Coming up on Radio 1 at
PCBs for Thomas Henry's X-4046 VCO
Page 9 of 12 [296 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9, 10, 11, 12 Next
LektroiD
PostPosted: Tue Nov 15, 2011 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's my 'ghetto style' 4046 oscillators in 5U format. Thought you might want a look...
And here's the rest of the synth
Any more of these boards available?
Fonik's Oscillators :)
 Filesize:  1.3 MB
 Viewed:  679 Time(s)
PostPosted: Wed Nov 16, 2011 1:13 am    Post subject: Reply with quote  Mark this post and the followings unread
you built four of them and want more? so you are happy with them?
your synth looks great BTW - looks vintage...
and yes, i have PCBs available.
Posted Image
LektroiD
PostPosted: Wed Nov 16, 2011 6:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Indeed, they do everything an oscillator should, and track very nicely over a good range of octaves.
I'm in the process of moving, so now is not an ideal time to buy, but I'm definitely in for some more soon! Ideally I'd like another 8, but funds are looking more like I can only stretch to another 4 sets (I may come back for more at a later date).
Also, any plans for Fonik VCAs?
a.b.o.z.
G2 patch files: 4
PostPosted: Thu Nov 17, 2011 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got mine boards today. Looking funky Very Happy
Thank you
aladan
PostPosted: Wed Dec 07, 2011 3:57 pm    Post subject: Low triangle output level on Fonik X-4046 core PCB? Reply with quote  Mark this post and the followings unread
Last night I finished building a X-4046 core board (Fonik style) and the saw and triangle waveforms are looking and sounding beauitful. Sawtooth is around 5V p-p, but the triangle is much quieter; less than 2V p-p. Is this normal? Can I simply decrease the value of R4 (currently 1K) to increase the level of the triangle output, or should I be looking at R32 or trying alternatives for IC3 instead (I think I ended up using a uPC324 because I had no TL074s handy?)
Thanks for the boards Fonik - ordering was a breeze, the price was very reasonable and they arrived here in Australia very quickly. Even the PCB layout and the red boards are aesthetically pleasing! I couldn't be happier Smile
On the weekend I'll try out the waveshaper...
PostPosted: Thu Dec 08, 2011 12:16 am    Post subject: Re: Low triangle output level on Fonik X-4046 core PCB? Reply with quote  Mark this post and the followings unread
actually not. what 4046 IC are you using?
R4 is nothing but the output impedance resistor according electro notes.
increasing R32 would add gain.
the uPC324 has a wider swong than the TL074, so i don't think this is an issue.
Posted Image
aladan
PostPosted: Thu Dec 08, 2011 5:55 am    Post subject: Re: Low triangle output level on Fonik X-4046 core PCB? Reply with quote  Mark this post and the followings unread
Thanks for your response Fonik,
The 4046 is one of the "good" brands - an NXP HEF4046BP. I have a few spares of those I can try, and some other unrecommended ones (unknown brand 4046B, ST HCF4046BE and TI CD4046BE.) I checked R32, it's definitely 100k. And I did find and use a TL074 so that's not the issue there either.
Tomorrow I'll try a bigger resistor for R32 and let you know how it goes.
Thanks again!
Adrian.
PostPosted: Fri Mar 09, 2012 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
i just wanted to let you know that i re-ordered a few more of PCBs for this VCO. due to the low order quantity i had to raise the prices.
the PRICES (revised for low quantity re-order)
7.- EUR/10.-USD for the VCO core PCB (saw/tri)
and
5.- EUR/7.-USD for the waveshaper PCB (tri2sin/pulse/PWM)
+ p/p
Deutschland: 1.- EUR/2 PCBs, 1.50 EUR/3+ PCBs
Europe: 2.- EUR/2 PCBs, 4.- EUR/3+ PCBs
Outside Europe: 4.- USD/2 PCBs, 6.- USD/3+ PCBs
Posted Image
hegeldas
PostPosted: Mon Apr 16, 2012 10:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is it possible to count one of each for me ? how to pay?
PostPosted: Mon Apr 16, 2012 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
you do the right thing, check PM. Very Happy
Posted Image
elanhickler
G2 patch files: 6
PostPosted: Tue May 29, 2012 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Is this a saw core VCO?
PostPosted: Tue May 29, 2012 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
it is both, a saw and a triangle core VCO!
tomas henry used a very clever method to combine several outputs of a manipulated CD4046 to form both, a saw and a triangle output.just take a look at the schematics:
http://www.birthofasynth.com/Thomas_Henry/Pages/X-4046.html
Posted Image
elanhickler
G2 patch files: 6
PostPosted: Tue May 29, 2012 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Aha, a response! Hey! Another question: Does this VCO have variable sync? According to your panel it doesn't but just wondering if you left it out... since... tri-core oscillators usually have it. (Anyway I'm interested in this VCO for its hardsync everyone is raving about!)
What's the + p/p 1 euros for 2?
PostPosted: Tue May 29, 2012 10:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
don't forget, this is not a VCO with comparator/integrator core. it uses a PLL as core... anyways, this hardsync is worth it.
all prices are written in the 1st post of this thread, however, the PCBs are currently sold out. nevertheless, i will re-order a new batch soon and announce it herein the sub-forum.
hope this helps.
Posted Image
OSCANO
PostPosted: Thu May 31, 2012 1:38 am    Post subject: Re: PCBs for Thomas Henry's X-4046 VCO
Subject description: re-ordered a few spares...
Hi! do you still have the PCBs??? Need 2 of each, thanks.
PostPosted: Thu May 31, 2012 2:18 am    Post subject: Reply with quote  Mark this post and the followings unread
i will re-order a batch soon, however, i will have to complete the PS3100 resonator PCB sale first....
Posted Image
aladan
PostPosted: Tue Jun 05, 2012 9:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Count me in for a few more when you do... need more VCOs, loving the X-4046 Smile
Audio files: 163
PostPosted: Tue Jun 19, 2012 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Fonik
2 core's & 2 shapers for me please .
Thanks again
elanhickler
G2 patch files: 6
PostPosted: Tue Jun 19, 2012 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am confooozd... Mad
So, is the PCB available? Where do I send payment? If paypal, what's the address? When will it be shipped? Embarassed
Audio files: 163
PostPosted: Tue Jun 19, 2012 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Keep an eye on this thread over the next month or so , Fonik says "after the ps3100 boards are all parceled up & posted off , he will order another batch of the vco pcb's , register your number of boards required so he can get a rough idea how many to order from the factory Smile
baudrate
PostPosted: Tue Jun 19, 2012 6:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't wait to build a pair of these!
Mongo1
PostPosted: Tue Jun 19, 2012 8:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd definitely be in for a pair of these... Looks great!
Gary
Oort Cloud
PostPosted: Tue Jun 26, 2012 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for 4 core & 4 wave shapers PCBs.
tokyomatik
Audio files: 6
PostPosted: Tue Jun 26, 2012 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
i think i did something wrong with one of my boards.
i desoldered maybe 3 or 4 times the tempco and now the pads are gone, so now on my scope i can see the triangle wave only when i turn the frequency pot at 50% or more, before just flat, the sound is pretty acute on the high high frequencies....i hope i didn't killed all the dogs of the neighborhood with it ...or drive crazy dolphins and bats....Rolling Eyes in wich way i could fix this??
just in case, are there some pcbs available??
elanhickler
G2 patch files: 6
PostPosted: Sun Jul 08, 2012 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is it OK to use Mouser # 147-72-104-RC 100n capacitor for VCO and Waveshaper boards?:
C10
C12
C13
C300
C400
