WSG too high pitched
Page 1 of 1 [2 Posts]
danoaks15
PostPosted: Fri May 29, 2009 7:19 am    Post subject: WSG too high pitched Reply with quote  Mark this post and the followings unread
Hello,
I finished building my WSG today and when I turned it on, both of the weird oscillators were so high pitched that it was barely audible. When I turn the wacky too function on, I can hear the two wacky oscillators and when I turn on the wackiness I can hear a tone.
I am pretty sure that all of my wiring is correct and I am not sure what to do.
Thank you,
Daniel O'Keefe
Wizard Mike
PostPosted: Fri May 29, 2009 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Double check all of your capacitors. I encountered a problem similar to this on a piece I built last year. I eventually changed out a few caps few one with a higher tolerance and the problem went away. It is at least a good place to start looking.
