Asio Chuck
Page 2 of 2 [34 Posts]
Goto page: Previous 1, 2
radarsat1
PostPosted: Mon Aug 11, 2008 10:22 am    Post subject: asio build cvs aug 4. Reply with quote  Mark this post and the followings unread
Here's a build of the latest CVS with ASIO support. (Last commit was Aug 4.) I tested it with DS, but I don't have ASIO installed on this computer so I didn't actually test this build yet, so who knows.. Wink (Seems to run fine on silent mode.) DX9 SDK was installed. Please confirm that it works.
Built in VS2005, pre-SP1 Vista 32-bit. Included a patch detailing a few changes I needed to do to get it to compile.
Steve
chuck-asio-aug4.zip
Here's a build of the latest CVS with ASIO support. (Last commit was Aug 4.) I tested it with DS, but I don't have ASIO installed on this computer so I didn't actually test this build yet, so who knows.. ;-) (Seems to run fine on silent mode.) DX9 SDK
 Filename:  chuck-asio-aug4.zip
 Filesize:  458.28 KB
 Downloaded:  1674 Time(s)
radarsat1
PostPosted: Mon Aug 11, 2008 12:48 pm    Post subject: another try Reply with quote  Mark this post and the followings unread
Look as though building on a combination of Vista and VS2005 led to a bad executable. Here's another try, this time built on XP.
chuck-asio-aug4-2.zip
 Filename:  chuck-asio-aug4-2.zip
 Filesize:  455.05 KB
 Downloaded:  1756 Time(s)
radarsat1
PostPosted: Mon Aug 11, 2008 6:54 pm    Post subject: one more time.. Reply with quote  Mark this post and the followings unread
I'll keep my expletives to myself and give it another shot: this one's built on XP using VS2003, without IE7 installed (to my knowledge; haven't had a chance to check properly, this was built remotely).
chuck-asio-aug4-3.zip
I'll keep my expletives to myself and give it another shot: this one's built on XP using VS2003, without IE7 installed (to my knowledge, haven't had a chance to check).
 Filename:  chuck-asio-aug4-3.zip
 Filesize:  442.85 KB
 Downloaded:  1766 Time(s)
PostPosted: Tue Aug 12, 2008 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Please note that on XP (under some configurations?) this version may crash at shutdown. Right-clicking on the exe and turning on "compatibility mode" set to Windows2000 seems to fix this.
Arnaud06
PostPosted: Thu Aug 25, 2011 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry but I have a little problem with the ASIO Chuck, I don't know if it has been discussed already.
I want to do something like this :
adc.chan(5) => WvOut w => blackhole;
I have :
[chuck](VM): NullPointerException: (UGen link) in shred[id=1:Sampler.ck], PC=[31]
Can you help me ?
eudes
PostPosted: Thu Jul 31, 2014 6:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey.
I've successfully built the latest stable release (1.3.4.0) with ASIO support (attached to this post Very Happy).
This was a fantastically mind-numbing experience, as the documentation is sparse and disperse. Thanks to the users of this thread and this other one ( http://electro-music.com/forum/topic-20796.html ) for the info.
It sometimes crashes on shutdown. No compatibility mode in Win8 remedies this.
Exe inside the rar, simply extract and use.
For the daring souls who would like to try building it from source this is the process I followed: (Using Windos 8 and Visual Studio 2010).
IMPORTANT NOTE: DON'T ClOSE VISUAL STUDIO UNTIL YOU HAVE FINISHED. All of these config changes are volatile. If you close it, you will have to go back to step one (well, 2 or 3, since you don't have to install DirectX again, and its directory location will stay put).
Download and install DirectX SDK (August 2007). This is the last version that supports Chuck, since it uses deprecated libraries (dinput.lib, dxgui.lib...).
Open the project (dsw file) and say yes to everything.
Add the location (C:\Program Files (x86)\Microsoft DirectX SDK (August 2007)\Lib\x86 by default) to Visual Studio VC++ library include path (under Porject>Properties>VC++ directories>Library directories) at the beginning of the list.
In the same properties window, make sure that Release is selected on top, and go to C/C++>Preprocessor.
