Coming up on Radio 1 at
Snare simulation using banded waveguide
Page 1 of 1 [4 Posts]
Axiom
G2 patch files: 28
PostPosted: Sun Oct 23, 2005 5:13 am    Post subject: Snare simulation using banded waveguide Reply with quote  Mark this post and the followings unread
Hi folks,
today i've found an interensting paper about banded waveguide (i'm been searching info about tabla synthesis) and I've played around with this technique. This is my first result, a snare drum.
I would like to see improvements made by you all Smile
Luca
snare.mp3
Sound sample
 Filesize:  194.31 KB
 Viewed:  1702 Time(s)
snare.pch2
Patch file. Uses a lot of cpu so I dunno if it will load on a standard G2/Engine.
 Filename:  snare.pch2
 Filesize:  2.81 KB
 Downloaded:  2090 Time(s)
Posted Image Posted Image
Audio files: 353
PostPosted: Sun Oct 23, 2005 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds interesting, could you tell a bit more about the banded wave guide technique, or maybe point us to some web site ?
The funnny thing is that when I disabled the reverb the sound didn't resemble a snare anymore, and so I thought I could remove all the waveguide stuff and replace it with a noise osc, but that was too simple, bad idea :-)
Axiom
G2 patch files: 28
PostPosted: Sun Oct 23, 2005 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
in fact is the same thing i've noticed. Here are two interesting docs:
ftp://ftp.cs.princeton.edu/techreports/2002/659.pdf
http://www.cs.princeton.edu/sound/research/controllers/etabla/Petthesis.pdf
The frist schema i've found uses some delayed BPF and a feedback path. Another, instead, adds a reflection block and, after, another series of delayed BPF as a feedback path. I've used this one and results are interesting. More work is needed and I'm very lame on math Razz
Luca
Audio files: 353
PostPosted: Sun Oct 23, 2005 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Axiom wrote:
[...] I'm very lame on math :P
Luca
But your patch is interesting nevertheless.
Tthanks for the links !
