non-realtime FFT
Page 1 of 1 [5 Posts]
fabb
PostPosted: Sat Dec 13, 2008 7:21 am    Post subject: non-realtime FFT
Subject description: sndbuf as uana?
hey there!
i'm trying to abuse chuck for non-realtime tasks. i want to fft a wav file, do some freaky stuff, ifft it again and save the result as wav to the disk + play it.
problem with this is that fft seems to only accept incoming samples being chucked realtime from sndbuf.
any chance to upchuck sndbuf's whole content to a uana like fft?
thanks,
fabb
Kassen
PostPosted: Sat Dec 13, 2008 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure I understand what you are trying to do, wouldn't the "--silent" flag, do? "--silent" makes ChucK calculate as fast as it can, regardless of real time, this can be a good way to calculate stuff very quickly or it can be a method to generate audio that would otherwise take too much power for your CPU.
Kassen
fabb
PostPosted: Sat Dec 13, 2008 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
ohohooo, thank you very much!!
i didn't think it makes much sense to read through these parameters when using miniaudicle... how wrong i was Smile
Kassen
PostPosted: Sat Dec 13, 2008 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm, I'm not sure how the Mini would work with the silent flag, Starting a VM with "--loop --silent" will do nothing, as fast as possible, leading to 100% CPU usage for indeterminate amounts of time.
Maybe we need a interface for that, some way of expressing we only want the VM to run in silent mode in the Mini for as long as it takes to render/calculate our code. I'm not sure what that would look like; I use the comandline version when I need to render.
Kassen
fabb
PostPosted: Sat Dec 13, 2008 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
no problem for me to use the commandline for this purpose here.
