 Forum index » Clavia Nord Modular » G2 Performances - Completed
droscanoo
Page 1 of 1 [19 Posts]
mother misty
G2 patch files: 130
PostPosted: Fri Mar 04, 2005 5:52 am    Post subject: droscanoo Reply with quote  Mark this post and the followings unread
This noodle consists of 4 slots
Sounds are generated in slot A, B & C but all routed to slot D.
in slot D you can control
* variations for slot A, B, & C
* Filter & Peak EQ for slot A, B & C
* A master section with filter, eq, delay efx's & 2 phase filters which controls the whole performance.
This one is good for scapes, drones and other ambient stuff...
Check the first 5 variations in slot D for some performance examples
(dunno if this will work on an unexpanded G2)
enjoy!
droscanoo.prf2
drone / scape noodle performance.
 Filename:  droscanoo.prf2
 Filesize:  15.26 KB
 Downloaded:  1955 Time(s)
Audio files: 266
PostPosted: Fri Mar 04, 2005 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool, Mother Misty.
I like this concept of using one slot as a control center for the entire performance. It makes the noodle performable. To me, performable noodles are where it's at.
cebec
G2 patch files: 31
PostPosted: Fri Mar 04, 2005 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
i like that aspect of your performances, too, mother. i'm with mosc on this. even if the noodle is simple, i really enjoy interactivity. been working on this in my own patches, as well. i like the way rob, for example, uses colors, name bars, and module placement to designate overall control parameters, too.
mother misty
G2 patch files: 130
PostPosted: Mon Mar 07, 2005 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
This patch was more of an experiment based around slot D. Slot A, B, & C were quickly patched for testing purposes Smile
I thought it would be nice to have a performance with all slots routed to 1 "masterslot" where you could control variations, volume, filter, eq's, for each slot and a final 'mastersection' (filter, eq, comp, del, rev) which would control the whole performance.
As a G2 keyboard user I still spend lots of time behind the monitor in the editor and not that much on the G2 itself.
(a bit weird, since I love tweaking hardware and this must be the most tweakable synth I've ever had)
This is just another attempt to change that, to make things a bit more controlable, logical & easier, at least for me Smile
Sometimes I forget how much fun tweaking this red monster can be without using the mouse!
Roland Kuit
G2 patch files: 127
PostPosted: Mon Mar 07, 2005 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice one Misty Cool
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Mar 07, 2005 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
All Performnaces are not download able at my computer. They open as txt-file and make the ditor crash. Any idea's?
Wout
Roland Kuit
G2 patch files: 127
PostPosted: Mon Mar 07, 2005 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
All performances, or only this one? Is it your OS? otherwise you can go to your map opties and make sure that the perf extension opens with the editor os you use.
Former site admin
Audio files: 353
PostPosted: Mon Mar 07, 2005 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout
I ran a few tests.
At this computer, at work, using Mozilla I do have a similar same problem - I have editor 1.24 instqlled here. The performance opens as text in the current browser window.
At home, with a later version of Mozilla and a later version of the editor I don't have this problem (I think ... I'm pretty sure ... I'll check later).
Using internet explorer at work works OK..
Also from Mozilla at work I can right click and use "save link as" or something alike to save the patch to disk. It will then open withoutout problems in the 1.24 editor. Using this procedure you'll at some stage have to manually change the name from "download.php" into something like "perf_name.prf2" - which is a bit of a pita.
I also tried to manually add an appropriate mime type to the Mozilla settings, but that makes no difference at all.
So .. I guess .. that when you are using Mozilla you maybe try to upgrade to a more recent version. But ... it might be that Howard or Stein forgot to list prf2 files as being binary in the Apache settings ....
Jan.
Audio files: 266
PostPosted: Mon Mar 07, 2005 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, what kind of mimetype should these files be.
BTW, this file works with FireFox on my computer. When you load the G2 editor it should register these filetypes for use with the editor. A correctly configured browser should check for the default registered application, shouldn't it?
Former site admin
Audio files: 353
PostPosted: Mon Mar 07, 2005 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Once home again using Mozilla everything indeed works as it should.
Meanwhile, listening to some beautifull variations of the patch that started all this and that I had completely overlooked before (foolish me), I communicated a little with Howard elswhere and he is going to try something.
Hope it works.
Jan.
Audio files: 266
PostPosted: Mon Mar 07, 2005 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jan sent me some mime-type entries to try. We might need to put these on both of our servers - the main one and the file server. I'm not sure. I just put them up on the main server. If those that are having problems with the download would be kind enough to try again I would appreciate it. It will help us find out which server is controlling what the clients are seeing in the mime-types.
thanks
Former site admin
Audio files: 353
PostPosted: Tue Mar 08, 2005 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I re-checked at work. The prf2 files still open as text here.
Jan.
Audio files: 21
PostPosted: Tue Mar 08, 2005 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Huh!!!!!????
Ehh.. let me look into this tonight. I did make the changes... but..
Flickr
Former site admin
Audio files: 353
PostPosted: Tue Mar 08, 2005 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Meanwhile I installed the G2 demo software here and the public beta as well, and now prf's do open ... sigh ...
Jan.
Former site admin
Audio files: 353
PostPosted: Tue Mar 08, 2005 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, forget that last post, it still don't work. Tried a pch instead of a prf ... and that does work (as it did before already)
Jan.
Sander_k
G2 patch files: 16
PostPosted: Tue Mar 15, 2005 12:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool performance... i'm still trying to figure out what everything does.. it's hard to figure out others patches
About that txt-file problem, my G2 sometimes pops into an error when opening prf2 or pch2 files... only happened with Roland Kuit's patches (no offence Wink )
monokit
G2 patch files: 8
PostPosted: Tue Dec 13, 2005 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful soundscape, can't stop listening.
Nice idea of having one slot be in control of it all.
But I understand the G2 also has a set of global param pages, that can control parameters from any of the slots. Wouldn't that help when the performance was not designed with a control slot in mind?
mother misty
G2 patch files: 130
PostPosted: Wed Dec 14, 2005 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
You can assign any parameter of one of the 4 slots to the global page,
but I don't think there's another way to have performance variations than this one...
monokit
G2 patch files: 8
PostPosted: Wed Dec 14, 2005 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, I understand now. You use the slot D variations to store slot A/B/C variation combos. Nice...
