Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
Joined: Jan 31, 2003 Posts: 18532 Location: Durham, NC
Audio files: 267
Posted: Thu Oct 20, 2005 7:46 am Post subject:
The arrow is the positive power supply rail. It is a common convention in schematics. Probably not a great one, but it is often used nevertheless. _________________ --Howard
my music and other stuff |
Pehr
Audio files: 267
Posted: Thu Oct 20, 2005 8:45 am Post subject:
| Pehr wrote: |
Where should I connect the modulation input and signal input if I build this into my SL? |
Maybe use a switch and choose an oscillator and an LFO for the modulation input.
For the signal input, why not go with the output of the SL itself?
Could I use a TL084 along with the LM13700?[/quote]
I would think any garden variety op amp would work. _________________ --Howard
dnny
Joined: Mar 12, 2005 Posts: 519 Location: Helsinki, Finland
Audio files: 19
Posted: Sun Oct 23, 2005 4:32 pm Post subject:
that's a nice and simple design Ray Will it work with SoundLab's +/- 9v range?
(cheers for the link dnny ) |
Audio files: 267
Pehr
Audio files: 267
Posted: Mon Nov 07, 2005 9:36 am Post subject:
| Pehr wrote: | | What if the signal input comes from a microphone and the modulation from a VCO? what happens? |
You get classic ring modulator sounds. Try it, you'll like it... _________________ --Howard
Pehr
Former site admin
Audio files: 353
Posted: Mon Nov 07, 2005 1:51 pm Post subject:
| More like short wave radio speech sounds. |
Audio files: 19
Posted: Mon Nov 07, 2005 2:23 pm Post subject:
| Pehr wrote: | | Like a vocoder? |
If you use a square wave around 4 to 15 Hz you get the classic Dr Who 'Dalek'
not only that- it sounds rather disturbing- way better than your average boring old vocoder  _________________ ACHTUNG!
Audio files: 267
Posted: Mon Nov 07, 2005 2:26 pm Post subject:
Isn't that Flakey Foont?  _________________ --Howard
Audio files: 19
Posted: Tue Nov 08, 2005 5:02 am Post subject:
| mosc wrote: |
Isn't that Flakey Foont?  |
Possibly? I'm a bit flakey myself at the best of times!
I did a search on Robert Crumb and Google came back with this. (originally I wanted his 'Stoned Again' image- but I thought this was more appropriate ) _________________ ACHTUNG!
fluxmonkey
Posted: Wed Nov 09, 2005 7:09 am Post subject:
i think you'd need to add some amplification to the mike signal... you want both signal and carrier to be at comparable levels.
b |
adhdboy
Posted: Mon Nov 14, 2005 6:38 am Post subject:
Ring Modulator with AD633 for about 6 bucks and 6 mAs Subject description: Here is the simplest AD633 ring mod you will find. |
Hi All
I finally got around to the AD633 and its very cool. There are definitely more precision circuits out there but this one is very simple and only uses about 6 mA. The chip is very accurate straight out of the shoot thus I skipped all of the offset nulling, balancing, yada yada etc. It is not DC coupled but the 2uF caps on the inputs are so you can pass from very low freq AC signals to very high ones. I show +/-12V but it will work from +/-9 to +/-15 volts.
http://www.musicfromouterspace.com/analogsynth/RingModulator/RingModulator.html
adhdboy _________________ There 10 kinds of people in this world that understand binary those that do and those that don't. |
Lorenzo
Joined: Nov 09, 2008 Posts: 375 Location: Trieste - Italy
Posted: Sun Nov 09, 2008 2:13 am Post subject:
Re: super simple ring modulator |
Hallo,
I try to built this ring modulator: WARP633
Looking .pdf shematic v.a.1 I don't understand how is connect the CONN H5.
I notice that the AD633 is used in a different way from the MFOS Simple Ring Modulator...
My prototipe seems not work...  |
Audio files: 267
Posted: Mon Nov 10, 2008 11:47 am Post subject:
Here's what I think:
On H5,
connect 1 and 2
connect 3 and 4
See how that works. I'm not exactly sure what pin 5 is for, but I would leave it unconnected.
The two different circuits are pretty similar. Instead of the Multiply/Modulate switch on the MFOS link, the one you are using uses RV5 for this function. The pot is better because you get a continual adjustment. I would call it MIX/BLEND. IMHO, the warp633 circuit is superior because it has buffered inputs, AC/DC coupling, a blend control, and buffered output. Good choice.
I don't think you need the two trim pots, RV3 and RV4, because the 633 is laser trimmed. If you don't use them, just connect the ends of R5 and R7 to GND.
Hope this helps. _________________ --Howard
Lorenzo
Posted: Mon Nov 10, 2008 1:54 pm Post subject:
| mosc wrote: | Here's what I think:
On H5,
connect 1 and 2
connect 3 and 4
Thank you for your kindly reply.
I thought H5 connect 2 to 1 and 5 in ON-OFF-ON mode, and 3 with 4.
I built and re-built it but I think I'm makeing some mistake...
maybe some value for R or C...
or too difficoult for fledgeling...
You think that the schematic is good done? |
stolenfat
Joined: Apr 17, 2008 Posts: 476 Location: Sunny Oakland California
Posted: Mon Nov 10, 2008 6:35 pm Post subject:
i was turned onto the AD633 because it seems like the main chip in ray's ring mod
jameco sells them for 9 bucks a pop, is there a cheaper place to find them? 9 bux! I think thats whacky! |
guitarfool
Lorenzo
Posted: Tue Nov 11, 2008 5:32 am Post subject:
| guitarfool wrote: | Marc covers it in the docs that he ships with his PCB. Also this was discussed in this thread a while back
Thank you!! |
RKHobbs
Posted: Tue Nov 11, 2008 7:31 am Post subject:
| You can buy direct from www.analog.com. Might be worth it if you want some other things (like the matched transistor pairs for Ray's VCO.) |
shimshon
Joined: Sep 03, 2008 Posts: 9 Location: bergen county, nj
Posted: Thu Jan 22, 2009 7:01 pm Post subject:
| stolenfat wrote: | | jameco sells them for 9 bucks a pop, is there a cheaper place to find them? 9 bux! I think thats whacky! |
they're on "sale" for 7.75 now
does anybody have the schematic for the 13700 based ring mod? the link mentioned earlier no longer works.
thanks
vito |
RF
Audio files: 28
