A Birth of a Synth/Thomas Henry section that doesn't suck...
Page 1 of 2 [41 Posts]
Scott Stites
Audio files: 97
PostPosted: Sun May 02, 2010 7:43 pm    Post subject: A Birth of a Synth/Thomas Henry section that doesn't suck... Reply with quote  Mark this post and the followings unread
Hi All,
I'm in the process of transferring my website to my domain from the People's Republic of PC. Actually (as some may have noticed) I've already moved the TH content. Unfortunately, the move turned into a delicious serving of loser cakes smothered in fail sauce. I purchased one of those WYSIWYG editors, and what I saw is not what you got - some of the pages are nearly unreadable on just about any platform other than mine, and for that, I apologize.
The fail is a result of some bad cut-and-paste to an equally bad editor that provided no means at all of hand-editing the HTML/CSS tables, which would have been nice because the program seemed to rely on tags that had long since been deprecated before the program was released. Moreover, it created such a snarl of CSS that, even when I did get the proper tools, it became obvious that it would be easier to rewrite the pages and publish them anew. This weekend I tried a Hail Mary CSS reset on the published pages, which actually made the situation worse. Unfortunately, I'd deleted these pages from the old site, so there's no going back there....
Anyway, I'm sorry to have crapped up those pages so bad, and soon I'll have them fixed in a new, code compliant, improved read-o-matic style.
My apologies,
Scott
My Site
Sound
PostPosted: Mon May 03, 2010 1:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Congratulations for your new site. well done well done well done
richardc64
Audio files: 26
PostPosted: Mon May 03, 2010 5:54 am    Post subject: Re: A Birth of a Synth/Thomas Henry section that doesn't suck... Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
...the program seemed to rely on tags that had long since been deprecated...
"I know engineers, they love to change things!" -- Leonard McCoy
Scott Stites
Audio files: 97
PostPosted: Mon May 03, 2010 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, guys.
The deprecated tags really wouldn't jack the site as bad as it is. I think the main problem was the WYSIWYG program I was using before was designed mainly for people who wanted to use the built in templates. It allowed one to create one's own layouts, but it had some restrictions that clashed directly with my goals - the main problem right off the bat is that it restricted the vertical height of the page to 5000 pixels, which forced me to attempt to squeeze a lot of those pages down. That and the cut-and-paste I'm sure was putting in unwanted style code, and there was no way to look at the code inside the program to edit things out. I didn't have any obvious reason to - it looked fine on my computer; it wasn't until I looked at a different computer here at work that I realized the fail of my ways.
Anyway, I've got Microsoft Expression Web 3, which I really like. It allows me to work with the code directly and see what happens right off the bat in design view. It also checks whether the code is compliant or not, and that really helps. It's got some great preview modes, and I've got every browser I could find on my computer to check it out as well.
I've got a test page up - so far it works on my computer using all my browsers and a computer here at work running Linux with Firefox and Google Chrome. The main page content is a bit schmaltzy and stern in other places, but I'm worrying more about layout than content right now. The Home and Thomas Henry Designs menu items work - the rest are just place holders. The only TH page I've re-worked is the 8038 Generator, which is the simplest of the pages. I was considering using frames, but have decided not to; I still need to work out a decent menu system for the multi-page projects (like the SN-Voice), but so far things are working out better. The test page is here, should anyone want to take a look:
http://www.birthofasynth.com/index_test.html
Cheerios,
Scott
My Site
Former site admin
Audio files: 353
PostPosted: Mon May 03, 2010 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry to hear Scott Crying or Very sad the new one looks fine to me, on the mac as well (FF and Safari).
Scott Stites
Audio files: 97
PostPosted: Mon May 03, 2010 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Jan! I don't know anybody here with a Mac, so that really helps.
Cheerios,
Scott
My Site
Audio files: 19
PostPosted: Mon May 03, 2010 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes you do! Wink
Stein and Carlo, are also on Mac. Also is Les (Inventor).
