Coming up on Radio 1 at
Bayesian Probability
Page 1 of 1 [14 Posts]
bachus
PostPosted: Fri May 28, 2010 2:42 pm    Post subject: Bayesian Probability Reply with quote  Mark this post and the followings unread
Several years ago I read David Temperley's The Cognition of basic Musical Structures and was glad to see his extension of Lerdahl and Jackendoff's preference rules. In effect, this kind of rule incorporates informed intuition about musical context into analysis and provides substantial leverage in elucidating elements under the surface of musical score. On the down side it makes for a semi-formal system, one not amendable to translation into algorithms. In his new book, Music and Probability, Temperley shows how Bayesian Probability can be used to "statistically" formalize preference rules.
I know a number of people on this forum use probabilistic methods and was wondering if any are using Bayesian methods and if so, how and with what results?
Van_Tek
PostPosted: Mon May 31, 2010 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I've been producing music for 10 years now and I have no idea what you just said...
Dope Tito music: www.dopetito.com
My Facebook: www.facebook.com/VanTek
My Artist Page: www.facebook.com/jasonvantek
bachus
PostPosted: Mon May 31, 2010 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here are the three books that, if read and understood, would put one in a position to not only understand the initial post, but to assist with Project Zylaphon.
A Generative Theory of Tonal Music
The Cognition of Basic Musical Structures
and
But, of course, I don't expect you to this--though I would rejoice at it. The purpose of the post is to engage someone who has read at least one of these books as a starting point for conversations on the topic of surface first analysis. I.E. starting with the notes provided by the composer and projecting deep structures from that data.
Sorry, it is a difficult area, and I need all the help I can find.
Embarassed Laughing
Acoustic Interloper
Audio files: 90
PostPosted: Fri Jun 04, 2010 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I wrote a patent application for a client in 2007 that made use of Bayesian data filtering to figure out the likelihood that you want to establish geographically local communication contacts as you travel, based on prior actions. (Simulations were quite scary in predicting human behavior. The patent is still pending.) I haven't done anything relating to music, although I did read Temperley's Music and Probability a few years ago.
The most useful newbie tutorial for me was Paul Graham's essays on Bayesian spam filtering,based on the statistical correlation of words within emails classified by the user as spam. It was a fairly understandable introductory essay.
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
bachus
PostPosted: Sat Jun 05, 2010 5:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Acoustic Interloper wrote:
... haven't done anything relating to music, although I did read Temperley's Music and Probability a few years ago.
Thanks, Do you remember what your impression was of Music and Probability?
Acoustic Interloper
Audio files: 90
PostPosted: Sun Jun 06, 2010 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I thought the book was fine, although tangentially related to my interests. As I recall it was about classification and generally related to score retrieval and categorization.
More to the point, I have general ideas about a representation format for scores derived from mechanisms in quantum mechanics, where events in a score have probabilities ranging from 0 to 1, and probabilities for events (both "atomic" events however they are defined, and their multi-layer hierarchical aggregates) are resolved to 0 or 1 only at performance time, with resolution determined in part by actual performance data coming into the score (from performers, conductor, room acoustics, etc.). Anything resolving to 1 plays and to 0 does not. The concept is inspired by the notion of measurement-as-participation and quantum entanglement. I am sure that I have prattled on about it before.
Even more to the point, I just got back from http://www.icmc2010.org/ this early AM and spent much of yesterday participating in the "Unconference," including a lengthy discussion among performers and some composers (ICMC has a strong classical bias; Unconference not as much) about the impossibility of repeat performances without the composer at hand, partly because the composer is now over-coupled into the job of instrument designer (designing unique, hard-to-duplicate instruments as a component of every score), partly because there is no portable, machine-and-performer readable score format capable of capturing scores that include strong, non-traditional sonic components.
From my perspective the notation should not be tool specific (C++, C#, Max, PD, Chuck, whatever). It must be a data language (e.g., on top of XML), readable by humans (via a custom music-atop-XML viewer), and extensible so that it can capture scores for unique instruments. XML is just an example, although a likely one. Clearly, I would like it to be able to handle probabilities, presumably Bayesian ones.
The other missing piece is the "technician" who nowadays is an additional performer who should get performance credit on the score and program. Someone referred to this person as the "Performer Whisperer."
I thought of your recent threads right away, and also how the Unconference discussion ought to be continued here. I did a bit of proselytizing for electro-music, with plans for more. I did also get some contacts for interested people, including one professor in my university system who teaches in middle PA. Following up on all this is in my to-do list.
bachus
PostPosted: Mon Jun 07, 2010 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Dale, interesting, informative post.
