WaveWiper 2.0 (improved version)
Page 2 of 2 [48 Posts]
Goto page: Previous 1, 2
phobos
Audio files: 728
PostPosted: Fri Jan 22, 2016 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I already sold a couple and there are some other others who showed interest so I am giving them a chance to get some first.
But if there are any boards left you're next on the list. There will probably be another run though. And yes I do want to make
panels, I need them myself anyway. I ordered some transfer paper from china to see if I can get good results with the
toner transfer method (will take a couple of weeks before that arrives). Another option would be using PCB material but
eagle lite doesn't support the panel size. So I have to find something else to design that with and figure out how to import an
image exactly to scale (I did make a design).
As for what it does have a look at the manual Cool
The Golden Shrimp Guild
Ayab
PostPosted: Fri Jan 22, 2016 10:07 am    Post subject: Wavewiper PCB Reply with quote  Mark this post and the followings unread
Hi Phobos
Have been quietly following this thread and it is good to see your idea come to fruition. Lovely design.
I'm up for a pair of boards too - how much are they? Feel free to pm me your email and will paypal you and give you my address.
All the best
Audio files: 163
PostPosted: Fri Jan 22, 2016 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi There Smile
Phobos helped me out when I had a wee anomaly on the breadboarded V2.1 circuit , thanks again .
I had an idea for something using the wave wiper and done some tests to see what happens when running 2 wave wipers in series and also to see what it sounded like with FX / filters / wave folder / 5pulser etc between the wipers almost like a send & return loop , the results were that pleasing I have decided to build a 4 wave wiper module Smile Smile Smile Smile .
I was initially thinking of having 4 fully modular wipers , and changed my mind to have 2 fully modular ones with a slave wiper under each with an added cross over switch to swap over output 1B and output 2A , which will be wired through, going into input 3B and input 4A, also a couple of veroboard simple LFO's
The diagram below is showing the inputs and outputs & how the cross over switch operates in the middle and the lfo destinations.
The bottom file is version 4 of trying a few hardware layouts ( to be turned skrog blue once im ready for ordering a panel sticker) .
 Filesize:  84.3 KB
 Viewed:  822 Time(s)
 Filesize:  757.9 KB
 Viewed:  779 Time(s)
Audio files: 163
PostPosted: Sat Jan 23, 2016 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds Smile
I recorded some of the tests I wanted to try with my breadboarded wave wiper (s), here are some mp3s & descriptions of set ups .......
1 wave wipe saw & squ in +lfo.mp3
one wave wipe with a vco square to in 1A and separate vco saw into in 1B , I am swinging the wipe set pot to start with then turn up the cv input which has a Mfos LFO patched up.
 Filesize:  2.26 MB
 Viewed:  2007 Time(s)
2 wipes in series seperate lfo's to each.mp3
2 wave wipes in series with a separate LFO into each cv input , again turning the wipe set pot and adjusting speeds of the lfo's , same inputs as before but changed the pitch of one VCO.
 Filesize:  2.76 MB
 Viewed:  2003 Time(s)
2 wipes series with Mfos wave freaker inseterd between.mp3
2 wipers in series this time with a Mfos wave freaker patched as an insert FX between output 1A and slave wiper 1A input , the wave freaker has a frequency divider & fold/ shape type actions , adjusting lfo speeds & amounts & wipe set adjustme
 Filesize:  1.86 MB
 Viewed:  1996 Time(s)
2 wipes series with 5Pulser inserted beteween them.mp3
2 wipers in series with a ian fritz 5pulser inserted between first wiper out 1A and slave wiper in 1A I use a slow lfo to hear the stepping sounds and adjusted the speed for lfo 2.
 Filesize:  3.65 MB
 Viewed:  1982 Time(s)
2 wipes series with delay FX between them.mp3
this one I tried a delay FX between the wipers ,a dual sequencer is now playing the 2 VCOs , turning the delay time up & down, and adjusting the lfo speeds ..... at the very end of this file it sounds like a modular Status Quo riff , hehe , new terri
 Filesize:  4.8 MB
 Viewed:  2046 Time(s)
piedwagtail
PostPosted: Sat Jan 23, 2016 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the samples.
I was wondering what it sounded like with harmonics of the same wave in both inputs, the 5-pulser gets in that area.
and
that Glaswegian drunken slur at the beginning of the last one is a good indication of the possibilities!
R
phobos
Audio files: 728
PostPosted: Sat Jan 23, 2016 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Razz thanks for the demos Dave.
nice to hear some skrog wiping action. Especially those last 2 are pretty nuts.
Audio files: 163
PostPosted: Sat Jan 23, 2016 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Smile Smile thanks , I am really looking forward to building the Quad one .
phobos
Audio files: 728
PostPosted: Sat Jan 23, 2016 1:20 pm    Post subject: Re: Wavewiper PCB Reply with quote  Mark this post and the followings unread
If there are any boards left you are next on the list.
Ayab
PostPosted: Sun Jan 24, 2016 4:13 am    Post subject: Wave wiper Reply with quote  Mark this post and the followings unread
Hi Phobos
Thank you will look forward to hearing if you have any spare
Audio files: 163
PostPosted: Sat Jan 30, 2016 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Smile
Boards arrived early in the week , thanks Phobos , snapped off the top boards & got to work soldering the diodes / resistors / ic sockets / caps etc onto the 4 main pcbs .
