Coming up on Radio 1 at
VCF-1 PCB layout anyone?
Page 1 of 1 [19 Posts]
roborobert
PostPosted: Wed Jun 12, 2013 6:44 am    Post subject: VCF-1 PCB layout anyone? Reply with quote  Mark this post and the followings unread
hey there,
i'm just getting modules together for a small modular. Thomas Henry's VCF-1 is one of the filters i'd like to build, so i was searching for a pcb layout & couldn't find any...
is that possible? Wink
no problem rolling my own, but i'd rather build and evaluate sth that's already there...
many thanks (in advance and retrospect to this forum),
best, rob
roborobert
PostPosted: Sun Jun 16, 2013 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
hmmm...
so, also nobody is interested in a pcb layout ?
i did one in the meantime and I'm not sure if it's ok to post it here.
or maybe i should go over to the layout factory? don't know.
anyway, much love,
rob
dark000arena
PostPosted: Sun Jun 16, 2013 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Robo,
God yes!. of course we want to see your VCF1 layout. I got this design onto a credit card sized piece of stripboard. so cool to see another persons parts placement decisions tho. This is a classic filter and quite steiner like.
roborobert
PostPosted: Sun Jun 16, 2013 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Smile
ok, so here's the stuff.
it's one of my first *proper* pcbs ...
it's unbuilt and untested. and it'll be a month from now until i really get to this. i crammed the stuff a bit inone corner so that the layout fits the usual 100mm of pcb material.
i double checked it, so everything should be ok.
i quite convinced that it'll work properly.
would be glad if someone could do the triple check, though...
ah - it's designed for discrete matched transistors.
as far as i searched the web, i couldn't find anyone doing or selling pcbs for this, so i guess it's appreciated to post this.
hope it's useful to somebody else.
best,
rob
TH VCF-1 parts place bw.pdf
 Filename:  TH VCF-1 parts place bw.pdf
 Filesize:  151.99 KB
 Downloaded:  979 Time(s)
TH VCF-1 bottom copper.pdf
 Filename:  TH VCF-1 bottom copper.pdf
 Filesize:  26.17 KB
 Downloaded:  882 Time(s)
th - vcf1.zip
the zip contains pcb and parts placement + the expresspcb file for customization (like changing the discrete transistor version to IC version) if someone likes to...
 Filename:  th - vcf1.zip
 Filesize:  204.57 KB
 Downloaded:  833 Time(s)
dark000arena
PostPosted: Wed Jun 19, 2013 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
fantastic contribution robo. Gorgeous, elegant layout and its a Thomas Henry design. Everyone should etch this. Can I ask, what software did you use to do your layout. I am heavily into Ki-cad myself.
Nardu
PostPosted: Wed Jun 19, 2013 9:51 pm    Post subject: Thomas Henry VCF-1 layout on Stripboard Reply with quote  Mark this post and the followings unread
Hello !
Here : http://electro-music.com/forum/post-385955.html#385955 , a version of Thomas Henry VCF-1 layout on Stripboard !
roborobert
PostPosted: Thu Jun 20, 2013 3:52 am    Post subject: Reply with quote  Mark this post and the followings unread
hey,
Very Happy thanks for your kind words, dark000arena !
i did the layout in expresspcb. it's freeware and i'd say it's only real downside is that you can't export gerber files - which is a big one but doesn't matter for me since i etch pcb's on my own.
When i was searching for free pcb-layout-editors this was the one i felt really comfortable with. very nice workflow and intuitive handling.
i attached the .pcb (expresspcb) file in the .zip folder, so one can make changes to the layout if one needs to.
Thanks also for the link to the stripboard layout, nardu!
i always preferred perfboards and never felt comfortable with strip boards.
(i guess it's a what you grew up with thing Wink )
but surely it's really good to have the link here. Also because of the LM13700 version!
