Coming up on Radio 1 at
 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - interactive
realtime sequencing
Page 1 of 1 [4 Posts]
3phase
G2 patch files: 141
PostPosted: Thu Oct 21, 2004 11:44 am    Post subject: realtime sequencing Reply with quote  Mark this post and the followings unread
Some more out of the 3phase sequencer kitchen.. i realy would prefer to patch sounds again... Sad
DudelQuenz.prf2
 Filename:  DudelQuenz.prf2
 Filesize:  4.45 KB
 Downloaded:  2151 Time(s)
3phase
G2 patch files: 141
PostPosted: Thu Oct 21, 2004 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
It really sucks to post patches on the forum... i never get it to have multiple attachments and it needs hours...
RealQuencer BSE.prf2
 Filename:  RealQuencer BSE.prf2
 Filesize:  8.96 KB
 Downloaded:  2211 Time(s)
3phase
G2 patch files: 141
PostPosted: Thu Oct 21, 2004 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
And actually i got the impression that it stops the list activity as a patchers place...
There are hundereds of listmembers and only 3 post patches there...a view more here...but you dont see them because you have to look thru all subcattegories..
It was much more fun in earlier times to recieve a bunch of patches during the week automatical..that was inspiring because you tried them with a quick click...and sometimes you found gold ..like the gorgeous Mr Singer patches...
DoubleQquencer.prf2
 Filename:  DoubleQquencer.prf2
 Filesize:  16.91 KB
 Downloaded:  2099 Time(s)
3phase
G2 patch files: 141
PostPosted: Thu Oct 21, 2004 12:44 pm    Post subject: Add Info Reply with quote  Mark this post and the followings unread
The DudelQuenz is a simple try or an earlie stage for the bigger versions... but it records permanently and dudels with you...
A feature that was rather difficult to implement in the bigger gatetime able seqencers... I havent posted such a version because i havent finshed it yet.
The Realquencer is supposed to be a monophonic realtime sequencer..
16th resolution... But it only retriggers on note changes or after a 16th gap...
so multiple 16th on the same pitch will end as one long note...
I might improove that in the future...but the whole thing is rather expensiv allready...play octaves when you need multiple 16th on the same pitch.
In the moment it is set to 3 voices because dependent on the play technic (dont hit all keys of a chord at once, but within one 16th, just a bit loose) it really records polyphonic..but you cant store or edit that or change variations...
So to analyse and use the real thing set it to mono...
I posted it in poly to show this interesting behaviour.
Pitchstick to the right records/erases... Pitchstick to the left enables keytranspose (in poly mode rather irritating but nice...for a real transpose you have to press the desired key 3times quickly on 3 voice polyphony...but it can be fun to grab a chord as transpose source)
The double quencer is a rather complikated try.. Slot B can add and overide to the seq in slot A..
The sequencers are monophon but can trigger 3 notes simultaniously...
On certain settings nothanging can occur during variation changes..
especially when both sequencers adress the same midichannels or midichannels get switched in a variation change
the panic button helps...
regards
Sven
