Problems with Nord Lead 2
Page 1 of 1 [14 Posts]
gabbe
PostPosted: Wed Nov 22, 2006 11:04 am    Post subject: Problems with Nord Lead 2 Reply with quote  Mark this post and the followings unread
When I'm splitting the synth it's just coming sound out of the one half of it. What should i do?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Nov 24, 2006 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just try to ask your question in this forum:
http://www.electro-music.com/forum/forum-137.html
Wout
Former site admin
Audio files: 353
PostPosted: Fri Nov 24, 2006 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good idea Wout :D
I moved the post.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Nov 25, 2006 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, here's the right place Smile
First of all, the Manual is always download able from Clavia's site in pdf format. It's on page 14.
Activate the split by pressing the button.
Activate at least two Slots, best is Slot A and Slot C.
Slot A will sound in the lower half, Slot C in the upper half.
After this, select the sounds you want to use.
By [Shift+Split] you can change the splitting point of your keyboard.
Be sure Slot C+D are set to the same output. [Manual page 59]
Mostly Slot A+B are set in stereo [ab3], so when you select Slot C+D it has to be [cd-], which means the same as Slot A+B.
If your synth is a NordLead(Rack) or NordLead(Rack)2, you'll need a PCMIA card to save the settings as a performance; no problem to do this on a NordLead(Rack)2X.
Wheel and PitchStick are global, so if you use for your right hand a lead sound and in the left a beautiful bass, the later will change in pitch too!
Hope all is clear...
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Nov 25, 2006 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Forgot to write: when playing any key, while holding [Shift+Split], that key will be the lowest key of the upper part.
Wout
gabbe
PostPosted: Sat Dec 23, 2006 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its bin a while since I posted anything in this thread, but it comes just sound from the lowest part of NL2, not te highest... Any suggestions?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Dec 23, 2006 5:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you have two Slots activated?
Slot A & B are used for the lower part, Slot C & D for the upper part.
Wout
gabbe
PostPosted: Sat Dec 23, 2006 5:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, i have. But it does not come any sound if I have selected C, even when the keyboard is not split.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Dec 23, 2006 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
How about the output routing of Slot C?
If it's set to output 3 and you're only using output 1 & 2...
Wout
gabbe
PostPosted: Sat Dec 23, 2006 5:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, that's the problem, it works perfectly now Smile Thanks for the help!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Dec 24, 2006 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey, I just noticed you changed your last mail!
I was writing a long story and at the same moment you solved your own problem Smile
Just for the records, here is my, for the moment redundant, answer:
gabbe wrote:
Ah, that's probably the problem, how do i change that?
Well, there is of course the Manual, downloadable at Clavia's site:
http://www.clavia.se/products/manuals.htm#nl2
Take a look at page 59 - Out Mode.
BTW it continues on page 60 Wink
Further more, if you have a NordLead2(X), it's also written in the text on the panel itself, the second item.
It reads:
OUT MODE
Slot C and D
-.cd Slot C and D routed same as A and B
Anyway, press [Shift+SlotB] > Out Mode.
press [SlotB] (without the Shift) again and you'll find the settings of Slot C & D.
When it reads [-.cd] it will copy the settings of Slot A & B.
If there is another setting, e.g. [4.cd], change the first value to [-.cd] using the the up & down buttons beneath the display.
Of course the Slot A & B settings have to be [1.ab] Smile
Let me know if it works...
The NordLead has a very open and easy to understand interface, apart of these kind of [Shift] functions, which work using menu's. At the other hand, once set the synth will mostly stay this way, until it will find a new owner.
Wout
gabbe
PostPosted: Sun Dec 24, 2006 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, i kinda figure it out myself, but thanks for the help anyway! Btw, do you know about any natural piano sounds out there?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Dec 24, 2006 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's what the Electro and Stage are for...
If you want to do it on a Lead, you have to think about performances.
Let us know about some results, because with a little help it can be done.
Wout
Erv
PostPosted: Sun Jun 26, 2016 7:35 pm    Post subject: KBD Split not Work, only as trig note in NL2 ¿ whi ? Reply with quote  Mark this post and the followings unread
hi Boys, i revive this topic for solve a following problem:
¿ my Nord Lead 2 requires of some trick for activated KBD Split ?
when buy it 4 months ago (I am the third owner), i was in the same situation than now, which did not work the KBD Split, at that time, had found on the internet, a procedure to enable the KBD Split, and I remember than had to press a combination of buttons.. or configure something
It was different from that specified in the manual
and had worked
but now I press the KBD Split and only trigger a Do3 note as if it were a Nord Lead 2 Rack
