ARP Odyssey Oscillators
Page 4 of 20 [488 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, ..., 18, 19, 20 Next
numbertalk
PostPosted: Fri Oct 17, 2008 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Exactly all I needed to know - thanks for taking the time to answer!
numbertalk
PostPosted: Fri Oct 17, 2008 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
One more question - I notice 4 FM inputs - is this 1 exp and 1 linear for each osc? If so, which one is the exp input and which is the linear for each osc?
urbanscallywag
PostPosted: Fri Oct 17, 2008 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
The pink dot FM inputs all look exponential (notice the 100k resistors are connected to the same node for each VCO).
numbertalk
PostPosted: Fri Oct 17, 2008 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I couldn't tell the difference between them either. So I'm guessing each osc has 2 exp FM inputs?
urbanscallywag
PostPosted: Fri Oct 17, 2008 8:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds right, check out the Odyssey it has 2 sliders for 'FM' per VCO (with selectable modulation sources).
Smile
peng
PostPosted: Fri Oct 17, 2008 11:51 pm    Post subject: ARP Odyssey Oscillators Reply with quote  Mark this post and the followings unread
AndyR1960 wrote:
To be honest, I had no idea that Tim Servo was also working on these VCO's (as we say in England - you wait all day for a bus, then two come along at once).Andy.
Umm... I just built a clone, too...before I even knew this thread was going! It turned up in my Google search for "Odyssey selected FET" !
AndyR1960 wrote:
There is something "special" about the Oddy VCO/RM combination
I agree. That is one reason why I built this clone. The other reason being I had two Odysseys here to repair and one with a non-working VCO. Thought it would help in troubleshooting (and some fun).
I've built three and all are different. These are on the breadboard and may be suffering from interference of some kind. I'll just have to do a pcb for this and see.
I subbed the 2N5910 with 2N3906
Subbed 2N5459 with 2N5458
Didn't bother with a tempco...yet.
The waveform offsets in the Odyssey are maintained when using SH Mixer to modulate VCO 2 or the VCF. The signals are AC coupled pre-VCF so level shifting should have little effect on the output sound.
I plan to do pcbs with:
2 VCO circuits with 4011 "ring mod"
portamento
noise
The goal is to make an Odyssey work alike with 3 modules - VCOs, VCF and LFO, and Mod sources (EGs, SH, etc). I'll ditch the 3080 VCA in favor of something better.
Oh yeah.
The FETs are marked "selected" in the Service manual.
Selected for what?
Any guesses?
phil
Broadwave
Audio files: 6
PostPosted: Sat Oct 18, 2008 1:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Numbertalk - The FM inputs are linear. I don't think ARP used Log FM on anything they made, maybe apart from the 2500.
Peng - The FET is "selected" for a low pinch off value. Any 2N5457/8/9 seems to work fine.
I didn't bother level shifting the VCO outputs to +/-5 volts, as I wanted a true clone (plus the fact that I wanted a small PCB footprint).
Andy.
Synth DIY Projects
Musical Doodlings
peng
PostPosted: Sat Oct 18, 2008 2:18 am    Post subject: ARP Odyssey Oscillators Reply with quote  Mark this post and the followings unread
Here are a couple samples. Two VCOs raw saw output. No VCF.
You'll here the mistracking most in the high range. This is without tempcos.
od_raw_saws1.wav
 Filesize:  3.06 MB
 Duration: 0:36
 Viewed:  2657 Time(s)
od_raw_saws2.wav
 Filesize:  1.91 MB
 Duration: 0:23
 Viewed:  2500 Time(s)
urbanscallywag
PostPosted: Sat Oct 18, 2008 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you clarify this please? The FM inputs are going through the exponential converter, so they are exponential FM inputs, right? Confused
Or did I miss something? Laughing
urbanscallywag
PostPosted: Sat Oct 18, 2008 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Never mind, I think we just have a semantics issue here. Exponential and linear response to the input versus linear and logarithmic controls to the input.
The Odyssey provides an exponential response to a linear input, right?
peng
PostPosted: Sat Oct 18, 2008 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes. Expo response. All the FM inputs sum at the base of the PNP of the expo converter. Works with 1V/Oct keyboards, etc.
The faders are different taper (not that doesn't matter much):
two FM inputs - Audio taper
Pulse Width - Linear
PWM - Audio
p.
numbertalk
PostPosted: Sun Oct 19, 2008 6:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looking at how close some of these resistor values are to each other, are any of them crucial enough to require .1% or is 1% okay all around?
urbanscallywag
PostPosted: Sun Oct 19, 2008 7:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Which resistors are you looking at?
numbertalk
PostPosted: Sun Oct 19, 2008 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
120K & 121K are actually the only ones I seem to see that could crossover within 1%. Does that matter for these particular ones? Just guessing why not use all of 1 of those values instead of some 120K some 121K if it didn't matter, but I'm not sure.
Thanks.
peng
PostPosted: Sun Oct 19, 2008 9:10 pm    Post subject: ARP Odyssey Oscillators Reply with quote  Mark this post and the followings unread
120K for both are fine (or 121K). The reason why they didn't pick the same value is probably because they had 120K 5% and 121K 1%. Back in those days 1% metal film resistors were significantly more expensive than 5% carbon film.