Do you know if it sounds/behaves different to the CA3080 version?
best wishes, rob
paulstone
PostPosted: Wed Jul 31, 2013 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
roborobert wrote:
hey,
best wishes, rob
Hi rob
have you already build the filter with your pcb layout , will work ?
thx !
roborobert
PostPosted: Sun Aug 04, 2013 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey paulstone,
sorry for late reply, just came back from holidays Cool
due to that, i still haven't built it. but it's one of those projects next in line, especially with forum motivation Very Happy
yet, it's still too early for announcing a date or timeframe...
i'll post more when i get there.
best, r
paulstone
PostPosted: Mon Aug 05, 2013 1:06 am    Post subject: Reply with quote  Mark this post and the followings unread
roborobert wrote:
hey paulstone,
best, r
hi rob thanks
i really want build the VCF-1 , unfortunately i'm not expert in electronic cad and pcb layout so any help is much apprecciate Smile
ciao
PostPosted: Mon Aug 05, 2013 8:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
It might be simpler to use the stripboard layout from here then:
http://electro-music.com/forum/topic-58498.html
paulstone
PostPosted: Tue Aug 06, 2013 12:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
i have try the adventure to build this stripboard , i realize that there is two time R5 resistor in the layout , and in the first power is burn the fuse -12V of my powersupply . i have chek 2 time the solders and jump seems all ok
boo Smile
Nardu
PostPosted: Tue Aug 06, 2013 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
paulstone wrote:
.... i realize that there is two time R5 resistor in the layout
I have corected the - R5 resistor duplicate fault ! , ( thanks again to @Jaba for his revision ).
- Bellow, the route of [+ / -] 15V power:
TH VCF-1 2SA798 R2 [+15v-15v], power route
 Filesize:  406.17 KB
 Viewed:  645 Time(s)
http://nardusynth.blogspot.ro/
paulstone
PostPosted: Tue Aug 06, 2013 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Nardu
i will chek again the connections Smile
roborobert
PostPosted: Sun Oct 13, 2013 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey again,
i wanted to confirm that the layout i posted is working. nicely Smile
although the self resonance is quite harsh and dirty, not sure if this is the way it should be. i like it anyways.
no possibility for pics and sounds yet. these will follow.
best, rob
roglok
PostPosted: Wed Oct 16, 2013 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
roborobert wrote:
hey again,
best, rob
good to hear it's working.
one thing i noticed on your layout is that the tempco is not mounted in thermal contact with transistor pair Q1/Q2. of course this has nothing to do with the resonance behaviour... regarding the sound - maybe you are overdriving the filter? what happens when you attenuate the input signal?
roborobert
PostPosted: Wed Oct 16, 2013 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
hey roglok, thanks for your interest!
yeah... the tempco/transistor-pair position was a strange compromise.
i wanted to limit the size of the pcb in such a manner that one could fit three of them on a standard euro pcb (160mmx100mm) and i found no way manage to do it otherwise without starting from point one again.
anyway - it's totally possible to mount the tempco in contact and extend the wires to the other side of the op-amp, so i thought it's ok.
about the resonance issue - i'm talking only about self resonance - which occurs no matter if an input signal is present or not, so that's not the reason. i'm quite sure it's just the way it is.
i'll try to record a sound sample and post it here within the next week - it's way easier to talk about it then.
roglok
PostPosted: Wed Oct 16, 2013 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
oh, i see... sorry misread your post. so i guess it's not a clean sinewave but self-oscillation with harmonics..? my SEM VCF clone, which is rather similar to Thomas Henry's design does not self-oscillate, so i can't really comment on that.
sound samples would be cool!
PS: regarding your earlier question about the LM13700 - it's really the same thing as the CA3080, except for the addition of linearizing diodes and a buffer for each OTA... http://www.idea2ic.com/LM13700.html
dimebucker
PostPosted: Fri May 02, 2014 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Any update on the resonance issue?
Just trying to decide on whether to etch this pcb, or go down the stripboard road....
