Coming up on Radio 1 at
12db MFOS filter
Page 1 of 1 [21 Posts]
haxster
PostPosted: Wed Jun 20, 2007 9:36 pm    Post subject: 12db MFOS filter
Subject description: Noisey filter output
I just recently finished soldering and wiring up the !2db version of the MFOS modular DIY filter. I ordered and built 3 of them. I wanted to use to process drum machines. I am also powering from the DIY power supply FONIK posted up, but am only using the 12+/- voltage side of it.
Has anyone built these yet? It works as far as cutoff and rez is concerned, but i am getting alot of noise out of it even with no input connected. The noise is enough with the filter to make the typical swoosh sound. In other words it sounds like Pink noise.
Do you guys think maybe a transitor is bad? i haven't checked my solder points yet but just brainstorming. I doubt it is this noisey stock right? i am also going to finish up wiring another one to compare and using another power source. Usually grounp problems produce Hum right. I have nothing like that, just ssssssss.
RF
Audio files: 28
PostPosted: Thu Jun 21, 2007 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope, they are not normally noisy like that. I built one and it does not have the issue you describe.
Sorry I don't have a specific answer for you.
Do you have a 'scope? If not, one of Ray Wilson's pages shows how to use an amp as a signal tracing device. Trace the signal path til you find where the noise shows up in the circuit, then check components and solder joints in that part of the circuit.
Good Luck!
Scott Stites
Audio files: 97
PostPosted: Thu Jun 21, 2007 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I built three of them and put them in one module (my Triple Wilson SVVCF module). If you're using line level signals, you probably will hear a bit of hiss as it sweeps. Crank things up to 10Vp-p synth level and it's fine.
Scott
My Site
haxster
PostPosted: Thu Jun 21, 2007 7:36 pm    Post subject: i think it is bad circuitry noise Reply with quote  Mark this post and the followings unread
i get the noise even with nothing plugged in to the analog input, i think it's bad circuitry noise. it is as loud a synthesizer pink noise. i am going to try the other to compare when i get the time. i have a feeling it is either bad transitor or not making good contact to the transitor. I have built the Noise Cornacopia and remember how ray made noise by not connecting a leg of transitor.
hackbox
PostPosted: Sun Aug 05, 2007 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually I have this exact same issue.
is it something to do with cheap transistors maybe?
I originally thought it might need a resistor adjustment but now I don't know what to think.
Apart from this I really like the sound of it.
edit:
I just noticed this on the SVVCF page and might be the cause of out issue.
"The 220pF integrator caps should be high quality and well matched for best results."
hackbox
PostPosted: Mon Aug 06, 2007 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
So I spent the day trying a few things out.
I changed all the chips to the lower noise equivalent.
The TL074 did some weird things... was kinda randomly generating
the TL072 didn't change anything as far as that hiss went.
so I changed all the chips back to the original config and poked around with an audio lead plugged into a preamp input.
What I did find was that the TL084 is the source of the noise(seems to be anyway). Just a gentle hiss really, but the same as through the outputs.
So what could be done to sort that out?
Would it be the integrator caps?
I couldn't find any that were better than what I have already got from fututrelec and others.
Any ideas?
Or is everyone else just building the soundlab?
lanxe
PostPosted: Mon Aug 06, 2007 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, i built two of these........
i have a slight noise in both of mine, but i never thought to worry too much until reading these posts. i want to go home and check mine out with the scope now.
please keep this thread going.
RF
Audio files: 28
PostPosted: Mon Aug 06, 2007 9:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey guys - I just checked mine - My MFOS 12 db State Variable has a bit more noise than the MFOS 24 db or the Steiner/Synthacon VCF I built - but not much.
I can hear it when I sweep the cutoff freq with no input. Like Scott said, if you are using 10v synth levels - no problem. The no input noise on mine is well below .1 volts peak to peak on the 'scope...
Good luck
Bruce
hackbox
PostPosted: Mon Aug 06, 2007 10:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Unfortunately I don't have a scope available to test it out that way.
The noise I'm getting is well above the noise floor of other gear.
The phaser has a little bit of hiss, but it doesn't have anywhere near the level of this, and nothing at all when nothing is plugged into it.
I'm going to poke around some more and maybe change some caps n stuff.
My joins all look ok.
A
haxster
PostPosted: Tue Aug 07, 2007 7:14 am    Post subject: STYRENE HIGH QUALITY CAPS Reply with quote  Mark this post and the followings unread
I ordered some high quality caps and as soon as they come in I am going to try that myself, I am also going to try s differet power supply. Yeah the noise on mine is well above average equipment hiss. Not even the Sound Labs are close to as loud as this.
lanxe
PostPosted: Tue Aug 07, 2007 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
well, i dont think mine is that bad......like others have said, there is some slight noise (even with nothing plugged in) but it is very low, and as far as i am concerned negligible. i guess i can spec my parts out a bit better, but sometimes i can be cheap!
good luck.
