PCBs for a Sequential Analogue Switch
Page 3 of 7 [170 Posts]
PostPosted: Sun Apr 19, 2009 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
i just made a very short sample of the switch in audio range. it is set up as follows: the triangel and sine outputs of my TH8038 VCO are routed to I/O 1 & 2 of the switch that is set to 2 step mode.
1st i switch manually, then i switch with a 2nd VCO/LFO, which is controlled by another LFO then (falling sweeps). after that i clock the switch by the TH8038 VCOs square output, then divided by 2, then by 4 (using my simple clock divider).
http://www.modular.fonik.de/sound/SeqSwitchaudio.mp3
(846kb)
Posted Image
LektroiD
PostPosted: Sun Apr 19, 2009 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Drool!
Is the 'zipper noise' avoidable, or is that the point of the module?
LektroiD
TekniK
PostPosted: Sun Apr 19, 2009 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
LektroiD wrote:
Drool!
This module is mainly used to switch between voltage sources,not audio.
U can use it for audio in switched sequence but then those 'tiks' u get on top of it are normal.
thanks Matt for the demo,and bringing this simple but wonderfull usable module
Funky40
G2 patch files: 5
PostPosted: Sun Apr 19, 2009 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I take three Boards,
and thanks !
Funky40
G2 patch files: 5
PostPosted: Sun Apr 19, 2009 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
there are a lot of DIY-boards out there without any standard headers... so "something is better that nothing"?!
when ever possible i don't build boards without PSU Headers.
btw.:
the dotcom connector can use the pads from one row of the doepfer Header,
you just need to place a sixt pad, and you must change the Ground plane on that row
---> dotcom has the Ground only on one pin, and +5V on a pin that goes to Ground if not changed a little bit.
dotcom pinout:
V+
NC ....( Grnd on doepfer)
+5V...( Grnd on doepfer )
Grnd..( Grnd on doepfer )
V-
NC ( ok, not really necessary )
PostPosted: Mon Apr 20, 2009 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
okay then... now almost everyone should be fine, i think. i added the MTA-156 connector and modified one row of the euro-style ribbon connector to comply with the dotcom standard. the footprints for the beads now have a .039 drill.
 Filesize:  56.08 KB
 Viewed:  1121 Time(s)
Posted Image
xpmtl
PostPosted: Mon Apr 20, 2009 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
banana
Thanks matthias Very Happy
http://sdiy.xpmtl.net
PostPosted: Mon Apr 20, 2009 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
i am taking advance orders until 3 MAY 09
then i will send the files to the manufacturer
PRICING:
each PCB 9.-USD/7.-EUR
+ packaging & postage:
1 PCB 4.-USD, more than 1 PCB 8.-USD worldwide
3.- EUR europe
2.- EUR deutschland
PCBs should be available mid-may, i guess.
Posted Image
KrIVIUM2323
PostPosted: Mon Apr 20, 2009 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Count me in for 2 boards please.
Thanks Matthias.
PostPosted: Mon Apr 20, 2009 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
BTW, all who indicated interest in this thread so far are on the list. i don't think it is necessary to PM all of you before the boards are in...
however, don't hesitate to contact me in via forum, PM, e-mail or whatever.
Posted Image
adambee7
PostPosted: Mon Apr 20, 2009 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll take 3 please. Very Happy
Funky40
G2 patch files: 5
PostPosted: Mon Apr 20, 2009 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, thats cool ! i use dotcom headers banana afro thanks !
Matthias, please change my order to 4 Boards
bubblechamber
PostPosted: Mon Apr 20, 2009 7:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi matthias-this looks great. put me down for 2. thanks.
david
You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same.
simmeau
PostPosted: Mon Apr 20, 2009 11:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll update my order to 2 boards thanks.
PostPosted: Mon Apr 20, 2009 11:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
you're welcome.
Posted Image
fluxmonkey
PostPosted: Tue Apr 21, 2009 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
2 for me, please and thank you!
bbob
www.fluxmonkey.com
billy pilgrim
PostPosted: Sun Apr 26, 2009 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll tke 1 board, thanks...
... billy pilgrim
Luka
PostPosted: Tue Apr 28, 2009 2:37 am    Post subject: Reply with quote  Mark this post and the followings unread
matthias did you have a BOM for this?
just doing some ordering now
problemchild
melbourne australia
PostPosted: Tue Apr 28, 2009 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
here's the raw, unedited BOM. hope that helps. the actual building docs will be published before i mail out the boards.
SeqSwitchBOM_raw.pdf
 Filename:  SeqSwitchBOM_raw.pdf
 Filesize:  45.65 KB
 Downloaded:  1552 Time(s)
Posted Image
DGTom
PostPosted: Thu Apr 30, 2009 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Please put me down for 2 boards as well Very Happy
gwaidan
PostPosted: Thu Apr 30, 2009 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Please put me down for 2 boards!
dave_3283
PostPosted: Thu Apr 30, 2009 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I would like two.
Thanks-
dave
LektroiD
PostPosted: Thu Apr 30, 2009 4:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Paid for one board. Looking forward to yet another quality project.
Many thanks.
LektroiD
303monkey
PostPosted: Sat May 02, 2009 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'll be up for two
LektroiD
PostPosted: Sat May 02, 2009 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
PRICING:
3.- EUR europe
2.- EUR deutschland
I think I may have read this wrong... I paid for one + shipping already, using the paypal address I already have for you, is that ok?
LektroiD
