Joined: Feb 04, 2005 Posts: 2903 Location: Nottingham, UK
Audio files: 282
Posted: Wed Mar 02, 2011 3:24 pm Post subject:
One-off or irregular show bookings |
EDIT: see http://electro-music.com/wiki/pmwiki.php?n=Radio.BroadcastingInfo for more on how to broadcast on electro-music.com.
To avoid unnecessary scheduling conflicts, could everyone who wants to do a one-off or irregular radio show on the main port of radio. electro- music.com please post date and time details (start time and length) here to book a slot. All times must be in GMT.
This is the current schedule:
When booking are added to this thread a stream op will add them to the schedule so that all irregular and one-off shows are easily visible
Please try to avoid scheduling a one-off show against a regular show as these will have priority. If there are any accidental scheduling conflicts these will be resolved when they become apparent. _________________ Jez
music | adventures in sound | gear for sale Last edited by modulator_esp on Wed Mar 02, 2011 4:03 pm; edited 4 times in total |
Audio files: 282
Posted: Wed Mar 02, 2011 3:27 pm Post subject:
I would like to book a slot for Chez Jez #4 on Saturday 18th June from 21:30 GMT for 90 minutes _________________ Jez
music | adventures in sound | gear for sale |
Audio files: 353
Posted: Wed Mar 02, 2011 3:47 pm Post subject:
| Jez you got booked for June 18 |
Audio files: 282
Audio files: 373
Posted: Fri Mar 04, 2011 7:42 am Post subject:
Since there is an apparent clash between Commuter's Diary part II and Chez Jez tomorrow, Jez asked me to move back a bit, which is fine by my. My show is actually a bit less than an hour and a half, so could you please move me back one hour, to... whatever GMT that ends up being (I can only see my local time here and I'm afraid to do the math in my weary head). I'll play just before Jez at any rate.
Audio files: 353
Posted: Fri Mar 04, 2011 8:30 am Post subject:
| Did that Stefan, also adjusted the length to 90 minutes. Glad you got it sorted out. |
Audio files: 282
Audio files: 373
Audio files: 282
Posted: Thu Mar 31, 2011 4:45 am Post subject:
Will add next Chez Jez to schedule for Saturday 30th April at 21:30 for 90 minutes _________________ Jez
fky
Posted: Mon Apr 11, 2011 2:38 am Post subject:
Hi
Just wondering when is the best time frame to arrange the once-off show?
There could be a huge time gap around the world. Say If we plan a show at night, the stream operator needs to get up at 6:00am.... _________________ http://soundcloud.com/fkyfkyfky |
Audio files: 353
Posted: Mon Apr 11, 2011 11:32 am Post subject:
| fky wrote: | | Say If we plan a show at night, the stream operator needs to get up at 6:00am.... |
Not necessarily .. if you would use the sc_trans connection you could switch yourself; to be able to use sc_trans you can not use ed/oddcast tho, but will have to use nicecast or butt. |
fky
Audio files: 353
Posted: Sat Apr 16, 2011 7:26 am Post subject:
It is one of the tools we use for streaming; it handles the play list, but it also supports what they call DJ connections. When a DJ connects that will take over the stream on main. So there is no switching involved then, but it will not work properly with the good old edcast / oddcast software.
When streaming from a Mac you could use Nicecast, if you have that, or otherwise install Butt - Butt is available for PC and Linux too : http://butt.sourceforge.net/
When you want to try things out, you can set up Nicecast or Butt to connect to electro-music.com on port 9878 with password public:public (exactly as I wrote it, with the : (colon) and all). To listen to that test stream you can tune in to port 8054. It should be set in shoutcast mode,the bit rate and audio format is not too critical - it will be transcoded to 44 kHz 128 kbps stereo by sc_trans (and that is where it gets it's name )
When ready to run a show just give me a date and time in GMT, a duration, an artist name and a name for the show/preformance - I'll make a schedule entry for it then and that will cause the event to be listed on the site here automagically. And then for the real show you just use port 9876 instead of the testport. |
fky
nobody
Posted: Tue Apr 26, 2011 6:46 am Post subject:
As I posted in the radio schedule thread, I feel that a regular show is not working for me right now, so I guess in the future, you'll be hearing from me here when I'm ready for the next show.  |
Audio files: 353
Posted: Tue Apr 26, 2011 7:20 am Post subject:
| Ok Damien, will fix the schedule for it - hope to hear you on the radio soon. |
nobody
Posted: Tue Apr 26, 2011 1:19 pm Post subject:
| Blue Hell wrote: | Ok Damien, will fix the schedule for it
Thanks.
| Blue Hell wrote: |
And thanks!
