dnny
Joined: Mar 12, 2005 Posts: 519 Location: Helsinki, Finland
adhdboy
Posted: Tue Mar 22, 2005 6:12 am Post subject:
This is very cool. Thanks for taking the time to do this.
adhdboy _________________ There 10 kinds of people in this world that understand binary those that do and those that don't. |
Alex_D_Steak
Posted: Thu Mar 24, 2005 4:38 pm Post subject:
great work, dnny!
@adhdboy
might be worth including a link to this post on your site  _________________ Doctor... who? |
etaoin
Joined: Jun 30, 2005 Posts: 761 Location: Utrecht, NL
Posted: Wed Oct 26, 2005 10:29 pm Post subject:
More LF442 replacements: TL072 (low noise), TL062 (low power)
More LF444 replacements: TL064 (low power)
TL082 and TL084 are also options. |
dnny
Posted: Thu Oct 27, 2005 2:00 pm Post subject:
thanks Etaoin for the substitutes.
and thanks v-un-v for making this post "Sticky"
i added the subtitutes for the MPF102.
daniel _________________ Association of experimental electronics
www.koelse.org
flickr: cable porn group |
Audio files: 19
Posted: Thu Oct 27, 2005 2:23 pm Post subject:
no probs dnny :)
I'm gonna address the other issues as soon as Mosc sorts out some current server problems.
Tom |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
Posted: Sat Oct 29, 2005 5:43 am Post subject:
What does "sticky" mean?  _________________ What makes a space ours, is what we put there, and what we do there. |
dnny
Posted: Mon Oct 31, 2005 12:45 am Post subject:
i think that sticky means
the post will stick on top of the list no matter what.
so it will not get buried by time. _________________ Association of experimental electronics
www.koelse.org
Audio files: 19
Posted: Mon Oct 31, 2005 12:48 am Post subject:
| Uncle Krunkus wrote: | | What does "sticky" mean? :? |
I'll probably do the same for your veroboard designs as soon as the become more 'buried'! |
gubbeper
Posted: Mon Oct 31, 2005 1:13 am Post subject:
On the subject of substitutes I’ve been thinking about the 1N914 diode and whether it could be replaced by the 1N4148?
In the partslist for the 1V/Octave Voltage Controlled Oscillator the diodes are only refered to as High Speed Sw Diodes. Could the 1N4148 be used here as well?  _________________ /Per
I'm on Twitter |
Posted: Mon Oct 31, 2005 1:21 am Post subject:
The 1N914 and the 1N4148 are almost exactly the same. I haven't come across a circuit which quotes one and doesn't work with the other. You can however get diodes that switch faster than either of them. _________________ What makes a space ours, is what we put there, and what we do there. |
Pehr
Posted: Sat Dec 03, 2005 1:35 pm Post subject:
I can't see anything wrong with it.
I'm not an expert at reading Op-Amp specs though.
Pinout, and power supply are fine, so I'd give it a go. _________________ What makes a space ours, is what we put there, and what we do there. |
etaoin
Posted: Thu Dec 08, 2005 12:51 am Post subject:
| Pehr wrote: | Does anyone know if the LM324 is a good substitute for LF444?  |
LF444 is a JFET input opamp, LM324 isn't. So no. |
etaoin
Posted: Thu Dec 08, 2005 12:55 am Post subject:
By the way, I'm currently building RJW's VCO and found that replacing the LF411 and LF442 with their TL "equivalents" doesn't always work. I can't get the 1V/Oct scaling right with these substitutes in. So the exact specs might be essential in some applications.
This might also affect the LF444 used in the SL's oscillators. I got mine to work with TL064's, but judging from my experience with the VCO, the original LF might have been better. |
dnny
Posted: Thu Dec 08, 2005 1:04 am Post subject:
thanks for the info.
the "equivalents" are picked up whit only equal pinnouts . not by the specs
| Ray W wrote: | Op Amp Substitution?
Pretty much any quad JFET input op-amp with the same pinout will do to replace the LF444 and pretty much any dual JFET input op-amp with the same pinout will do to replace the LF442. I chose these because they draw very little current and they are still in full production. There are many many JFET input op-amps in full production. Search for "JFET input" on your favorite part suppliers website and they'll be there. |
etaoin
Posted: Thu Dec 08, 2005 1:15 am Post subject:
| I should probably add that my LF411 and 442 are still on order, so although I can't get the VCO to work properly with TL061 and TL062 replacements, I can't yet say it does work with the LF's! I'm just assuming that the reason I can't get it tuned is because I tried replacements. All other components are as specified and it does work fine apart from the tuning. |
Audio files: 19
Posted: Thu Dec 08, 2005 2:23 pm Post subject:
| Etaoin wrote: | | I should probably add that my LF411 and 442 are still on order, so although I can't get the VCO to work properly with TL061 and TL062 replacements, |
Etaoin,
This is a bit off topic. Do you mind starting afresh in a new thread?- as I want to try and keep this thread reference material as far as possible- and of course open source- and no need for locking it. Thanks!
Tom _________________ ACHTUNG!
etaoin
Posted: Thu Dec 08, 2005 2:37 pm Post subject:
| I was trying to explain that it was wrong to include my comment at the top of this thread. If I say that elsewhere, it's of not much use. I'd suggest just removing my messages from this thread. |
Audio files: 19
Posted: Sun Dec 11, 2005 3:38 am Post subject:
| Etaoin wrote: | | I'd suggest just removing my messages from this thread. |
No offense mate, but I've got enough things on my plate right now- than having to chase list members who aren't thinking before pressing return. (This goes for everyone btw!)
I hope you understand
If you've got a component which works as a substitute for any component on Ray's site- then by all means- put it here. But if you have a problem with a substituted component listed on this thread, then please start a fresh thread- then everyone can gain knowledge from your discovered experiences- otherwise everything just gets buried.
You could also include a link in your new post so people understand where you are coming from? _________________ ACHTUNG!
seraph
Editor
Audio files: 33
Posted: Sun Dec 11, 2005 3:43 am Post subject:
you can do it yourself  _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
Pehr
Posted: Mon Jan 09, 2006 7:04 am Post subject:
Yeah,
Ray said there's some specific problem with the TLXXX series, I think it was in the VCO, can't remember, but apart from that they're fine. _________________ What makes a space ours, is what we put there, and what we do there. |
Mikmo
Joined: Dec 01, 2005 Posts: 150 Location: Copenhagen - Denmark
Posted: Thu Apr 06, 2006 2:38 am Post subject:
Just a little warning.
You can't always substitute 13600 for 13700. 13700 have linearisation diodes, 13600 does not.
If Rays design uses these diodes you can NOT use the 13600 in stead of the 13700.
I do not know if this is the case though. _________________ Stay Cool
Mikael
http://www.mikmo.dk |
