radfaraf
Posted: Tue May 24, 2005 8:16 pm Post subject:
Yay I got sound but the sounds seem to trigger themselves. |
I got mine constructed enough for sound finally.
When I turn on my mini-synth I get the sounds triggered every few seconds. I will get a sound that lasts a few seconds, stops and then a few seconds later a sound again. Seems to be triggering without me connecting the two wires I have for trigger (they aren't wired to a button yet). Could having the repeat feature on cause this? I tried having it both on and off, doesn't appear to change anything. The sound seems to keep coming back forever without any action on my part. |
lanxe
Joined: Feb 24, 2005 Posts: 102 Location: Columbus, OH - Now Carson City NV
Posted: Thu May 26, 2005 7:19 pm Post subject:
check that you didnt jump any traces on the pcb.........if you short out anything on the bottom you might get some crazy reactions.
i have made a few mistakes with the wiring before and while the sound lab still makes sounds it is definitely not functioning as designed. after finding my faults (just wires going to the wrong place), the synth worked great.
Hope this helps. just check and check again!
Ryan |
Audio files: 19
Posted: Fri May 27, 2005 4:22 am Post subject:
| lanxe wrote: | check that you didnt jump any traces on the pcb.........if you short out anything on the bottom you might get some crazy reactions.
Circuit bending anyone? _________________ ACHTUNG!
radfaraf
Posted: Fri May 27, 2005 9:16 pm Post subject:
| v-un-v wrote: | | lanxe wrote: | check that you didn't jump any traces on the pcb.........if you short out anything on the bottom you might get some crazy reactions.
Circuit bending anyone? |
Yeah but we don't want accidental circuit bending. I think I'm going to rewire this, I used really poor wires that are 22 gauge and one strand of copper only. They are super unflexible so I can't even try to work with it to figure something out. Need to get more flexible wires first. |
Joined: Jan 31, 2003 Posts: 18522 Location: Durham, NC
Audio files: 266
Posted: Sat May 28, 2005 9:22 am Post subject:
Good idea to replace the solid copper wires. Even when they make good connections they are dangerous because they can break, sometimes inside the insolation. When this happens, it's really hard to identify the problem because everything looks right. _________________ --Howard
my music and other stuff |
lanxe
Posted: Sat May 28, 2005 9:36 am Post subject:
| mosc wrote: | | Good idea to replace the solid copper wires. Even when they make good connections they are dangerous because they can break, sometimes inside the insolation. When this happens, it's really hard to identify the problem because everything looks right. |
yep,
i learned that the hard way.......the first minisynth i put together in a super tight box i used solid core wire......it was pretty flexible but i was still having problems with it. |
Audio files: 266
Posted: Sat May 28, 2005 10:07 am Post subject:
Hee hee... I learned that one the hard way too...  _________________ --Howard
radfaraf
Former site admin
Audio files: 353
Posted: Sun May 29, 2005 3:18 pm Post subject:
UL recognized, interesting question I thought and so I typed it into Google which resulted in about half a milion hits. http://database.ul.com/grcinterfro_00-1-frnt.pdf , one the links popping up explains it all, well almost.
Jan. |
Audio files: 266
Posted: Sun May 29, 2005 5:43 pm Post subject:
UL stands for Underwriters Laboratory, an industrial research lab run by the insurance industry. It sets safety standards for many electrical components. In the USA, you can't get insurance if your house hasn't been built according to the building code (local building laws). Most codes require UL approved wires, sockets, switches, etc. _________________ --Howard