Substitute everything in Preprocessor definitions for:
NDEBUG;__PLATFORM_WIN32__;WIN32;_CONSOLE;__WINDOWS_ASIO__;__WINDOWS_DS__;_SCL_SECURE_NO_WARNINGS;_CRT_SECURE_NO_WARNINGS;%(PreprocessorDefinitions)
Go to Linker>Input and add ws2_32.lib to the additional dependencies list.
Now, download the matching release of RtAudio* (this version is http://www.music.mcgill.ca/~gary/rtaudio/release/rtaudio-4.0.12.tar.gz).
Take the files in the Include folder and put them in the chuck/src/RtAudio folder.**
Make sure to ADD THESE FILES TO THE PROJECT in Visual Studio by selecting "See all" in the VS "Solution Browser" and rightclicking on them>add to project.
Select Release as target, compile (Ctrl+B) and hope it works.***
And that's all.
* You can check what version of RtAudio chuck uses in src/RtAudio/RtAudio.h.
Code:
// RtAudio version
static const std::string VERSION( "4.0.12" );
Also, you can find other releases of RtAudio at http://www.music.mcgill.ca/~gary/rtaudio/release/ , and the RtAudio site is
http://www.music.mcgill.ca/~gary/rtaudio/index.html
** To be honest, I had no idea where to put these files, so I put them everywhere. If the described process does not compile/link, and complains about not finding asiosys.h or something asio-ish, try this other approach, which is what I did:
Copy the files under include to all of these locations: src/, src/asio, src/RtAudio, src/RtAudio/include, src/RtAudio/asio.
Add the new files in src/ (only the ones at the root) to the project.
*** If it still doesn't compile, it might help installing the latest Windows SDK. I have no clue if this is necessary, but I had it installed when I built this.
chuck.rar
Chuck 1.3.4.0 with ASIO support. Exe inside.
 Filename:  chuck.rar
 Filesize:  579.82 KB
 Downloaded:  2655 Time(s)
sorenkj
PostPosted: Mon Sep 01, 2014 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the effort, much appreciated!
However, it doesn't work for me - after copying/overwriting the .exe file I am still experiencing slow latency..
Are we supposed to have any visual indications as to whether this is working correctly? I can't see any changes in Chuck's preferences menu and also, normally when I start up Renoise - where I have set up ASIO4ALL - in the taskbar the ASIO4ALL control panel will pop up (with ASIO-Chuck it doesn't).
neuro99
PostPosted: Thu Apr 22, 2021 6:37 am    Post subject: chuck asio build
Subject description: how to build chuck with asio support with visual studio 2019
hi everybody,
I managed to compile chuck with asio support with visual studio 2019.
Here is how I did :
lauch vs2019 by clicking on chuck.sln (chuck-1.4.0.1\src\visual-studio)
select x86 option instead of x64 in the ide (just under the menus)
add in the preprocessor (project/ properties/ C/C++ / preprocessor / preprocessor definitions) __WINDOWS_ASIO__
copy include files from "rtaudio-5.1.0\include" to "chuck-1.4.0.1\src\host\RtAudio"
(https://www.music.mcgill.ca/~gary/rtaudio/)
add those files in the solution explorer (in host/rtaudio)
build the solution
when you launch from command line, if you want to choose an audio device, you must specify both adc and dac
i.e. type in console : chuck --adc2 --dac2 --bufsize128 chuckfile.ck
I've tried compiling with x64, it builds ok but the executable crashes.
Thanks to all previous authors for their precious and helpful contributions.
you will find in attachment the chuck 1.4.0.1 asio build.
chuck.zip
 Filename:  chuck.zip
 Filesize:  1.07 MB
 Downloaded:  575 Time(s)
caiafaverde
PostPosted: Sun Apr 25, 2021 6:25 am    Post subject: ChucK ASIO build
Subject description: extra things to check
The RtAudio macro __WINDOWS_DS__ (for DirectSound audio) is widely used in code for specifying windows-specific parts. Although there's a macro defined __PLATFORM_WIN32__ for that matter (I suppose it's historical...).
So everywhere __WINDOWS_DS__ macro is being checked in code (apart from RtAudio code of course) you should add check for __WINDOWS_ASIO__ or replace it to __PLATFORM_WIN32__.
Otherwise win64 build works ok without crashes (didn't try big projects yet).
