Wiring up my first two modules
Page 1 of 1 [3 Posts]
Appliancide*
PostPosted: Thu Jan 28, 2010 4:24 pm    Post subject: Wiring up my first two modules
Subject description: Wiring advice needed
I have two sn voices ready to be wired up. Is ribbon cable ok or do I need twisted sets of wires for each pot/jack?
thanks,
Paul
http://appliancide/blogspot.com
mark_olson
PostPosted: Thu Jan 28, 2010 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
You don't need to do the twist.
If you are using connectors of some kind that makes it make sense to use ribbon cable it will be fine.
I just used stranded wire, a lot of it Smile
Good luck,
Mark
Danno Gee Ray
PostPosted: Thu Jan 28, 2010 7:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wire size requirements are a function of current running through them at a given voltage. You will likely be dealing with milliamps at low voltage DC. Ribbon cable should be ok.