ACHTUNG!
mark_olson
PostPosted: Mon May 03, 2010 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I looked at it in Safari, FF, and Camino (my preferred browser) and it looks fine but I have a hunch that the text window is probably not intended to cover as much of the image/s as it does.
And as Tom has already pointed out, you have more Mac users among your friends than you seem to realize Smile
Oh, and nice work, BTW.
Good luck.
Mark
Is this the desired appearance?
 Filesize:  320.85 KB
 Viewed:  396 Time(s)
Scott Stites
Audio files: 97
PostPosted: Mon May 03, 2010 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I should have clarified "here" - I meant, physically here as in my immediate vicinity of Kansas. Come to think of it, Scot Solida uses mac, if I'm not mistaken.
Thanks for the screenshot Mark. Actually that's how I intend it to look - I lowered the main content a bit to let the more of the background image through - I liked that better. I spent too much time on it to cover it up. Laughing
The "birth of a synth" logo is a separate transparency that doesn't work well with IE6, which has poor transparency support, but I have absolutely no urge to jump through hoops for that browser. It's still visible, you can just see the edges of the transparency.
Thanks all,
Scott
My Site
Tronato
PostPosted: Tue May 04, 2010 3:48 pm    Post subject: New Website Reply with quote  Mark this post and the followings unread
Hello!
Your new website looks great to me!
Congratulations!
TRON
RF
Audio files: 28
PostPosted: Tue May 04, 2010 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your efforts at keeping this up Scott. Your pages have been a great source of ideas and inspiration for me. Sorry to hear of the problems - glad to see the content is still around Smile
bruce
www.sdiy.org/rfeng
Scott Stites
Audio files: 97
PostPosted: Tue May 04, 2010 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, thanks guys! Very Happy
I'm finally getting a grip on things, and hopefully I'll have all of the TH pages restored to legibility in a week or two. Then I'll transfer the rest of the content and go from there.
Scott
My Site
tommi
PostPosted: Wed May 05, 2010 2:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott i am digging this page from your website:
http://www.birthofasynth.com/boas1_002.htm
I like every one of your klee's samples.
http://tideofsound.net
Audio files: 25
PostPosted: Wed May 05, 2010 4:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott
Looking good thus far. The page is very readable. I will assume that menu items 4 & 5 are intentionally not loading. I can appreciate all tghe work your doing so hang in there.
The new web tools seem to be much better and maybe even something I would be interested in. That "Web Easy Professional" program is a joke really (if thats the program your using originally) !! Seems only good for templates and not much else. Rolling Eyes
BTW: I enjoyed reading the piece about the "analog vs digital" on the home page to ... Wink
Bill
BananaPlug
PostPosted: Wed May 05, 2010 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott:
In newspaper lingo "above the fold" referred to the top half of the newspaper page; highly valued space because people see it first and only then decide if they want to pickup the paper and read it. It's the same with web pages and scrolling. Of course it's your web page and you aren't trying to sell newspapers, but I felt compelled to stand up for this basic principle of page layout anyway. (insert hiding-under-chair icon here)
Scott Stites
Audio files: 97
PostPosted: Wed May 05, 2010 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, Bill - this isn't the "live" site, just a test HTML - I'm just working out whether the layout will work across different platforms and browsers.
Banana Plug - I'll let you take that up with Morten Rand-Hendriksen Very Happy
http://www.designisphilosophy.com/
My Site
mark_olson
PostPosted: Wed May 05, 2010 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
...will work across different platforms and browsers.
To say nothing of ADA compliance Wink
Mark
Scott Stites
Audio files: 97
PostPosted: Wed May 05, 2010 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
ADA?
My Site
Audio files: 19
PostPosted: Wed May 05, 2010 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott, my only criticism, is that the text is rather difficult to read against that grey-ish textured background. I actually really liked your first site, as I found white text on a black background quite easy to read. Grey is far better though, and this shows on your rectangular inserts.
