Help with proxy needed
Page 1 of 1 [10 Posts]
Audio files: 266
PostPosted: Thu Sep 04, 2014 7:31 pm    Post subject: Help with proxy needed Reply with quote  Mark this post and the followings unread
I'm at the Greenkill center and I can't get our through their firewall. Is there are proxy that I can use to connect to srv4.electro-music.com:8071
phobos
Audio files: 728
PostPosted: Fri Sep 05, 2014 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
is this helpful ? http://www.electro-music.com/forum/topic-62520.html
The Golden Shrimp Guild
Former site admin
Audio files: 353
PostPosted: Fri Sep 05, 2014 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm ... we need the inverted situation here ... they want to stream out ... so that would need to be on a different IP than the main server in order to be able to use port 80 .. and then it should relay to the real relay ... maybe .. as we have a couple of IP addresses on our servers we could use one of those and then configure apache properly for that? Not sure if that is possible ... and of course we need it like NOW Confused
Audio files: 266
PostPosted: Fri Sep 05, 2014 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't even get on the chat - seems to be blocked as well. Will use this method to communicated.
Audio files: 266
PostPosted: Fri Sep 05, 2014 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Is Paul around?
Audio files: 266
PostPosted: Fri Sep 05, 2014 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
The IT desk said it will be about 2 hours from now. I'm going out to buy some drinks and snack food.
Former site admin
Audio files: 353
PostPosted: Fri Sep 05, 2014 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Paul, nope, he had this wedding .. prolly busy .. I''ll direct him to here when I see him.
Audio files: 266
PostPosted: Fri Sep 05, 2014 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got the stream working but not the chat. The guy punched a hole for irc.othomann.de, but no luck. Any ideas?
Former site admin
Audio files: 353
PostPosted: Fri Sep 05, 2014 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
When you use mibbit you need a hole for the mibbit servers .. or else use a chat client to connect directly .. you can install chatzilla for instance into firefox and then go to irc://irc.othomann.de/electro
Audio files: 266
PostPosted: Fri Sep 05, 2014 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
will try chatzilla soon. Gotta play banjo with dale now
