PCB for the EFM VC-RADSR
Page 1 of 1 [11 Posts]
jbeuckm
Audio files: 9
PostPosted: Thu Mar 19, 2015 6:09 pm    Post subject: PCB for the EFM VC-RADSR Reply with quote  Mark this post and the followings unread
I'm going after the EFM VC-RADSR mentioned here:
http://electro-music.com/forum/post-224210.html#224210
schematic: http://www.modular.fonik.de/files/EFMforum/orgEFMfiles/vcradsr.pdf
I've got a euro-friendly layout pretty close, and I will make a prototype soon. Anyone see any problems with this capture of the schematic? I added the supply decoupling capacitors -- the CMOS are at middle left and opamps are on the bottom left. I did not put in the offset amplifier from the original.
EFM VC-RADSR
 Filesize:  92.59 KB
 Viewed:  1103 Time(s)
jbeuckm
Audio files: 9
PostPosted: Fri Mar 20, 2015 6:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
That first schematic missed a 10k resistor between Q1 and the OTA. Here is my prototype - will try one soon.
Eagle stuff here: https://github.com/jbeuckm/EFM_VC_RADSR/tree/master/eagle
 Filesize:  116.79 KB
 Viewed:  728 Time(s)
roglok
PostPosted: Sat Mar 21, 2015 4:38 am    Post subject: Reply with quote  Mark this post and the followings unread
looks great. haven't come across this one yet. the rate parameter seems super useful. please keep us posted!
if you decide to do a PCB run it would be cool if you included mounting holes.
glot
PostPosted: Sat Mar 21, 2015 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
that really does look great Cool
would you add a footprint for the lm13700 the ca3080 is only getting more rare and expensive
roglok
PostPosted: Sat Mar 21, 2015 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
one thing: why did you leave out the attenuverter? all you need to do is add 2 extra resistors and a pot somewhere... you could make it optional, just the pads for flying wire installation... there's a spare opamp anyway...
btw. are you joe beuckman of beige records fame?
jbeuckm
Audio files: 9
PostPosted: Sat Mar 21, 2015 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
@roglok I'll probably add the offset amp back if this works. I usually try to mount on the 16mm right angle pots. Is there a particular way you would do the mounting holes? No production run but my work in Eagle will be open if someone wanted to.
@glot I'll look into that lm13x00 substitution.
Anyone in MSP have an extra 4052? Wink
joe@beigerecords.com
VC-RADSR prototype in progress
 Filesize:  96.64 KB
 Viewed:  691 Time(s)
jbeuckm
Audio files: 9
PostPosted: Mon Mar 23, 2015 8:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Everything seems to work. Here is a sample playing with rate, attack and decay in LFO mode. I wish the release could be adjusted longer relative to the attack. To get the release very long at all, the rate has to be drawn out so that the attack is soft. Since it's voltage controlled, I guess I could use a separate EG to change the rate parameter during the release... VC opens up a lot of coolness.
The output is a little less than +5V at +/-12V supply. Offset amp will be nice. If the 3080 gets replaced with a 13700, there will be an extra OTA sitting there. I was thinking of trying to fit a simple VCA onto this board.
vceg_lfo_mode.mp3
 Filesize:  626.05 KB
 Duration: 0:32
 Viewed:  1749 Time(s)
roglok
PostPosted: Tue Mar 24, 2015 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
cool. good to hear you got it working.
regarding the gain stage and envelope times, maybe this is of interest to you (in case you haven't seen it):
http://synthdiy.fonitronik.de/files/7413/8288/0912/VC-RADSR_forum.pdf
http://www.modular.fonik.de/files/EFMforum/vc-radsr%20ScottBmod.pdf
you could make C1 switchable to get different overall envelope times.
jbeuckm
Audio files: 9
PostPosted: Tue Mar 24, 2015 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
@roglok Thanks - that's really good info! I will try some of the many mods and possibly JH's discrete VCEG.
jbeuckm
Audio files: 9
PostPosted: Fri Mar 27, 2015 9:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is an update with LM13700 instead of CA3080, offset amp from the original and an indicator LED with transistor driver. Let me know if you see any problems before I make one tomorrow.
 Filesize:  83.94 KB
 Viewed:  780 Time(s)
jbeuckm
Audio files: 9
PostPosted: Sun Mar 29, 2015 6:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
It works. Here is the layout. Eagle stuff available here:
 Filesize:  126.38 KB
 Viewed:  649 Time(s)