I downloaded a really mad app the other day called "sim-daltonism" which simulates what it is like for people with colour blindness, who have to look at websites, and applications. It's amazing how much we take for granted!
http://michelf.com/projects/sim-daltonism/
Apart from that, nice site! I've built mine 7 times now, and it still hasn't got published! Shocked
ACHTUNG!
Scott Stites
Audio files: 97
PostPosted: Wed May 05, 2010 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Tom,
Yeah - I'd read about that app in one of the books - I hadn't tried it out yet. Some of those filters are wild. It's a good thing to check.
I agree on the text - I have a hard time following it, too. However:
I changed that later on specifically because I had someone complain about it - this person said that it fatigued his eyes very quickly.
I like the gray background idea, and I'll give that a shot. I've set up my CSS code so that I can make changes like that very easily across all the pages I've so far re-built.
Right now I am mainly concentrating on working on code compliance: whether the site displays at all in a manner where things don't overwrite other things and it's readable.
The content up to this point is a done deal for the time being - I'm in a phase where I am just translating from the old site to the new.
I appreciate people's advice, particularly concerning readability, and so forth but I have a very good idea of how I want to organize and present the site as a whole. On that point, I'm going the Ricky Nelson route; you can't please everybody. I don't particularly enjoy web design, and this has taken far more of my time and money already than I intended to spend on it. I spend my entire day in front of a computer, and it takes a sizable force of will to even look at a computer when I get home. I seriously have better things to do. So, once the site is up, viewable, and doesn't have any broken links, I'll let the content drive whomever would care to view it. I plan to add to it, but I'm trying to arrange it so that process is a painless as possible.
If I were a commercial entity, I would, of course, take a different approach.
Cheerios,
Scott
My Site
mark_olson
PostPosted: Wed May 05, 2010 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
ADA?
Sorry; you probably thought I meant Lady Ada :
http://www.ladyada.net/about.html
But no, I meant "Americans with Disabilities Act", as in:
http://www.ada.gov/pcatoolkit/chap5toolkit.htm
Oh, and I should add that I couldn't find the tongue-in-cheek emoticon Wink
Scott Stites
Audio files: 97
PostPosted: Wed May 05, 2010 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I was thinking A/DA.
Does this mean I have to put up a carpal tunnel syndrome disclaimer? Laughing
My Site
Tronato
PostPosted: Wed May 05, 2010 10:21 am    Post subject: Complaints? Reply with quote  Mark this post and the followings unread
Hello!
Scott, do what you feel is right and don't try to satisfy everybody, that is impossible!
From my point of view, we are already lucky enough to see you post anything at all!
Cheers!
TRON
Audio files: 19
PostPosted: Wed May 05, 2010 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
We can't bloody win can we? Laughing
Grey is good, and so is 1.5 or more (double) spacing between lines. I always lost marks at university if I didn't use double spacing in dissertations! Idea
You're a great bloke, with some great tales to spin, but that's part of the problem- it can be hard going sometimes reading all that text, so double spacing comes highly recommended! (I think this would also bode well with other disability guidelines (American?) too. Very Happy )
ACHTUNG!
Scott Stites
Audio files: 97
PostPosted: Wed May 05, 2010 8:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks again, guys. I widened the line spacing and put a gray tint on the content tiling and subdued the grain a bit (I liked it better than the straight background gray, Tom). One thing I think helped also was to bring down the color of the background tiling - it's actually pretty close to the color of my old site now. I found the bright blue tended to make it harder for my eyes to focus on the content.
I also changed the background image and pulled the opening page content higher on the Y axis so that more of it was visible when the opening page opens. I checked for color blindness - it generally does OK. One or two modes gave it more of a pinkish tinge, but it wasn't too garish.
Cheerios,
Scott
My Site