Certainly notation must be extensible if it is to fill the needs of diverse approaches to music creation. But from my view point notation is most often a surface feature of an elaborate deep structure and to be functional in a computational sense, notation is inseparable from that structure. Though a data language like XML is certainly capable of encoding such deep structures it seems the whole shebang would have to be duplicated in some general-purpose language, e.g. Java, C# etc.. Which is a bit off-putting both conceptually and practically. That said, I certainly see the advantage of the XML/XML-Viewers model for surface feature presentation an interaction.
Perhaps I am missing something? Or perhaps that is the difference between viewing notation as a data to be interpreted by performers and viewing it as an interface into a deeper web of data to be manipulated by composers?
Acoustic Interloper
Audio files: 90
PostPosted: Mon Jun 07, 2010 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
These sorts of issues come up all the time in the design and implementation of CAD tools for VLSI design, which is where I spent much of my Bell Labs time (and where I met Mosc).
To the degree possible tools need to exchange data in a common, extensible format. In the "leaves" are the hooks for annotating information to tool-specific features, such as a pragma that indicates using some tool-specific VLSI compaction algorithm, for example. The core of an XML-hosted musical notation language would be standardized, representing common features. Some extensions might be expressed in terms of that core, e.g., aggregation of units defined in the core language. Some would be outside the language, i.e., resident in a specific tool or language. Such constructs should be in the "leaves" of a particular design file, as opposed to being over-coupled into the core from the outset. The XML, for example, could have URIs pointing to tool-specific annotations in a common, tool-neutral form, indicating precise ways to implement those common constructs in tool-specific ways.
Extension languages like Tcl or Python do this. Some extensions are in the language, built up using language constructs. Others are under-the-hood extensions under a foreign language API that appear as function calls in Tcl or Python. The Java Native Interface is similar, allowing access to underlying code written in C; that C code is the analog of the tool-specific features not found in the standardized language but nevertheless accessible from it.
In our discussion at the Unconference the performers expressed dissatisfaction with notations such as "depress pedal X for 2 beats" without any notion of what depressing pedal X represents sonically. The core concept such as "pink noise for 2 beats" should appear in the core of the score, with the means for realization (depressing a pedal in this example) "in the leaves." Sometimes the leaves are simply paths/URIs to machine-readable instructions.
Hope this makes sense. Part of my reading of the problem is that modern electro-classical composers over-couple too many things. They over-couple instrument design into the score, and they over-couple non-musical artifacts (from a performer's perspective) into the score as used at practice and performance time by a performer. The performers invest a lot of time preparing for a piece, and they do not want their efforts to be thrown away after 1 or 2 performances because of instruments that cannot be reconstituted, often for reasons of non-robust design, and because of scores that cannot be interpreted without the composer sitting in the room.
bachus
PostPosted: Mon Jun 07, 2010 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I certainly can be slow, but now I've got it and have to agree completely. Thanks for the clear and compelling explanation.
bachus
PostPosted: Mon Jun 07, 2010 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually I don't quite agree with every thing. Even though the creation of ephemeral compositions does not interest me, I have some misgivings about this. To my mind it is entirely valid for a composer to conceive and create a composition that is essentially ephemeral, having no life beyond a precious few performances other than recordings of those performances. So I would not want to disparage the preparatory efforts of performers in this and similar contexts as being "thrown away". But I guess that's a composer's view. I'm sure if I were a performer I would piss and moan about it.
Acoustic Interloper
Audio files: 90
PostPosted: Mon Jun 07, 2010 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree with you, and I think the performers in the room would have agreed, that it should be *possible* to write and perform ephemeral compositions. Their main point was that the composition should not be ephemeral simply because they as performers cannot repeat a performance of a heavily practiced and otherwise non-ephemeral piece simply because the communication of that piece to them is incomplete, requiring the composer to be lurking in the shadows pushing buttons during performance.
Of course, I play improvised music and none of this much affects me directly. After doing *Sketches of Spain* with classical performers who had no inclination towards improvisation, Miles Davis referred to that mode of performance as "robot shit." Improvisation in Indian classical music also came up during this discussion.
But I am, after all, a jazzified folkie and generally a musical poser. Twisted Evil
bachus
PostPosted: Tue Jun 08, 2010 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
OK. I confess, the last two lines were a joke meant to poke fun at the attitudes of both composers and performers. -- After all I am a would-be composer Laughing
Acoustic Interloper
Audio files: 90
PostPosted: Tue Jun 08, 2010 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, there was plenty of implied pissing and moaning. Laughing
Acoustic Interloper
Audio files: 90
PostPosted: Sun Aug 21, 2011 8:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just ran across a transcript of this Unconference here.
