sub oscillation
Page 1 of 1 [6 Posts]
isak
PostPosted: Thu Feb 11, 2010 3:13 am    Post subject: sub oscillation
Subject description: whos desing to use ? and how to connect to sound lab plus pcb ?
Hi guys
i want to add a sub oscillation to the sound lab plus, there are a lot of desings in the net, if any one here have experience with how to do it and what desing to use i'm sure that every one here will be happy to hear about it.
any info will be much appreciated by every noob here including me Mr. Green
thanks,
Isak.
if837
PostPosted: Thu Feb 11, 2010 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
roland sh09 uses a sub oscillator, you could perhaps start with looking at the service notes. I´m also interested, to know if someone has figured out the partslists for SH09 with suggestions for replacements.
Maybe BA6110FS could be used for replacing some of the IC´s in the VCO?
http://www.electromusic.com/takeout/sh09.pdf
RF
Audio files: 28
PostPosted: Thu Feb 11, 2010 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I've built and used this one - although it's more than just a subOsc...it gives you several divisions of the input frequency, and the ability to mix them...
I like it alot....
Just leave off the 4040 sectionif you don't need those pulse outputs...
http://www.freeinfosociety.com/electronics/schemview.php?id=112
Here's another - I had not seen this one before.
http://home.comcast.net/~sbernardi/elec/og2/og3_sine_suboctave.html
The last page of this pdf has a simple one or two octave subOsc schematic..
http://www.synthdiy.com/files/2001/madm.pdf
...and then there is this snippet posted below... might need to dress it up a bit... it's pretty bare.
bruce
 Filesize:  10.36 KB
 Viewed:  339 Time(s)
www.sdiy.org/rfeng
isak
PostPosted: Fri Feb 12, 2010 12:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi RF and thanks for the info Smile
can i use the first link in the soundlab plus ? i mean to connect it to the pcb somehow..?
did you made the sub with a stripboard?
can u please upload the stripboard diagram? (if u did)
million thanks RF Smile
Isak.
RF
Audio files: 28
PostPosted: Fri Feb 12, 2010 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi isak -
I just built it on perfboard....sorry.
I'm certain you could build it into your Soundlab - You probably want to be able to switch it in or out, right?
Take a look at the instructions on MFOS for patching out your Soundlab.
bruce
www.sdiy.org/rfeng
isak
PostPosted: Sat Feb 13, 2010 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi bruce and thanks for u'r reply.
i will look and try to understand how do it.
thanks again,
Isak.
