 Forum index » Instruments and Equipment » Soft synths
Setting up Softsynths in OMS
Page 1 of 1 [8 Posts]
Gothboy
PostPosted: Mon Mar 20, 2006 7:50 am    Post subject: Setting up Softsynths in OMS Reply with quote  Mark this post and the followings unread
Can anyone please fill me in on how to setup a softsynth in OMS. I'm using OMS 2.3.8 in OS 9.2.2. I understand fully how to add a hardware synth in OMS having done it about a thousand times, but for some reason can't quite get my head around this one partly beacause the synths' manual info is so sparse on the subject! There's a Midi in and a Midi channel select from the drop down menu in the synth software and THAT'S IT! Do I use the IAC bus as the midi in, for instance? Do I have to add a device in the OMS setup? None of this is explained in this manual Question Plus it's an old, no longer supported product. So I guess what I need is a Softsynth/OMS 101 course. It's probably easy and I'm just missing it. Rolling Eyes Any help would be great.
Apple Mac Pro 2019 3.2 GHz 16-Core Intel Xeon W
96 GB Ram
15.6 Sequoia
Novation SL49, Behringer 2600, Crave, Edge
Mophox4, Nord Lead 2,Modal electronics Argon 8m, Roland System 1, Novation Nova, Nord Micro modular, Korg Radias, Roland d-05, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Arturia Beatstep and SparkLE, Korg ER-1, Unosynth
"We are the music makers and we are the dreamers of dreams"
Dymaxion Vehicle Music at www.dymaxionvehicle.com/
Audio files: 21
PostPosted: Mon Mar 20, 2006 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Softsynths usually won´t show up in OMS. Mostly they are inside a host, like Cubase 5.x or similar. Standalone apps have their own midi settings, like B4 and Pro 52.
Gothboy
PostPosted: Mon Mar 20, 2006 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
So how do I get it to show up in the Pro Tools list of instruments in a Midi track?
96 GB Ram
15.6 Sequoia
Audio files: 21
PostPosted: Mon Mar 20, 2006 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Any PT users here? When I still was on 9, I used Steinberg Cubase 5.x VST 32.
Audio files: 19
PostPosted: Mon Mar 20, 2006 4:07 pm    Post subject: Re: Setting up Softsynths in OMS Reply with quote  Mark this post and the followings unread
The info is all there- it looks brief but it does make sense and it's actually easier than you think. Trust me Smile
What midi interface are you using?
Gothboy
PostPosted: Mon Mar 20, 2006 6:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
M-Audio 8X8 Midisport
96 GB Ram
15.6 Sequoia
Audio files: 19
PostPosted: Tue Mar 21, 2006 2:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh no- not the midisport!! Shocked
I had nothing but problems with the smaller version- no actually I tell a lie- it worked flawlessly for a while then one day it just 'died'!
If you can find one, the best cards are the PCI ones- not the usb ones.
ACHTUNG!
paul e.
PostPosted: Tue Mar 21, 2006 7:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
not exactly sure about Pro Tools
but in OMS setup [which i presume is in PT's], make sure you have all ports checked off as inputs ....
i assume you will be triggering the softsynth from a controller..if so, make sure the port number that corresponds to the controller's midi input on the MIDIsport, is selected on a PT's track
Spiral Recordings
