RhythmMaster 85
Page 1 of 1 [17 Posts]
Hammer
PostPosted: Sat May 26, 2018 4:56 am    Post subject:  RhythmMaster 85 Reply with quote  Mark this post and the followings unread
Hello!
This is RhythmMaster 85S (S mean simplified) device. It makes hi-hat and snare beats out of white noise generated by TL-431.
Full version have external clock source and bass drum generator with sidechaining feature. Still in progress.
1. When you will turn on this device, you will hear white noise with periodic scratches. If you do not hear the scratches, just wait until ATTiny85 will warm up or cold down.
2. Turn the knob, it will change beats.
3. Push the buttont once, it will change knob mode. In this mode turn the knob, it will change decay.
4. Push the button, hold it and turn the knob, it will change tempo.
Code: https://github.com/youcantignoremytechno/RhythmMaster_85S
RhythmMaster 85S
 Filesize:  248.08 KB
 Viewed:  879 Time(s)
RhythmMaster 85S circuit diagram
 Filesize:  91.07 KB
 Viewed:  981 Time(s)
Hammer
PostPosted: Sat May 26, 2018 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
To make it more interesting, play with envelope forms and noise timbre.
Examples:
rhythmmaster_85s_vinyl_noise.mp3
 Filesize:  94.68 KB
 Viewed:  1607 Time(s)
rhythmmaster_85s_beats.mp3
 Filesize:  388.99 KB
 Viewed:  1612 Time(s)
rhythmmaster_85s_tempo.mp3
 Filesize:  162.56 KB
 Viewed:  1628 Time(s)
rhythmmaster_85s_decay.mp3
 Filesize:  262.92 KB
 Viewed:  1588 Time(s)
StormB
PostPosted: Tue Jun 12, 2018 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Hammer,
wich Bootloader need 1 or 8 MHZ ?
and how much for the Sketch 16 MHZ?
Hammer
PostPosted: Tue Jun 12, 2018 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm always using 16mHz. In this project you don't need bootloader, because there are no USB port, only power from USB. Use another Arduino as programmer or use USBasp - the best.
StormB
PostPosted: Wed Jun 13, 2018 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Hidiho Hammer,
wich transistor is right 2x 3904 npn or 2x3906 pnp
in your schematic you have 1 x3904 and 1x3906
but the symbol is for 2 x3906
thanks
StormB
Hammer
PostPosted: Wed Jun 13, 2018 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for mistake! I've update circuit diagram.
Left - 2N3904 NPN, Right - 2N3906 PNP
Hammer
PostPosted: Sun Jul 01, 2018 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Syncronized with DIY CV/Gate converter and soviet RITM-2 synth: https://www.youtube.com/watch?v=3kAqZwofJxg
Still without tom, but it will be soon.
Hammer
PostPosted: Mon Jul 16, 2018 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I've used for tom/kick Wien bridge based oscillator. I'ts working great with 4069. Only sidechaining part of the main circuit still isn't ready.
But I started to make case out of e-bike controller box. Sides are laser cutted vinyl.
 Filesize:  6.51 KB
 Viewed:  22549 Time(s)
 Filesize:  667.16 KB
 Viewed:  816 Time(s)
 Filesize:  644.83 KB
 Viewed:  795 Time(s)
Hammer
PostPosted: Sun Jul 22, 2018 2:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Face deck
 Filesize:  764.06 KB
 Viewed:  779 Time(s)
phobos
Audio files: 728
PostPosted: Sun Jul 22, 2018 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
great idea with the lasercut vinyl Very Happy
sounds good too.
The Golden Shrimp Guild
Hammer
PostPosted: Sun Jul 22, 2018 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, PHOBoS!
A lot of interesting stuff could be cutted out of vinyl: https://www.instagram.com/youcantignoremytechno/
But it's not easy beacuse of releasing chlorine and condensating hydrochloric acid. CNC should be very good oiled, smoke should not stay in the room. Otherwise everything will be covered by rust.
Hammer
PostPosted: Mon Jul 23, 2018 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
All functions are here: hi-hat, snare, kick and compressor. It's noisy because I still hold some wires in hand. Now I can solder all parts together, and draw the circuit diagram.
rhythmmaster_85_sidechain.mp3
 Filesize:  563.37 KB
 Viewed:  1407 Time(s)
Hammer
PostPosted: Thu Jul 26, 2018 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Testing... New circuit and code will be here soon.
 Filesize:  883.83 KB
 Viewed:  597 Time(s)
Hammer
PostPosted: Sat Jul 28, 2018 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
New code: https://github.com/youcantignoremytechno/RhythmMaster_85
New circuit:
 Filesize:  194.44 KB
 Viewed:  750 Time(s)
Hammer
PostPosted: Sat Jul 28, 2018 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Action: https://www.youtube.com/watch?v=gjMpMup9Sd4
Hammer
PostPosted: Mon Aug 13, 2018 2:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I've made the 4069 VCA for BassMaster:
Posted Image
I think, that this is the way to shrinkify RhythmMaster!
Hammer
PostPosted: Fri Sep 07, 2018 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Random euclidean rhythms: https://www.instagram.com/p/BnbRhf3nOhH/
