One more question - I notice 4 FM inputs - is this 1 exp and 1 linear for each osc? If so, which one is the exp input and which is the linear for each osc?
Posted: Fri Oct 17, 2008 11:51 pm Post subject:
ARP Odyssey Oscillators
AndyR1960 wrote:
To be honest, I had no idea that Tim Servo was also working on these VCO's (as we say in England - you wait all day for a bus, then two come along at once).Andy.
Umm... I just built a clone, too...before I even knew this thread was going! It turned up in my Google search for "Odyssey selected FET" !
AndyR1960 wrote:
There is something "special" about the Oddy VCO/RM combination
I agree. That is one reason why I built this clone. The other reason being I had two Odysseys here to repair and one with a non-working VCO. Thought it would help in troubleshooting (and some fun).
I've built three and all are different. These are on the breadboard and may be suffering from interference of some kind. I'll just have to do a pcb for this and see.
I subbed the 2N5910 with 2N3906
Subbed 2N5459 with 2N5458
Didn't bother with a tempco...yet.
The waveform offsets in the Odyssey are maintained when using SH Mixer to modulate VCO 2 or the VCF. The signals are AC coupled pre-VCF so level shifting should have little effect on the output sound.
I plan to do pcbs with:
2 VCO circuits with 4011 "ring mod"
portamento
noise
The goal is to make an Odyssey work alike with 3 modules - VCOs, VCF and LFO, and Mod sources (EGs, SH, etc). I'll ditch the 3080 VCA in favor of something better.
Oh yeah.
The FETs are marked "selected" in the Service manual.
Selected for what?
Any guesses?
Posted: Sat Oct 18, 2008 11:18 am Post subject:
Never mind, I think we just have a semantics issue here. Exponential and linear response to the input versus linear and logarithmic controls to the input.
The Odyssey provides an exponential response to a linear input, right?
Posted: Sat Oct 18, 2008 1:17 pm Post subject:
Yes. Expo response. All the FM inputs sum at the base of the PNP of the expo converter. Works with 1V/Oct keyboards, etc.
The faders are different taper (not that doesn't matter much):
two FM inputs - Audio taper
Pulse Width - Linear
PWM - Audio
120K & 121K are actually the only ones I seem to see that could crossover within 1%. Does that matter for these particular ones? Just guessing why not use all of 1 of those values instead of some 120K some 121K if it didn't matter, but I'm not sure.
Posted: Sun Oct 19, 2008 9:10 pm Post subject:
120K for both are fine (or 121K). The reason why they didn't pick the same value is probably because they had 120K 5% and 121K 1%. Back in those days 1% metal film resistors were significantly more expensive than 5% carbon film.
For what it's worth, any clones I work on I approach this way:
Build the exact circuit (as much as possible).
Resistor values that I don't have are made with series resistors.
Once the circuit is going I start swapping out resistors in favor of values I already have. I also start swapping out opamps, transistors, etc.
See what is critical and what is not and WHY.
What improvements can be made and still be true to the original's sound?
Many original circuits are probably stripped down versions of their original self. Meaning Moog, ARP, or whoever would opt for cheaper parts whenever possible as long as it didn't compromise the circuit TOO much.
Feel free to do the same (maybe with better parts). Share your results.
What would be really interesting is if we could figure out what exactly makes the Odyssey VCOs interesting to our ears. For instance, I love the sound of Odyssey VCO sync. Why does it sound different than other saw core VCOs? It would be nice to implement this in other non-clone VCOs if possible. Or even change the circuit to make the sync more pronounced.
Cloning the exact circuit is well and good. But if I don't gain a deeper understanding of it, then it is not a good return on my time. I seek discoveries that will carry over to the next project, and the next...
Posted: Sun Oct 19, 2008 9:28 pm Post subject:
peng is right, the 120k is specified at 5%, the 121k is 1%. Looks like the 121k resistor is part of the PWM circuit, I guess its a more critical component.
I've learned a lot since I started building but there's still so much to learn. I should do the same more often, regarding switching out parts once I've finished a successful initial build. Especially with the ICs and transistors, since I always socket all of those. The resistors and caps I could see myself not doing since I'd have to desolder them. Though once I knew a circuit better and knew where a resistor or cap change could/would make a difference I could socket those specific ones.
Joined: Feb 16, 2007 Posts: 347 Location: Manchester UK
Audio files: 6
Posted: Mon Oct 20, 2008 9:11 am Post subject:
I don't usually bother with log pots unless they're absolutely required - lin are fine, you just loose a bit of control at the start of rotation (does that make sense??).
Yes, the FM inputs are logarithmic (muddled brain due to too much Tolexing and glue fumes - apologies)
I've just completed installing everything into a 6U rack, including both the 4023 and 4035 VCF's (with a second rack on it's way)
Sorry if this is a dumb question, but this project is a good example of something I've wondered about. When only 1 pad is given for each jack and pot and there are no extra ground pads on the board, where do you connect the ground lugs of each of these off-board components? Even if chained together on the jacks and pots themselves, where do you then ultimately connect to the common ground of the circuit?
EDIT: I especially wonder about this given the initial postings you made about problems related to using the same ground for both oscillators. If the answer to my question is to just drill a hole/holes somewhere in the ground trace, for this project, should the jacks and pots for each oscillator be connected to each osc's respective ground trace?
Great looking panels, by the way!
I'm just curious what others do to ground their off-board components when there aren't pads provided for them. Do you add pads yourself when you etch your board? If so, or if you just carefully drill small hole(s) somewhere in the ground trace, for this particular circuit, given Andy's initial problem with a ground loop between the 2 VCOs, does it matter what I connect to what part of the ground trace here?
Any help for someone admittedly still learning much appreciated.
Not dumb at all ... just not so easy to answer in a general way ... when the PCB designer did not bother to think about this it implies some laziness ... and wrong grounding can be a cause of trouble ... when no return paths are provided I'd just solder up something and when it behaves badly I'd try to find a better ground ref. and only then maybe drill a hole ... the hole doesn't have to be in a trace BTW, just beside it might be better as it probably can be a bigger hole then without damaging the trace.
Thanks for the reply. Sorry if my question implied any laziness on the part of the designer - not intended at all.
So when you say solder something up without drilling holes, what are some examples of where you might make these connections then? Thanks for the good advice regarding how to drill without breaking the trace. I usually use a smaller bit but this makes more sense (sometimes the bit is so small it makes it a slight challenge getting the wire through).
Andy, given the ground-related problems you initially had had and Blue Hell's comment on how wrong grounding can be a source of problems, any advice on grounding off-board components on this board?
Audio files: 6
Posted: Thu Oct 23, 2008 9:45 am Post subject:
I now tend to take the ground directly from the 0V pad on the PSU connector on all my modules, so far no problems.
I'm also glad that I'm not the original designer of this circuit : )
Yes, ARP did cut a lot of corners on their designs... certainly not enough decoupling for a start.
BTW, just posted the info for the 4035 VCF Module.
