Coming up on Radio 1 at
sh101 Subosc help please
Page 1 of 1 [17 Posts]
isak
PostPosted: Tue Jun 04, 2013 11:13 pm    Post subject: sh101 Subosc help please Reply with quote  Mark this post and the followings unread
Hi guys.
i really need some help to understand why the hell -2 is not working.
i'm using the ody VCO saw as my source for the subosc.
i design a pcb for this and -1 is working great only -2 and -2 pulse is not working.
i actually dont care about -2 pulse, i only want the -2 to work.
i modded the original scheme a bit cause it wont work with the resistors values it haves, its a small change, pics uploaded...
this is the original scheme...
Posted Image
this is the moded scheme...(the changes are marked with red round)
Posted Image
this is my pcb design...(already etched)
Posted Image
please tell me if my design is not good, and if its good why -2 is not working?
Isak E.
mrmrshoes
PostPosted: Wed Jun 05, 2013 3:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I think your layout is good.
but i can see one problem. Going from your component placement layout the 2n3904 pinout looks wrong.
You've got the emitter going to pin 3 and the collector to GND.
i would also use 220k to the base. or the closest value you have to it.
hope you find the problem
mrmrshoes
isak
PostPosted: Wed Jun 05, 2013 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you for your reply.
yes, your absolutely right!, how i missed that? Embarassed
i hope it will fix the problem, thank you very much.
i'll update soon.
isak
PostPosted: Wed Jun 05, 2013 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, ive fixed the transistor pins.
still no change, i dont get -2.
i put 220k pot instead and tried to play with the pot, up and down, still the same.
no -2
Confused
isak
PostPosted: Wed Jun 05, 2013 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
i have found the "problem"!
i was thinking to my self that this circuit is published and must work, i checked and replaced everything except the 68k, i puled it out and put a 100k pot instead, dial the pot up and down hoping to get something and i did Cool
after that i turned off power supply and measure the pot value, it was 6.5k, so i put 6.5k resistor instead 68k and thats it Smile
sound freaking amazing!
love it.
some sound sample (no keyboards just sound)
saw-squ and sub -1 and -2 amazing.wav
 Filesize:  7 MB
 Viewed:  1939 Time(s)
defog
PostPosted: Wed Jun 05, 2013 6:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi there,
I built both the SH-101 4013 based sub oscillator and a 4024 sub oscillator on a breadboard and found they sounded identical, and implementing a 4024 requires nothing but the chip, a cap, and selector switch. The 4024 also gives you options of much lower octaves that can be used as a repeat gate. I've added sub-oscillators to my soundlab ultimate and my own diy synth this way, they're quick and dirty square wave generators. If you have a 4024 laying around, I'd suggest bread boarding one up.
The Phoenix Vertigo is my Electronic alias. Check out my songs on soundcloud : http://soundcloud.com/charles-stieg/
isak
PostPosted: Wed Jun 05, 2013 8:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
You have a scheme of the 4024 subosc or how to connect guide?
defog
PostPosted: Thu Jun 06, 2013 6:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Posted Image
Pretty straight forward. Just put a 10nf cap between pin 14 and gnd. And the reset pin needs to be grounded. Nothing else to it.
isak
PostPosted: Thu Jun 06, 2013 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I must try this simple thing.
You sure it's sounds the same as the 101 sub?
tokyomatik
Audio files: 6
PostPosted: Tue Jul 23, 2013 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
really interested in trying this little circuit...at the moment i don't have any 1n914 but im full with 1n4148s...it will work anyway???
isak
PostPosted: Tue Jul 23, 2013 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes it will.
Please note that the 2n3904 is reversed in the parts placement, reverse it.
Another thing..
I advice you to put a trimmer instead of R24 (68k), trim it till you get the -2 to work.
Works like a charm Smile
Cheers and good luck.
wackelpeter
Audio files: 10
PostPosted: Mon Jan 25, 2016 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
taking all the Input from this thread i'd had a go on my own Version of an Suboscillator... using the CD4024 and the Input circuitry of the SH101 Subosc...
It can be fed by any waveform reaching at least +/-5V... as my Thomas Henry 555 VCOs do...
Feeding in 5V/gnd Signals.. cause Offset voltages...
on link below there's a sample using the suboscillator...
well it's not a solo demonstration of it as i abused the VCO with syncing and as always heavily used the Yusynth VC Panner (Is life possible without that VC Panner?) I'm heavily obsessed by that sounds Floating from left to right...
Well you can hear only one VCO and the SubOsc Output which is synced to an 2nd VCO
2 Thomas Henry 555 EG's involved... one for feding the VCA the 2nd sometimes modulating the master VCO...
no filtering after that, VCO and Subosc. going straight into VCA then into the panner followed by delay and caught onto tape...
https://soundcloud.com/bastian-j/track0131
TRACK0131.mp3
Sub Oscillator test
 Filesize:  3.34 MB
 Viewed:  1635 Time(s)
Ray_Ketamu
PostPosted: Wed Feb 17, 2016 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
could i implemennt this scematics in eurorack without changes or do i need to change values?
4024 seems fine without changes but the original 101?
Sound: https://soundcloud.com/stream Art: http://ketamuworld.blogspot.de/
isak
PostPosted: Wed Feb 17, 2016 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ray.
Use the board and info from this link Smile
http://electro-music.com/forum/topic-58533.html
Isak.
Ray_Ketamu
PostPosted: Wed Feb 17, 2016 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah. that was quick Smile thanks. did you try the 18k resistor to ground aproach for square out? didn´t find it in the pcb design. oh and you forgot to change the 15V to the 12V of euro... but very nice indeed. will pair it with two th-555, barton waveanimator and a ringmod Very Happy finally its DIY again!
Ray_Ketamu
PostPosted: Wed Feb 17, 2016 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
oooh... and shouldn´t there be an -12V connection too?
isak
PostPosted: Thu Feb 18, 2016 2:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I didn't try the 18k to ground but it's easy to implant.
Didn't checked with 12V.
And no, there is no need to -12V Smile
