 Forum index » Instruments and Equipment » Reaktor
modulating filter cutoff
Page 1 of 1 [6 Posts]
slave to this
G2 patch files: 7
PostPosted: Sun Nov 27, 2005 11:39 am    Post subject: modulating filter cutoff Reply with quote  Mark this post and the followings unread
i'm new to reaktor, and trying to do some things that i'm used to on the nord. how would you modulate the cutoff frequency of a filter with a regular, non-fancy ADSR envelope? reaktor won't let me connect my plugs this way. is there something in the properties that needs to be changed, or can this even be done?
i'd appreciate any help...
james
slave to this
G2 patch files: 7
PostPosted: Sun Nov 27, 2005 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
okay, so i see that the envelopes in the macro section have both types of outputs, but as a lesson, i'd still like to know how you go about making one of those regular ADSR envelopes in the "built in" section capable to do both?
Axiom
G2 patch files: 28
PostPosted: Mon Nov 28, 2005 4:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I used to pick a standard ADSR from macros and put the red output to P input of the filter. if you want to control the modulation amount, simply use a multiplier and connect both the envelope red output and a knob. Otherwise you can connet the black output to multiplier but you have to use an "A to E" conertor after the multiplier.
Luca
Posted Image Posted Image
slave to this
G2 patch files: 7
PostPosted: Wed Nov 30, 2005 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks luca, appreciate the help. needed that a to e converter!
james
060171
PostPosted: Sat Feb 04, 2006 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
The easiest way to do is, is to use a filter with FM. (that what it's for)
The FM input is for Audio (like an ADSR output)
Note that the range of FM=0 to 5000. The max. ADSR output= 1 , so you'll have to multiply the ADSR out by 1000 or more.
borgnagar
PostPosted: Fri Jan 12, 2007 5:02 am    Post subject: Reply with quote  Mark this post and the followings unread
In my first ensemble I did it like this:
1. (ADSR-Env) - input knobs for A,D,S and R (created with create control) and gate input from sequencer gate output.
2. (X) - Output signal was multiplied with 5000 (because the out connection gives values from 0 to 1 and filter expects values from 0 to 5000.)
3. (Amp/Mixer) - Multiplier was connected to a simple amp/mixer, with input knob for level to control the amount of the envelope.
4. (Pro-52 Filter) - Output of amp/mixer was connected to linear cutoff control input of the pro-52 filter.
