBFIRST, bits[colNum]); //left sr
digitalWrite(latchPin, HIGH);
void noteOn(int row, int col)
Serial.write(NOTE_ON_CMD);
Serial.write(keyToMidiMap[row][col]);
Serial.write(NOTE_VELOCITY);
void noteOff(int row, int col)
Serial.write(NOTE_OFF_CMD);
edit: it seems to be in the code correctly is what i mean by this |
Audio files: 728
Posted: Sun Dec 13, 2020 4:54 am Post subject:
| floating-water wrote: | When I tried compiling the sketch it gave an error:
'scanColumn' was not declared in this scope
when I get that error it usually means I forget a } somewhere else or maybe added one too many, usually as a result
of having a bunch of nested IF or FOR statements. The problem with that error is that is doesn't really tell you where that actually is.
I'll have a look at the code later,
testing wiki link with html: wikipedia Scope (computer science) _________________ "My perf, it's full of holes!"
The Golden Shrimp Guild Last edited by PHOBoS on Sun Dec 13, 2020 5:19 am; edited 1 time in total |
Audio files: 728
Posted: Sun Dec 13, 2020 5:01 am Post subject:
| Code: |
in that section the last } needs to go _________________ "My perf, it's full of holes!"
The Golden Shrimp Guild |
floating-water
Posted: Sun Dec 13, 2020 2:05 pm Post subject:
| Thanks my guy it worked |
floating-water
Posted: Sun Dec 13, 2020 2:27 pm Post subject:
Another problem, its stuck on uploading.
Its an arduino nano, its on port COM 5 its looks all set but wont upload, its a clone arduino nano |
Audio files: 728
Posted: Fri Dec 18, 2020 11:43 am Post subject:
do you get some kind of error message or does it just try to upload and then nothing happens and it keeps stuck on uploading ?
I've had that before but I think my solution was just to switch from windows to linux or the other way around. I guess that's not very helpful. _________________ "My perf, it's full of holes!"
floating-water
Posted: Thu Dec 24, 2020 6:20 am Post subject:
| for anyone that encounters this problem with a clone, i switched to the old bootloader and it worked |
Joined: Nov 23, 2015 Posts: 1320 Location: Netherlands
Audio files: 32
