 Forum index » Clavia Nord Modular » G2 Patches - Completed » FX
Dimension D
Page 1 of 1 [8 Posts]
ian-s
Audio files: 43
G2 patch files: 626
PostPosted: Thu Mar 17, 2005 1:56 pm    Post subject: Dimension D Reply with quote  Mark this post and the followings unread
I found a fairly detailed description of the Roland Dimension D chorus effect. The G2 chorus module is nice but this one has a more subtle character due to complimentary EQ of the direct and negative cross mix. Simple 1 oscillator synth in VA for demo.
dimensionD.pch2
Old Roland Chorus
 Filename:  dimensionD.pch2
 Filesize:  2.14 KB
 Downloaded:  2422 Time(s)
3phase
G2 patch files: 141
PostPosted: Fri Mar 18, 2005 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
where do you found that info.. i own a dimension d but i might have to sell this wonderfull fx one day... I only see on the goniometer that it work frequ selektiv...but mor insight info is from interest for me
Audio files: 21
PostPosted: Fri Mar 18, 2005 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
The Dimension D is coming for the UAD-1 card.
BTW: What are the Dimension D boxes going for these days?
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Mar 18, 2005 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
check it out here:
arrow http://www.prepal.com/data/Roland.htm
is it there Question
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Mar 18, 2005 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
check also:
arrow http://www.oldcrows.net/~jhaible/dimension/jh_dimension_clone.html
ian-s
Audio files: 43
G2 patch files: 626
PostPosted: Fri Mar 18, 2005 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
seraph wrote:
check also:
This is thew site I used for details, they are not absolute precise so maybe someone who ownes a DD could tune the patch by ear?
3phase
G2 patch files: 141
PostPosted: Sun Mar 20, 2005 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
g2ian wrote:
seraph wrote:
check also:
I will have a look...but its not very likely that its possible to get close..the DD is the most subtile chorus on the market ...
to the question above...i wouldnt sell my for much less than 1000 euro...it is just is too good on voices ...
3phase
G2 patch files: 141
PostPosted: Sun Mar 20, 2005 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had a look on theese webpage...but it dont describes much what is going on...
On the original DD you get more phase and higher lfo rates as higher the input frequencie gets...there fore bass frequencies get very little chorus why high freq get a lot... You can use the dimension D on drums if you want... its not optimal for the bassdrum but the rest of the set benefits..the highhats fly away...
