Posted: Mon Jul 09, 2012 1:08 am Post subject:
Z5U is the worst carbon capacitor you can get, i guess, however, they are cheap and i use them for decoupling. and that's what are the caps you referred to are for.
so yes, they are fine for this pupose. _________________
Tech Buddy at Random*Source |
Posted: Mon Jul 09, 2012 1:09 am Post subject:
BTW all who indicated interest in additional boards should check their PM#s and/or email... _________________
elanhickler
G2 patch files: 6
Posted: Mon Jul 09, 2012 7:12 am Post subject:
Thanks Fonik! Another question!
Is it possible to remove the Coarse tune pot from the circuit? I just want to use the FM inputs to control the frequency. Basically, I would want to replace the coarse tune pot with a fixed resistor... maybe 50K so it sits half way through its range? How would I wire it? |
Posted: Wed Jul 11, 2012 2:12 am Post subject:
| Argitoth wrote: | Thanks Fonik! Another question!
no need to do this. just leave off the potentiometer R43 and the according input resistor R29.
you don't need the fine coarse control then either? (R44, R56)
anyways, maybe you rather want to replace the panel mount coarse pot R43 by a trimmer? you could just replace the header by a PCB mount multiturn trimmer...  _________________
elanhickler
G2 patch files: 6
Posted: Thu Jul 12, 2012 12:18 am Post subject:
| I thought Todd Fletcher was offering a parts kit, but I've e-mailed and PMed him multiple times, no response... didn't even open the PM. |
elanhickler
G2 patch files: 6
Posted: Sun Jul 15, 2012 5:11 pm Post subject:
Here's my panel. How do you like them's apple's? 8hp. No coarse tune. I will mostly be controlling this via Silent Way or use a DC offset module.
Joined: Jan 07, 2009 Posts: 1231 Location: Scottish Borders
Audio files: 163
Audio files: 163
Posted: Tue Jul 17, 2012 10:22 am Post subject:
Argitoth ......
Nice layout , classic knobs to the top and jacks at the bottom .
Dave. |
elanhickler
G2 patch files: 6
Posted: Tue Jul 17, 2012 11:42 am Post subject:
| Skrog Productions wrote: | Argitoth ......
Dave. |
Thanks! I only do that if I have to and if I want to fit everything in the smallest space possible. If I really like a module, then I tend to make it small because I want many copies.  |
inlifeindeath
Joined: Apr 02, 2010 Posts: 316 Location: Albuquerque, NM
Posted: Fri Aug 03, 2012 10:47 am Post subject:
hmm, so despite my requests in the past for more boards, i never got a notification that they were available again ...
do you have any more boards left Fonik?
Thanks! _________________ http://www.youtube.com/user/borisandfef |
Posted: Fri Aug 03, 2012 12:25 pm Post subject:
| inlifeindeath wrote: | hmm, so despite my requests in the past for more boards, i never got a notification that they were available again ...
Thanks! |
currently not. someone over at muffs planned to do a eurorack panel (metalphoto top notch), alas, it did not happen yet. wanted to reßorder as soon as they are available... _________________
inlifeindeath
Posted: Sun Aug 05, 2012 6:45 pm Post subject:
that's pretty disappointing considering i've already been waiting months for you to announce the newest run. oh well, gonna have to make my own. _________________ http://www.youtube.com/user/borisandfef |
Posted: Mon Aug 06, 2012 10:23 am Post subject:
hey, all my fault! i am very sorry, it seems i did not track your request properly!
i want to sort this out right now! just tell me how many you need (up to 4 complete sets), and i will mail them this week! _________________
Posted: Mon Aug 06, 2012 2:26 pm Post subject:
inlifeindeath
Posted: Mon Aug 06, 2012 11:14 pm Post subject:
Once again verifying that Matthias is a solid dude and a true gentleman. All is well, thanks again! _________________ http://www.youtube.com/user/borisandfef |
elanhickler
G2 patch files: 6
Posted: Tue Aug 07, 2012 10:27 am Post subject:
| Hey Mr. Fonik, could you tell me the hole size and the #x # square that the PCB mounting holes sit on? |
Posted: Wed Aug 08, 2012 4:41 am Post subject:
PCB measurements:
the holesize is 3.2mm (0.126) _________________
Posted: Wed Aug 08, 2012 4:43 am Post subject:
notice that the PCBs could be mounted back on back. the power connector on the waveshaper is mirrored... _________________
elanhickler
G2 patch files: 6
Posted: Wed Aug 08, 2012 12:13 pm Post subject:
| fonik wrote: | | notice that the PCBs could be mounted back on back. the power connector on the waveshaper is mirrored... |
You're crazy! no thanks!
Posted: Wed Aug 08, 2012 12:46 pm Post subject:
the idea was to mount them on bot sides of a bracket, so that you still can reach all thise trimmers.
i mounted them all in paralel to to the frontpanel, though  _________________
Posted: Wed Aug 08, 2012 1:39 pm Post subject:
I'm planning to use a long/flexible enough cable that I can lay them side-by-side/flat while I'm testing and tweaking and then fold it over and mount parallel but back to back as you say, Fonik. Needs a 2U wide dotcom panel to fit the jacks and knobs anyway, and it fits in parallel very nicely. (in my plans anyway ) |
elanhickler
G2 patch files: 6
Posted: Wed Aug 15, 2012 2:10 pm Post subject:
| fonik wrote: | | Z5U is the worst carbon capacitor you can get, i guess, however, they are cheap and i use them for decoupling. and that's what are the caps you referred to are for. | Is C10 also used for decoupling? |
Posted: Wed Aug 15, 2012 2:35 pm Post subject:
| Argitoth wrote: | | fonik wrote: | | Z5U is the worst carbon capacitor you can get, i guess, however, they are cheap and i use them for decoupling. and that's what are the caps you referred to are for. | Is C10 also used for decoupling? |
yes it is. it is going across the CD4046 from Vdd to Vss. _________________
elanhickler
G2 patch files: 6
Posted: Wed Aug 15, 2012 3:03 pm Post subject:
Hmm... I don't know what to do with the matched transistors and 3k tempco I got from MFOS. Should I do it exactly like the picture above? Except I have thermal paste. Should I do it like the picture above except put thermal paste inbetween the transistors and sit the tempco on top and have some thermal paste on that as well?
Or maybe I can put the tempco between the transistors so the transistors touch the tempco and not each other and have thermal paste all inbetween? |
Posted: Thu Aug 16, 2012 8:21 am Post subject:
i use termal glue.
transistors back to back like in the pic with a thin film of termal paste (glue), 2k PTc resistor on top (again with termal paste/glue).
ther termal conditions of the two transitors should be as equal as possible. _________________
