Wattage of NL3?
Page 1 of 1 [19 Posts]
zam
PostPosted: Mon Apr 07, 2008 2:35 am    Post subject: Wattage of NL3? Reply with quote  Mark this post and the followings unread
Hi, can anyone tell me what the wattage consumption of the Nord Lead 3 (115V US version) is? I have looked through the manual, and searched the net, but cant find any info so far...
I live in Australia and just bought an American NL3 (my first synth too... very excited!). Although I am still waiting for it in the post, I have been researching US to AUS power issues and step down transformers. Ive read a few similar threads here regarding it all but I am still not certain.
Today i bought this: http://www.dse.com.au/cgi-bin/dse.storefront/47f9e6bf00efec08273fc0a87f9c071e/Product/View/M1153
The man at the store didnt seem to know too much about it either, which left me a bit worried. Is this what I need, or would 500W be overkill and somehow damage my NL3? I am also planning on running a second synth simultaneously, a Roland JP 8080 off the transformer.
Please excuse my electrical ignorance, I just want to be certain before I plug anything in!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Apr 07, 2008 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
:welcom: zam
I hope you can return your transformer, because when you open up your NL3 you'll find a little switch which can be set to 230 (240 Volts). Then you have to change the fuse too (Don't know which value, though, but it can be found in this forum...), which is far less money the a transformer.
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Apr 07, 2008 3:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Found it!
Fuse for 230V = 100 mA Slow Blow
Still, it isn't the answer to your initial question, Watt = Volt x Ampere, so 230 x 0.1 = 23 Watt at the most... Then the fuse will blow, slowly, that is Smile
Jan, tell me I'm right Smile
Wout
Former site admin
Audio files: 353
PostPosted: Mon Apr 07, 2008 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
The fuse will not blow Cool
To be clear, there are two options :
1) Use the auto transformer just bought and change nothing on the synth, the transformer seems suitable although it is a bit overkill in power (but that will destroy nothing, and it allows for a couple of synths more).
2) Modify the synth to work on 220/230 Volt and do not use the transformer. Modifying the synth is a matter of opening it, setting the internal power switch into the correct position and changing the fuse to the value indicated by Wout.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Apr 07, 2008 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
But...
Is the Watt of the synth somewhat less then 23 Watt or not? At least, not more then 23 Watt?
Wout
Former site admin
Audio files: 353
PostPosted: Mon Apr 07, 2008 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
At least not more ...
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Apr 07, 2008 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Jan!
I can sleep tonight.
Wink
Wout
zam
PostPosted: Mon Apr 07, 2008 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the informative replies guys! Long term I would like to convert the NL3 to AUS power, only then Ill still have a US JP 8080 on my hands, which I have no idea about in regards to doing the same power conversion... Anyone know anything about this?
So the NL3 is ~ 23W, is that pretty standard for all synths? If so I might return my transformer for a cheaper 250W one or something...
Also, Im still a little confused about this 'switch' inside the NL3, when you guys refer to this, is it a physical on/off switch that an electrical retard like me could do, or does it involve soldering a connection or something?
Former site admin
Audio files: 353
PostPosted: Mon Apr 07, 2008 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just open the machine Laughing
It is switch like switch, one that you can switch without soldering.
To open the synth ... unplug the mains ... two black screws on the sides, the frontmost ones the other two (with plastic washers) are hinges. A couple on the back, like four or five and one or two at the bottom side - they all are the same size.
Then it should flip open. It's pretty hard to damage it doing this, it should open up easily - when not you forgot a screw.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Apr 07, 2008 9:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe start another thread in the 'gear' forum?
Cheapest way is to click the switch and change the fuse. About five minutes work and even I can do it... Wink
It's a real, tiny, physical switch. It's on the power board next to the transformer. If you don't want to do it, take it to a repair man near to you, it will be cheaper too!
Sorry if my replies made you a little insecure, but it was a long time ago I used those formulas about power calculations and the obscure law named Ohm... Smile
Wout
BTW Roland synths? I thought they ran on cole, didn't they? Wink
zam
PostPosted: Tue Apr 08, 2008 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks again guys.
Wout - Dont be sorry! This is all really helpful, thanks
Ill let you guys know how I go with the Lead
zam
PostPosted: Mon Apr 21, 2008 12:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi again,
I tried to open my NL3 up last night, but it got stuck and wouldnt budge around the area to the right of the mod wheel. The rest of the case seemed fine and able to detach except for this point. I took off all screws I could see (4 at the back, 2 on each side). Am I missing something here? Anyone else have dramas getting the case open?
zam
PostPosted: Mon Apr 21, 2008 12:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Also, in this thread:
http://electro-music.com/forum/viewtopic.php?highlight=150&t=21906
Discussion over what was the correct fuse was 125mA, which Blue Hell changed to 150mA when dorremifasol said the back of his Nord Lead said:
115v~
300mA Slow Blow
Which mine does also. Can someone confirm whether it is 100, 125, or 150mA that Id need? Thanks!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Apr 21, 2008 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
zam wrote:
... Am I missing something here? ...
Yes! There is one at the bottum! Just turn the synth upside down and unscrew the one with the same size as the six you already removed.
And, indeed, it is just oposite to the Wheel.
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Apr 21, 2008 3:30 am    Post subject: Reply with quote  Mark this post and the followings unread
zam wrote:
115v~
300mA Slow Blow
Volt x Ampere = Watt
which means if
115 x 0.3 = Watt NL3 (when the fuse will blow),
it will be
230 x 0.15,
which results in 150 mA.
Wout
Correct me if I'm wrong...
zam
PostPosted: Tue Apr 22, 2008 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahhhhh Im so stupid I actually noticed those bottom two screws not long after I posted that. Thanks though Wout.
So sorry to come back to the fuse again, but after I opened my Nord up I couldn't work out where or what fuse it was that is needed to replace. To tell you the truth I barely know what a fuse would look like... Ive added an attachment - a rough pic of my power section inside my nord.
The only thing I could see that I thought would be the fuse ive pointed to with the red arrows - but theres two of these that are exactly the same! Do I replace both of these?
Sorry for all the double and triple checking guys, Im just scared to death about blowing up my red baby!
 Filesize:  51.53 KB
 Viewed:  327 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Apr 22, 2008 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't hesitate to ask! Indeed, better asked twice then destroying your gear!
Neither of both is the fuse. In fact, the fuse is inside the black tube at the right on the board, BUT no need to do anything to the board. A fuse is always in reach for replacements from the outside of the synth. (I don't have a NL2X, so I look at the NL2, assuming it's the same) Next to the power button on the back is a little disc, about 1 cm diameter, which has a little slit on the surface. Using a screwdriver unscrew the little disc and the fuse will being pushed out by a little spring. Better to open it pushing back, so the fuse AND the spring wouldn't be launched into your room Smile It's a little glass tube, mostly with two iron caps at both sides. One of the caps has some writing on it, mostly the value. Put the new fuse the same way in... It doesn't matter, which side is in front and which isn't, but maybe you'll feel better about it this way and you won't start being in doubt about it ) Just teasing!! Wink Screw the cap back in place and all is ready!
Wout
zam
PostPosted: Tue Apr 22, 2008 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice... Wow, Ive just been looking in ALL the wrong places so far havnt I! Oh well if anything it might help out others in the future. Thanks again Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Apr 23, 2008 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
There is no writing anywhere which tells you have to be a full trained engineer to play a synthesizer, isn't it?
I just hope all works out.
Let us know!
Wout