Don't worry, I'll be around.  |
Audio files: 282
Posted: Mon May 16, 2011 4:58 pm Post subject:
I'd like to book a slot for the next Chez Jez which will be on 28th May 2011 _________________ Jez
Audio files: 353
Posted: Mon May 16, 2011 5:04 pm Post subject:
| Ok, its in the schedule already I see :-) |
Audio files: 282
Posted: Mon May 16, 2011 5:38 pm Post subject:
| Blue Hell wrote: | Ok, its in the schedule already I see  |
yes, but I thought I should at least try to keep this thread updated  _________________ Jez
Acoustic Interloper
Joined: Jul 07, 2007 Posts: 2081 Location: Berks County, PA
Audio files: 90
Posted: Sat May 28, 2011 12:54 pm Post subject:
Pre-EM2011 show on September 7 Subject description: How is 6-8 PM Eastern Daylight Time on Sept. 7? |
How is 6-8 PM Eastern Daylight Time on September 7?
That would be 18:00 until 20:00 EDT, which I believe is 22:00 until midnight GMT. Only 4 hours when we Pennsylvanians are in daylight savings time, I think.
The event is a computer music seminar that will include two pieces by myself and some students in our university's planetarium. Michael O'Bannon has very graciously agreed to stop over on his way to electro-music 2011 to perform video magic on the planetarium dome. Between pieces Michael will give a talk and demo on EEG-to-music and some of his development process, and I will give some kind of technical talk.
It is likely to run a little less than 2 hours, so we can say 90 minutes if that makes sense. This may run into Jez or Rob's Adventures, although with electro-music 2011 kicking off two days later, it may not. If so, we can always record it and stream the good bits later.
The planetarium has an interesting placement of 5 speakers around the base of the dome + subwoofer, not exactly surround 5.1 placement, but, given a circular room, circular seating and heads pointed towards a domed ceiling, it's bound to be unique. Jeremy and Dr. Phill Reed of the Physics Dept. and I did sound and projector checks yesterday. It promises to be fun  _________________ When the stream is deep
my wild little dog frolics,
when shallow, she drinks. |
Audio files: 353
Posted: Sat May 28, 2011 1:02 pm Post subject:
Re: Pre-EM2011 show on September 7 Subject description: How is 6-8 PM Eastern Daylight Time on Sept. 7? |
| Acoustic Interloper wrote: | How is 6-8 PM Eastern Daylight Time on September 7?
That would be 18:00 until 20:00 EDT, which I believe is 22:00 until midnight GMT. Only 4 hours when we Pennsylvanians are in daylight savings time, I think. |
Yeah it would overlap then with AIS which runs from 22:00 to 23:00 - it is 4 hours indeed ... too bad, it would make for an interesting show. |
Joined: Apr 24, 2009 Posts: 2543 Location: Bristol UK
Audio files: 522
Posted: Mon May 30, 2011 5:47 am Post subject:
| Blue Hell wrote: | | Acoustic Interloper wrote: | How is 6-8 PM Eastern Daylight Time on September 7?
As far as I can tell, that's Jez' turn, and he would be on his way to EM2011 then I suppose? _________________ Muied Lumens Sub Forum
Bandcamp |
Audio files: 282
Posted: Thu Jun 02, 2011 2:41 am Post subject:
| Muied Lumens wrote: | | Blue Hell wrote: | | Acoustic Interloper wrote: | How is 6-8 PM Eastern Daylight Time on September 7?
As far as I can tell, that's Jez' turn, and he would be on his way to EM2011 then I suppose? |
Yes, it will probably be my week, and I will hopefully be somewhere in the US. Too early to say yet if I'll be doing a live show, depends where I am, however, I would try to be flexible with times if I am _________________ Jez
Audio files: 282
Posted: Tue Jun 21, 2011 11:41 am Post subject:
I've put the next Chez Jez in the schedule for Saturday 23rd July, from 20:30 to 22:00 GMT _________________ Jez
