Squelch without filter
Page 1 of 1 [13 Posts]
Wan
G2 patch files: 46
PostPosted: Fri Jun 10, 2005 5:53 am    Post subject: Squelch without filter Reply with quote  Mark this post and the followings unread
I experimented with the AD and DA converters, and stumbled upon a filter sweep like effect. Var 2 and 3 has the most pronounced one.
i didn't expect this. Anyone understands why it is squelching?
I think it can be a usefull effect
ConvWave.pch2
 Filename:  ConvWave.pch2
 Filesize:  1.49 KB
 Downloaded:  2522 Time(s)
Grtz Wan
Audio files: 266
PostPosted: Fri Jun 10, 2005 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know why it squelches either, but I love the sounds. Changing the divider settings is quite interesting. This is indeed surprising. I would have never thought of trying something like this. Smile
Axiom
G2 patch files: 28
PostPosted: Fri Jun 10, 2005 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice idea Smile I've done a little patch that scrumble a wave using AD/DA convertors. I've used Random Pattern Generators to scramble bits of both AD and DA.. its funny Smile
Luca
ADDA.pch2
 Filename:  ADDA.pch2
 Filesize:  2.79 KB
 Downloaded:  2402 Time(s)
Posted Image Posted Image
Audio files: 266
PostPosted: Fri Jun 10, 2005 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like this, but don't care for the repetition of the random patterns. Changes them to Random A modules and increased the rate a bit. This is great fun. The micorsounds people might like this. Smile
adda-b.pch2
Variation on a random ad-da patch.
 Filename:  adda-b.pch2
 Filesize:  2.72 KB
 Downloaded:  3723 Time(s)
Axiom
G2 patch files: 28
PostPosted: Fri Jun 10, 2005 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool Very Happy I'd play much with those converters. Nice ideas can be developed with those.
Luca
PostPosted: Fri Jun 10, 2005 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wan,
By doing the bit-selection the way you do inbetween the ADC and DAC, you're doubling certain bits, while throwing away others.
I made a simple graph using a spreadsheet, that is setup like most software compressors are- input on X-axis, output on Y-axis. To simplify, I only used 5 bits of adc/dac, but it easily makes the point here.
series 1 - linear (adc -> dac direct 1:1 connection)
series 2 - highest bit is used in place of highest & second highest bit.
series 3 - middle bit (bit 3 here) is used in place of bit 2 also.
series 4 - bit 5 (highest bit) replaces bit 5 and 4, bit 3 replaces bit 3 and 2 (somewhat combined series 2 & 3 ).
I use this method to create various look-up tables (that are larger than the 16 length (4 bit) sequencer/table that is available as a module. But I like the oddity you've come up with.
As for squeltching, it would depend on the divider/bit selection, and the frequency content of the input signal. In essence, (refer to the picture), a repeating wave (ie-frequency) would be jumbled up, in a repeating way. So in essence, you are moving the energy in certain frequencies to other frequencies. It'd probably be a good exercise to look at the "RAW" waveform and "DIST" waveforms through a FFT analyzer on your PC.
example graph of "squeltch without filter".
 Filesize:  45.18 KB
 Viewed:  36489 Time(s)
Wan
G2 patch files: 46
PostPosted: Sat Jun 11, 2005 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for this explanation, it is still a bit over my head, but the transfer of energy from frequencies to other frequencies is something that makes it a bit easier to grasp. I shall try to take a look at FFT analyses.
Grtz Wan
Wan
G2 patch files: 46
PostPosted: Sat Jun 11, 2005 8:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the basics of the squelch behaviour is in the swapping of the bits. In this patch all the bits are swapped and now it has a sync like character. But a very powerfull type of sync, much more pronounced than the normal sync input.
Var 5 is nearly chaotic, if you raise the leven of the ad further it is getting noisy [knob a:1:8].
adda sync.pch2
 Filename:  adda sync.pch2
 Filesize:  2.02 KB
 Downloaded:  2301 Time(s)
Grtz Wan
Wan
G2 patch files: 46
PostPosted: Sat Jun 11, 2005 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Luca
Sure, yours and Howards ideas are nice and promising. There are things happening in the patterns that catch my ear. I am going to delve further in this waveshaping with adda.
Grtz Wan
Wan
G2 patch files: 46
PostPosted: Sun Jun 12, 2005 5:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Another expirimental patch with ADDA.
I've made a matrix so you can set wich input bit will go to wich output bit [page b1]. So now you can explore what is the behaviour of the different mappings. And then the idea popped up to divide the different bits to see what that would bring [page b2]. Well, it introduces all kinds of harmonic series Shocked . Variation 7 and 8 are examples of that.
Added an input filter for the ADDA too, and that also has a great effect on the produced sounds.
I've made a quick setup for all variations to touch on a few ideas, but there is definitly more here.
Hope you enjoy!
Adda bitmatrix.pch2
ADDA waveshaping with bitmatrix and bit dividers
 Filename:  Adda bitmatrix.pch2
 Filesize:  2.98 KB
 Downloaded:  2247 Time(s)
Grtz Wan
Axiom
G2 patch files: 28
PostPosted: Sun Jun 12, 2005 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
lol i can't believe it Very Happy i'm been working to the same thing this morning Smile I will load your patch soon into my G2.
Luca
Audio files: 266
PostPosted: Sun Jun 12, 2005 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
These sounds have a renaisance quality to them. Brings to mind a Christmas carole.
merry-gents.mp3
O Come Ye Merry Gentlemen
Who know why...
 Filesize:  315.39 KB
 Duration: 0:27
 Viewed:  3368 Time(s)
Wan
G2 patch files: 46
PostPosted: Sun Jun 12, 2005 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
dancing
I know the tune, but i never expected this sound relates to it. Now where is that score of jingle bells?
Grtz Wan
