 Forum index » Clavia Nord Modular » G2 Performances - Experimental
Cello physical model
Page 1 of 1 [2 Posts]
Chet
G2 patch files: 35
PostPosted: Sat Jun 25, 2005 4:46 am    Post subject: Cello physical model Reply with quote  Mark this post and the followings unread
Here's a physical model of a cello, EQ'd from C2 through G4. I'm hoping to put together a complete set of strings (violin, viola, cello, and contrabass), so I'm considering everything experimental until the entire set is done.
Like the violin, expressiveness can be controlled by either morph group 1 (the mod wheel) or morph group 8 (a breath controller).
I added the cello to a little test mp3 that already some violins in it.
mumsCello011.prf2
A cello physical model.
 Filename:  mumsCello011.prf2
 Filesize:  41.95 KB
 Downloaded:  1707 Time(s)
Audio files: 266
PostPosted: Sat Jun 25, 2005 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Quite good, Chet. I understand this after your talk at electro-music 2005.
I would not have thought one could acheive such good results on a VA synth. But, I guess the way you are using the G2, it is not really a VA synth, but more of a DSP synth. Excellent. I look forward to your releasing a string section. Smile