Also finished the final layout on the panel (100mm x 250mm) , legends converted to blue and was thinking about the lfo's controlling a series wave wiper stack each , both stacks lfo amount into 1&3 / 2&4 would be swept the same direction , so I squeezed in 2 extra switches , one inverts the respective lfo1 / lfo2 into the slave wipers only, and the other switch will swap lfo 1 & 2 over (lfo2 to wiper 3 , lfo1 to wiper 4)
Hope to get the final sticker design ordered through next week sometime.
 Filesize:  480.27 KB
 Viewed:  749 Time(s)
 Filesize:  598.38 KB
 Viewed:  720 Time(s)
phobos
Audio files: 728
PostPosted: Sat Jan 30, 2016 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
looks promising dave Very Happy
bigsmurf smurfin
smurf brilsmurf
Audio files: 163
PostPosted: Sun Feb 14, 2016 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all , I was bedridden with a nasty flu bug most of last week , managed to do a bit of construction on the W4ve wiper Friday evening & yesterday.
Panel drilled & sockets, pots , switches fitted to faceplate now , 4 boards plus add on veroboard circuit with the 2 LFO's is attached .
wiring to pots & jacks all done, now ready to test & record some demo sounds later tonight....
 Filesize:  848.25 KB
 Viewed:  763 Time(s)
 Filesize:  545.07 KB
 Viewed:  760 Time(s)
 Filesize:  582.88 KB
 Viewed:  735 Time(s)
Audio files: 163
PostPosted: Sun Feb 14, 2016 4:18 am    Post subject: Reply with quote  Mark this post and the followings unread
View from the front ...........
 Filesize:  547.69 KB
 Viewed:  697 Time(s)
phobos
Audio files: 728
PostPosted: Sun Feb 14, 2016 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
That looks great Dave! can't wait to hear it. too much coffee
and nice solution with the bracket sandwich.
Audio files: 163
PostPosted: Sun Feb 14, 2016 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
More sounds Smile
First mp3 is 2 vcos sync'd together with square from 1vco and saw from 2nd vco going into wiper 1 & wiper 3 (left hand series stack) . A sequencer bass line runs the vcos and various combinations of internal & external lfo's / sequencer cv was tried on the cv inputs.
Second mp3 is a droney track , fed a differently modulated vco to each wiper (drums plugged into wiper 4), adjusting cv inputs & lfo speeds and wipe set positions.
wipers with 2 vcos in sync.mp3
 Filesize:  3.65 MB
 Viewed:  1980 Time(s)
W4VE drones.mp3
 Filesize:  9.51 MB
 Viewed:  2013 Time(s)
piedwagtail
PostPosted: Sun Feb 14, 2016 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Find it hard to discern what's happening without an oscilloscope Confused Smile
Like the soundworld of the second one, had me immediately reaching for this:
https://www.youtube.com/watch?v=YvlQ8TQsmQA
which is watchable in its entirety as Welt am Draht.
R
Former site admin
Audio files: 353
PostPosted: Sun Feb 14, 2016 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just watched part one - it has some interesting music!
phobos
Audio files: 728
PostPosted: Mon Feb 15, 2016 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
nice demos Dave I especially like the W4VE drones. Very Happy
and Welt am Draht is a great movie
Audio files: 163
PostPosted: Mon Feb 15, 2016 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
R
Hullo Smile
On the first set of demos , I had the outputs connected direct to a stereo channel on my mixer , with headphones it was easy to hear the sound sources being flung side to side with different modulations.
The mp3 "2 vco's in sync" , I used the W4ve wiper in a typical mono bass line patch up ...vcos / wipers / vca / mixer , it is acting as a type of bass line fattener almost like using something like Ken Stone wave folders to spice up a "plain Jane" synth line.
When patching up lots of wipers in series , I found just using a single output from the end of line wiper worked really well , when patching the 2 outputs of a full series chain of wipers to the built in 4 ch. mixer of my vca ( no panning) there was occasional cancellation and also distortion depending on where the wipe dials were set , but that is understandable with both outputs into a single vca.
Loving the twisting sounds this makes , perfectly suited for my Epicyclus & Orchard music Smile Smile
Audio files: 163
PostPosted: Mon Feb 15, 2016 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Phobos Smile
Audio files: 163
PostPosted: Mon Feb 15, 2016 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
R
Thanks Smile , wow that does look a good film , I will have to check it out when I get time some weekend .
One film I saw a few months ago was really good , The Parallax view (1974)
madtextureenvy
PostPosted: Wed Jun 08, 2016 11:12 pm    Post subject: What just happened?! Reply with quote  Mark this post and the followings unread
I think i just bought a WW2.1...
I was just reading up on some newish posts and reexamining your Simple Sampler(I have a YAKBAK that has been in my project drawer for 2 years now) not but minutes ago...
Then there is this blank spot in my memory... and suddenly I am staring at a PayPal confirmation...
Mwuhuhahahaha! Twisted Evil
phobos
Audio files: 728
PostPosted: Fri Jun 10, 2016 2:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I received your order and it will be shipped out today. Thank you! I hope you have fun with it. Very Happy
edit: it looks like I didn't post a link here to the other thread where I am selling the boards,
but they are available at the Stickney Synthyards Shop.
