BÄDBUNNY
Posted: Thu Feb 08, 2018 12:51 am Post subject:
MFOS Soundlab Ultimate Midi Mod Subject description: How to wire |
So to introduce myself: I'm pretty new here in this forum, to analog synthesis and DIY stuff. I'm just building a MFOS Soundlab Ultimate and also want to include a Midi to CV Converter.
Since I'm pretty unexperienced I want to know if anybody here has an idea how I can Midi control the most of the stuff that's possible my Soundlab. I know I can use something like a Doepfer MCV4, Darklink or a Midimplant from Roman Sowa. But have these enough outputs? How many outputs do I need?
Does anyone can help me what I shall choose and how I need to connect it to the soundlab? I don't really need to build in the converter but if it's possible to build the Midimplant into it I will do it so and than I guess I can save some audio jacks on the front.
On the front panel there are already three VCO LOG-CV In's so I guess I need to connect these with three Midi/CV-Converter-Outputs from a Doepfer that I can control all of these Oscillators?
I just want to control the tone high that coming out of the Soundlab via Keyboard (and maybe some mod wheel stuff). I don't know whats possible without completely modding the whole synth PCB. |
BÄDBUNNY
Posted: Sun Mar 11, 2018 11:50 pm Post subject:
[quote="elmegil"]I'm building an Ultimate + Expander + MIDI for someone right now.
My choice is to connect the CV and gate and trigger to:
1) the switch lug of the CVs (all 3 oscillators) in and gate and trigger in
2) bananas on a little aux panel, like the already existing aux panels for the Ultimate and Expander.
Also going to connect all the other values to the panel as well; plan to use the Kvitek MIDISizer, and in MONO mode I will have velocity, bend, cc1, start, and clock outputs, as well as LEDs for activity on MIDI and gate.[/quote]
Thanks for the reply! Can you send some updates during the building process? I'm right on soldering the whole stuff together!
I wanted to use a midimplant. Are there any differences between? Guess the Midsizer is a bit cheaper!
I just had the great Idea since I saw it on a SL Mini Mk2 build to make a three state switch and switch between internal Midi-Module, external midi-module and no CV. Guess that would be pretty nice 2 have.
How would you connect it to a soundlab ultimate without an expander? |
Posted: Mon Mar 12, 2018 5:35 am Post subject:
| BÄDBUNNY wrote: |
I'm not sure it's much cheaper after you pay for the components. It's just easier to mount, IMO. I have room and can do standoffs....
MIDISizer has a lot of options to it, like gate voltage levels, that are programmable with jumpers instead of sysex.
| BADBUNNY wrote: |
Similarly, using the switches on the input jacks. Switching isn't a bad idea, I'll have to think about that. |
BÄDBUNNY
Posted: Mon Mar 12, 2018 5:45 am Post subject:
[quote]Similarly, using the switches on the input jacks. Switching isn't a bad idea, I'll have to think about that. [/quote]
Yeah I guess I will also implement this. This is a good way to make it more suitable for different situations.
[quote]I'm not sure it's much cheaper after you pay for the components. It's just easier to mount, IMO. I have room and can do standoffs....
MIDISizer has a lot of options to it, like gate voltage levels, that are programmable with jumpers instead of sysex. [/quote]
Guess I'm gonna also go for it. Hopefully the custom service in Germany does not give that much attention
I will update this topic if I implemented the solutions. Maybe you can also do this  |
johnstilton
Posted: Tue Apr 23, 2019 11:00 am Post subject:
Appologies for bumping this older thread but is this the Midi - CV device that is you are using? Did the build go successfully? I am considering MIDI - CV options for my MFOS ultimate+expender build as well.
https://midisizer.com/midi2cv-mk2/
Can anyone post any pictures of the finished product incorporated into their panels?
Thank you. |
Posted: Tue Apr 23, 2019 11:47 am Post subject:
| I still haven't gotten mine wired :/ I don't plan to mount to the panel though, I have built a custom box for all of it, everything's going to be mounted in the bottom and then wired where it needs to go. |
BÄDBUNNY
Posted: Thu May 02, 2019 2:01 am Post subject:
Midimod Update |
So the project was laying around for some months. I just finished the Design and the MFOS Build will be nicer than every build you've seen.
In topic of the Midimod I built a Midi-CV Converter on my own with this instruction. I built a small PCB with an Arduino Nano mounted.
It's already done but not testet yet. I'm waiting for the Case to mount it all and the go on troubleshooting.
https://github.com/elkayem/midi2cv
Have a great day! |