For what it's worth, any clones I work on I approach this way:
Build the exact circuit (as much as possible).
Resistor values that I don't have are made with series resistors.
Once the circuit is going I start swapping out resistors in favor of values I already have. I also start swapping out opamps, transistors, etc.
See what is critical and what is not and WHY.
What improvements can be made and still be true to the original's sound?
Many original circuits are probably stripped down versions of their original self. Meaning Moog, ARP, or whoever would opt for cheaper parts whenever possible as long as it didn't compromise the circuit TOO much.
Feel free to do the same (maybe with better parts). Share your results.
What would be really interesting is if we could figure out what exactly makes the Odyssey VCOs interesting to our ears. For instance, I love the sound of Odyssey VCO sync. Why does it sound different than other saw core VCOs? It would be nice to implement this in other non-clone VCOs if possible. Or even change the circuit to make the sync more pronounced.
Cloning the exact circuit is well and good. But if I don't gain a deeper understanding of it, then it is not a good return on my time. I seek discoveries that will carry over to the next project, and the next...
p.
urbanscallywag
PostPosted: Sun Oct 19, 2008 9:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
peng is right, the 120k is specified at 5%, the 121k is 1%. Looks like the 121k resistor is part of the PWM circuit, I guess its a more critical component.
numbertalk
PostPosted: Mon Oct 20, 2008 6:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for such a detailed response! Make sense.
I've learned a lot since I started building but there's still so much to learn. I should do the same more often, regarding switching out parts once I've finished a successful initial build. Especially with the ICs and transistors, since I always socket all of those. The resistors and caps I could see myself not doing since I'd have to desolder them. Though once I knew a circuit better and knew where a resistor or cap change could/would make a difference I could socket those specific ones.
numbertalk
PostPosted: Mon Oct 20, 2008 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
PWM - Audio
So the PWM pots are 100K Audio (but the manual PW pots are 100K Linear)?
Broadwave
Audio files: 6
PostPosted: Mon Oct 20, 2008 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't usually bother with log pots unless they're absolutely required - lin are fine, you just loose a bit of control at the start of rotation (does that make sense??).
Yes, the FM inputs are logarithmic (muddled brain due to too much Tolexing and glue fumes - apologies)
I've just completed installing everything into a 6U rack, including both the 4023 and 4035 VCF's (with a second rack on it's way)
Posted Image
Andy.
Synth DIY Projects
Musical Doodlings
urbanscallywag
PostPosted: Mon Oct 20, 2008 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice, I like the Odyssey MKIII colors. Very Happy
numbertalk
PostPosted: Tue Oct 21, 2008 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry if this is a dumb question, but this project is a good example of something I've wondered about. When only 1 pad is given for each jack and pot and there are no extra ground pads on the board, where do you connect the ground lugs of each of these off-board components? Even if chained together on the jacks and pots themselves, where do you then ultimately connect to the common ground of the circuit?
EDIT: I especially wonder about this given the initial postings you made about problems related to using the same ground for both oscillators. If the answer to my question is to just drill a hole/holes somewhere in the ground trace, for this project, should the jacks and pots for each oscillator be connected to each osc's respective ground trace?
Great looking panels, by the way!
Makes sense. Thanks!
numbertalk
PostPosted: Thu Oct 23, 2008 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Is it really *that* dumb of a question? Embarassed
I'm just curious what others do to ground their off-board components when there aren't pads provided for them. Do you add pads yourself when you etch your board? If so, or if you just carefully drill small hole(s) somewhere in the ground trace, for this particular circuit, given Andy's initial problem with a ground loop between the 2 VCOs, does it matter what I connect to what part of the ground trace here?
Any help for someone admittedly still learning much appreciated.
Former site admin
Audio files: 353
PostPosted: Thu Oct 23, 2008 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Not dumb at all ... just not so easy to answer in a general way ... when the PCB designer did not bother to think about this it implies some laziness ... and wrong grounding can be a cause of trouble ... when no return paths are provided I'd just solder up something and when it behaves badly I'd try to find a better ground ref. and only then maybe drill a hole ... the hole doesn't have to be in a trace BTW, just beside it might be better as it probably can be a bigger hole then without damaging the trace.
numbertalk
PostPosted: Thu Oct 23, 2008 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply. Sorry if my question implied any laziness on the part of the designer - not intended at all.
So when you say solder something up without drilling holes, what are some examples of where you might make these connections then? Thanks for the good advice regarding how to drill without breaking the trace. I usually use a smaller bit but this makes more sense (sometimes the bit is so small it makes it a slight challenge getting the wire through).
Andy, given the ground-related problems you initially had had and Blue Hell's comment on how wrong grounding can be a source of problems, any advice on grounding off-board components on this board?
Broadwave
Audio files: 6
PostPosted: Thu Oct 23, 2008 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I now tend to take the ground directly from the 0V pad on the PSU connector on all my modules, so far no problems.
I'm also glad that I'm not the original designer of this circuit : )
Yes, ARP did cut a lot of corners on their designs... certainly not enough decoupling for a start.
BTW, just posted the info for the 4035 VCF Module.
Andy.
Synth DIY Projects
Musical Doodlings
