Posted: Sat Feb 26, 2005 4:00 pm Post subject:
G-Lab
Some experimental electronic drums based around Glitchlab1 by the why project.
(Good for Electro, IDM and other glitchy stuff)
As usual you can change the variations for the whole performance in slot C.
(7 variations are filled) Check the MP3 for an audio example
(Delete the slot C if you're using an external sequencer, beat=C1, perc=D1, snare=C1, hihat=E1)
have fun jamming!
AE-GLABv1-11.mp3
audio example G-Lab
Filesize:
1.27 MB
Duration:
0:55
Viewed:
1809 Time(s)
G-Lab v1-11.prf2
G-Lab, experimental electronic drums
(change performance variations in slot C)
"If something is boring after two minutes, try it for four. If still boring, then eight. Then sixteen. Then thirty-two. Eventually one discovers that it is not boring at all." --John Cage.
Posted: Mon Feb 28, 2005 1:26 am Post subject:
Re: G-Lab
have fun jamming!
This is one of the best things I've heard on the G2, imho!
Keep up the good work... _________________ (dx/dt=delta*(y-x))(dy/dt=r*x-y-x*z)(dz/dt=x*y-b*z)
I have listened to variation 7 for a looong time and its still interesting.
thanks ian. If you turn the modwheel in slot B in the other variations you will have a similiar effect
Great for building things up or break them down while still remaining the original tempo...
