Coming up on Radio 1 at
rip-of of the uneven part of Ken Stones wavemultiplier
Page 1 of 1 [6 Posts]
gabbagabi
PostPosted: Mon Oct 16, 2017 10:50 am    Post subject: rip-of of the uneven part of Ken Stones wavemultiplier
Subject description: sound sample added
hi,
i recently stumbled over the ken stones wavemultiplier.
The uneven harmonic part looked exactly like the circuits i like.
After simulation i did it directly on pcb and it worked well.
 Filesize:  47.78 KB
 Viewed:  778 Time(s)
 Filesize:  611.35 KB
 Viewed:  850 Time(s)
gabbagabi
PostPosted: Tue Jul 17, 2018 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
today i have this finally plugged in.
i really like what it does, with a vca in front that gently modulates the inputsignal
the pcb i did back then was an experiment to find out if the pcb could be the frontplate at the same time, the answer is - it could
i normalized the pcb today and will attach both
i included the mirror version - be shure wich one u use before etching
since it uses tl074 it dosent matter so much on the normalized pcb, but on the other the pot would work backwards
ueh_part.pdf
 Filename:  ueh_part.pdf
 Filesize:  1.04 MB
 Downloaded:  618 Time(s)
ueh.pdf
 Filename:  ueh.pdf
 Filesize:  1.02 MB
 Downloaded:  634 Time(s)
ueh parts small.pdf
 Filename:  ueh parts small.pdf
 Filesize:  1.11 MB
 Downloaded:  672 Time(s)
ueh small.pdf
 Filename:  ueh small.pdf
 Filesize:  1.09 MB
 Downloaded:  656 Time(s)
MapacheRaper
PostPosted: Tue Jul 17, 2018 4:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Another one for the TODOs folder. Cool!
The one of CGS is a ripoff of Haible so don´t be shy
I don´t understand why you need a VCA in the forefront thought. It´s to get some exponential conversion?. What happens if you feed it directly without the VCA?
gabbagabi
PostPosted: Tue Jul 17, 2018 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
well, its only that without the amplitude modulation done by the vca u will get a static signal, wich is kind of boring over the time.
hm if iam not mistaken KS took it from buchla? Anyway, i just mentioned KS cos of i saw it there first.
Attached a quickshot of the module, now as i see it i had some trouble with strange noise so i had to solder this 100nF close tho the power input, and also now i realize that i forgot the stabilisation caps on the opamps, pwnd myself,
so one have to solder in the caps directly on the solderside or has to do some unholy cap-leg-bending, my apologizes
 Filesize:  51.97 KB
 Viewed:  618 Time(s)
gabbagabi
PostPosted: Tue Jul 17, 2018 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
ive prepared a little soundexample of what ive played around with
the patch is a VCO (sin) modulated from a fast LFO
this signal goes then to a mixer and the VCA that drives the wavemultiplier
the VCA is slowly modulated of an other LFO
the output of the wavemultiplier goes then also to the mixer
the astetic of the soundsample is may not everyones taste, but its mine Smile
first u will hear the clean sound of the VCO,
then i switch on the reverb
then i mix in the multiplier
and go up with the pitch of the vco, increase the harmonics with the pot on the multplier
and pitch down
uneven.mp3
 Filesize:  2.17 MB
 Viewed:  1295 Time(s)
cygmu
PostPosted: Mon Jul 30, 2018 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Great!
This circuit has a special place in my heart -- it was the first thing I ever breadboarded, along with a simple trii-square oscillator, when I first got into this stuff.
This folder design originated with Serge I believe. Ken Stone explains on his web site that he was trying to reproduce the function of the Serge wave multipliers (middle section) when he came up with this circuit... and then to his surprise discovered that his solution was almost identical to the Serge schematic.
The Haible folder is a bit of a different beast. The Buchla one produces a similar effect in a very different way.
