A Chaotic LFO
Page 1 of 1 [11 Posts]
jamos
G2 patch files: 44
PostPosted: Sat Jan 15, 2005 11:49 am    Post subject: A Chaotic LFO Reply with quote  Mark this post and the followings unread
This simple patch implements the "logistic equation", which is a simple way to generate non-repeating, chaotic patterns.
Adjust the knob labeled "3 < k < 4" to vary the pattern from ordered to random.
Chaos Generator.pch2
Implements the chaotic "logistic equation".
 Filename:  Chaos Generator.pch2
 Filesize:  1.31 KB
 Downloaded:  2445 Time(s)
cebec
G2 patch files: 31
PostPosted: Sat Jan 15, 2005 9:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool, thanks for this...
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Sun Jan 16, 2005 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks much for this patch. I have not tried implementing logistic EQ on the G2, but I did some work with it in reaktor. you might find the attatched audio clip of interest:
gxaos1.mp3
recording of reaktor noodle: 4 logistic eq's, each with different constants and their own sampler. The same sample is being triggered in all 4, two strums of a dom7 chord on an acoustic guitar. The eq's are also set up to cross modulate the pitches, st
 Filesize:  1.15 MB
 Duration: 1:00
 Viewed:  2234 Time(s)
jamos
G2 patch files: 44
PostPosted: Mon Jan 17, 2005 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, fellers.
I figured out how to fix the annoying reset behavior, and it even requires fewer modules. The new version is up.
Audio files: 43
G2 patch files: 626
PostPosted: Mon Jan 17, 2005 11:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is great.
The output also makes some interesting, organic tones if clocked by an oscD.
Thanks for posting
Audio files: 266
PostPosted: Tue Jan 18, 2005 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I love this. Didn't know about it before. Thanks much...
Zynth, your track sounds fab. Cool
egw
Audio files: 19
G2 patch files: 8
PostPosted: Tue Jan 18, 2005 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Could you post the equation here, or a pointer to a site that explains it?
jamos
G2 patch files: 44
PostPosted: Tue Jan 18, 2005 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
The equation is
x[t+1] = k * x[t] * (1-x[t])
If you Google on "chaos" and "logistic equation", you'll find far more explanations than you can possibly read :') A good one is at http://hypertextbook.com/chaos/42.shtml .
egw
Audio files: 19
G2 patch files: 8
PostPosted: Tue Jan 18, 2005 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
How do you know that k should be between 3 and 4?
Trial and error, or is it a recommended value?
Are there any constraints on x[0] besides not equal to 0?
jamos
G2 patch files: 44
PostPosted: Tue Jan 18, 2005 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mostly 'cause I'm taking a class in chaos theory and know all this shit real good Very Happy
But the way you can really tell is from that bifurcation diagram at the bottom of the page that I referenced. This shows that for values of k (they call it r) < 3, the attractor is a fixed point - DC, in other words. No good. Even for k < ~3.57, the output is not chaotic, or even interesting - just two values (a square wave).
X[0] has to be between 0 and 1, exclusive. If it's either of those the output will go to 0. If it's greater than 1, the function goes to infinity. In G2 terms, 1 == 64; that took a while to figure out (look at the docs on the level multiplier, that's where I picked up the relevant tidbit.) The result is that the output (the green cords) swings from 0 to +64.
Audio files: 266
PostPosted: Tue Jan 18, 2005 8:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Zynth, now that you can see how to make this chaos patch using the G2, why not try a version of the Reaktor patch and let us see how it's done? This stuff if facinating.
