 Forum index » Clavia Nord Modular » G2 Patches - Completed » FX
Naive question about a factory patch
Page 1 of 1 [7 Posts]
ark
G2 patch files: 31
PostPosted: Sat Jan 31, 2009 4:10 pm    Post subject: Naive question about a factory patch
Subject description: Bank 1, patch 124, "Delicate Noise1"
Attached is the patch as distributed by Clavia.
As distributed, this patch makes no sense to me, because the Bode Shift module outputs go unused and the X-fade module uses only one of its inputs.
So as it stands, it seems to me that the Bode Shift module could be removed entirely without affecting the patch, and the X-fade module is essentially a volume control.
But if we connect the Up output of the Bode Shift module to input 2 of the X-fade, that seems to add some interesting sonic possibilities.
I am wondering whether someone more familiar than I with this patch knows whether that was what was intended in the first place.
delicate noise1.pch2
G2 factory patch
 Filename:  delicate noise1.pch2
 Filesize:  1.77 KB
 Downloaded:  2081 Time(s)
Former site admin
Audio files: 353
PostPosted: Sat Jan 31, 2009 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing you had already posted this, I deleted the other one.
ark
G2 patch files: 31
PostPosted: Sat Jan 31, 2009 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Odd... as far as I know, I posted it only once.
Audio files: 43
G2 patch files: 626
PostPosted: Sat Jan 31, 2009 6:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't look at the patch but it may be one produced before the frequency shift module was changed. It had a built in xfade in early OS versions.
Former site admin
Audio files: 353
PostPosted: Sat Jan 31, 2009 6:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, weird, don't know what happened, but your attachment doesn't work either ... could you try to upload it again please?
ark
G2 patch files: 31
PostPosted: Sat Jan 31, 2009 7:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have refreshed the original post and checked that it works now.
Former site admin
Audio files: 353
PostPosted: Sat Jan 31, 2009 8:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
it is an older patch ...
Code:
Version=Nord Modular G2 File Format 1
Type=Patch
Version=22
Info=BUILD 192
in 2004 I saved patches, first as
Code:
Type=Patch
Version=19
Info=BUILD 146
but later as :
Code:
Type=Patch
Version=22
Info=BUILD 202
So the patch was made with a version that was current somewhere in 2004 I'd guess, giving room for Ian's hypothesis.