Ryan
haxster
PostPosted: Fri Aug 10, 2007 2:30 pm    Post subject: I finally tested another 12db filter Reply with quote  Mark this post and the followings unread
This time I connected it to synth MFOS VCO module signal and yeah you guys are right, the noise doesn't really matter much or can't be heard. The VCA/ADSR would shut it up also any ways. I guess for audio signal processing the VCF alone is just too noisy and not recommended. Oh well, looks like i am going to keep 1 and try to interate the others in SL.
hackbox
PostPosted: Sat Aug 11, 2007 11:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
If thats the case I guess I'm not going to have a big old cry.
It still sounds good to me.
I kinda like it in that lo-fi tape hiss kind of way.
Haven't tested my VCA or ADSR yet, but will take your word for it.
sneakthief
PostPosted: Tue Aug 28, 2007 5:57 am    Post subject:
Subject description: BLUE LANTERN IS VIOLATING CREATIVE COMMONS LICENSE! (and the DIY spirit)
I'd like to hijack this thread and point out that Blue_Lantern is building MIDIbox SID's and selling them commercially on eBay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290153272206
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=290155185277
He is also selling MFOS synths which may also be in violation of Ray Wilson's agreement: "Everything on Music From Outer Space is freely available for non-commercial use"
http://cgi.ebay.ca/ANALOG-SYNTH-SOUND-LAB_W0QQitemZ290154737201QQihZ019QQcategoryZ38071QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Blue_Lantern has been clearly informed by various individuals that this goes against the Creative Commons Non-Commercial license of the MIDIbox platform (including the PCB he's re-selling) and undermines all of the hard work of the DIY community.
Please see this discussion at midibox.org for more info: http://www.midibox.org/forum/forums.html?topic=9760.0
Despite this, Blue_Lantern is still selling these items on eBay. Please help the MIDIbox community stop this violation.
Sneak-Thief - raw electrofunk
kryptic
PostPosted: Tue Aug 28, 2007 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I have been following the discussions over at the midibox forums also. I didn't realize until now that this was the same guy that was also selling Ray Wilsons designs without permission. He seems to be gaining quite the reputation on different forums for exploiting the kindness of the DIY community and then turning around and commercially selling other peoples designs for a very high profit, which he seems to continue to do even after being asked not to by various individuals as well as the designer of the board he is using for the midibox. Rolling Eyes
BTW,
haxster = blue_lantern seems he changed his name today.
zipzap
PostPosted: Wed Sep 26, 2007 3:21 am    Post subject: Reply with quote  Mark this post and the followings unread
He´s selling them all over the world. Guess if you want to stop him there are legal possibilitys. Eg, to sell an item on ebay, it has to fullfil certain standards. If the machine is missing lables like the ce in europe, or if he´s using non Ross parts or solder, and since it´s obvious that these designs are stolen all that´sa needed is a loyer who is interested in the case. (any diy synthbuilding loyers around?)
http://www.myspace.com/lorolocoacousticpop
music and transcribed jazz basslines
Audio files: 266
PostPosted: Wed Sep 26, 2007 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
This isn't probably popular, but please see this post. http://electro-music.com/forum/post-141294.html#141294
Thanks.
autoprod
PostPosted: Thu Oct 18, 2007 1:20 am    Post subject: Noisy 12db MFOS state variable filter Reply with quote  Mark this post and the followings unread
Just to ad my confusion to this -
I built the filter and it came out really noisy. After troubleshooting for too long, I built another one, with the exact same parts and layout, which turned out all well behaved and quiet. Both were put to good use, but I still can't figure out why they behaved so differently.
- autoprod
hackbox
PostPosted: Thu Oct 18, 2007 2:44 am    Post subject: Re: Noisy 12db MFOS state variable filter Reply with quote  Mark this post and the followings unread
Hmm... must be a parts thing then.
But which part?
I haven't really done anything with it apart from my initial fooling about.
The soundlab and wsg has been holding my attention.
My DIY and Instrument addiction blog.
http://theawesomepowerofrockets.blogspot.com
wooster
PostPosted: Fri Oct 19, 2007 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I used good quality polystyrene caps here, and my filter is still very noisy compared to my MOTM-440.
Feifer
PostPosted: Fri Jun 15, 2012 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd like to resurrect this thread if I may. I'm having the same issue with this module and can't find the culprit. Without any input signal I still get quite a bit of noise and it must be before the filter section because the lowpass still affects it. It seems to appear right after the initial summing amp (pin 1 on U3) but there is a lot of other stuff getting injected into that node so I'm not sure.
Correct me if I'm wrong in my thinking on this, but everything at the top of the schematic is just a current source to control the OTAs/U4s cutoff frequency, so any noise from the transistors would not be audible noise, right?.
Has anyone ever figure out this problem?
Thanks Smile
http://www.musicfromouterspace.com/analogsynth_new/STATEVARVCFFEB2006/STATEVARVCF_FEB06_PG1_schem.pdf
... for your convenience.
