NL 2x 110 -> 220v
Page 1 of 2 [42 Posts]
Valter
PostPosted: Wed Oct 22, 2008 12:59 am    Post subject: NL 2x 110 -> 220v Reply with quote  Mark this post and the followings unread
How?
I bought nord in usa..
Thanks Smile
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Oct 22, 2008 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome Valter
Open the red hood (4 screws at the back - at the sides just the ones in the front, not the ones with the washers, just untighten these a little and two at the button, right under the ModWheel and the other halfway)
Open it and just beneath the long fuse holder you'll find a switch 120 - 240. Set it in the right position.
Then you have to change the fuse also. Search this forum which value. I'll search too Smile
Wout
Valter
PostPosted: Wed Oct 22, 2008 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Oct 22, 2008 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Found the values...
Europe: 220V 125mA
USA: 110V 250mA,
both slow blow
Wout
WornVillain
PostPosted: Wed Oct 22, 2008 6:57 pm    Post subject: Changing from 240 to 110
Subject description: NordLead 2x
Hey dude's. I have a very similar issue.
I've just moved to America from New Zealand and I have brought my NordLed 2x with me. Do I basically have to do the same thing just the other way? Now, I have never soldered or changed fuses before in my life. I'm actually a beginner at all this high tech stuff, but with time I hope I'll get into the swing of things. If you guys or anybody could let me know what to do I would be very very greatful.
Cheers dude's
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Oct 22, 2008 10:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome WornVillain
I'll make a sticky post about this today, but indeed, it's the other way around.
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Oct 23, 2008 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
See the sticky thread in this forum!
Wout
WornVillain
PostPosted: Thu Oct 23, 2008 8:31 am    Post subject:  NL 2x 230 -110
Subject description: Soooo Rad
Valter..... You are a king among men!!!
I'm gonna have a go at it today. Thank you so much.
1 more thing dude. My power adaptor that came with my NL 2x is (I think) the european style adators. Which reads on the adaptor 2.5A 250V. It has 2 straight out prongs (please forgive my poor description). Which came with a small NZ adaptor on it. Would I be right in saying that after I sought out the voltage/fuse change on my NL 2x that all I have to do is buy a simple USA adator to go the European style plug? I have seen them at a place called radioshack here. Or will I have sort something else out!
Hopefully this makes some sense. Cheers dude
WornVillain
PostPosted: Thu Oct 23, 2008 8:33 am    Post subject:  Sorry! Reply with quote  Mark this post and the followings unread
Sorry about that Valter. I got names mixed up and I actually meant to thank Wout Bloomers. Sorry Wout!
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Oct 23, 2008 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Valter is Wout's middle name
Cool
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Oct 23, 2008 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout is short for Wouter, which means the one who uses force (some kind of a Hulk Wink and is the same as... Walter, Wolter, and... yes... Valter Smile
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Oct 23, 2008 3:02 pm    Post subject: Re: NL 2x 230 -110
WornVillain wrote:
... Would I be right in saying that after I sought out the voltage/fuse change on my NL 2x that all I have to do is buy a simple USA adator to go the European style plug? I have seen them at a place called radioshack here. Or will I have sort something else out!
Just use the adapter. I don't have a NordLead2X, but I assume it has a separated power cable. Isn't it possible to get a new cable using the right connection plugs?
Wout
WornVillain
PostPosted: Thu Oct 23, 2008 5:51 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Where I'm staying at the moment is like the movie Deliverence dude. I went to the local music store here and asked them for help and - A. they barely understood my accent (which I can kinda understand) B. They didn't know what I was talking about when i said Nord or Clavia until I said the "bright red" keyboards - C. They were kinda rude!
So until I get of here I gotta find other ways to do things ya know! Which this forum is already helping out thanx to its fine community!!!
I let ya know if I blow up all my gear. Haha!
t0pc4t
PostPosted: Fri Oct 24, 2008 12:09 am    Post subject: Reply with quote  Mark this post and the followings unread
if you don't want to take the cover off your nord I am pretty sure you can get a device to sit between the socket and the plug to take care of the voltage conversion.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Oct 24, 2008 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Accent? What accent? I don't read any accent! Wink
- B. They didn't know what I was talking about when i said Nord or Clavia until I said the "bright red" keyboards
Yep! What's that called (nervously clicking fingers) That car... That red one... Ferrari!, Yeah!
Remember my name Wink
I added some more info with pictures on the sticky thread.
http://electro-music.com/forum/topic-29716.html
Wout
WornVillain
PostPosted: Fri Nov 07, 2008 1:57 pm    Post subject:  Finally
Hey Wout. Just got back from sight seeing/looking at places to live here and are about to get into my NLD2X!!!
Went down to the local RadioShack to get a fuse. I had taken my fuse which reads, 125ma - 250V, and told them I needed 115/125V - 250ma. Is that correct? They basically tried to sell me the exact same thing even after I told them that mine was not broken. They also said that what I actually needed was a 0.25ma 250V. And also that they had never heard of one like that Evil or Very Mad
They did how ever have a plug, which is exactly like mine but for america. Which is 10amps and my original is only 2.5amps. Would that be ok once everything is sorted? i hope you aint getting sick of me yet Laughing
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Nov 07, 2008 5:36 pm    Post subject: Re: Finally
WornVillain wrote:
... They did how ever have a plug, which is exactly like mine but for america. Which is 10amps and my original is only 2.5amps. Would that be ok once everything is sorted? i hope you aint getting sick of me yet Laughing
Are still talking about the fuse? 10 Ampere is by no way 250 milliAmpere...
Wout
Former site admin
Audio files: 353
PostPosted: Fri Nov 07, 2008 6:12 pm    Post subject: Re: Finally
WornVillain wrote:
[...]and told them I needed 115/125V - 250ma. Is that correct?
Yes that is correct. The voltage of the fuse doesn't matter as long as it's more than 110 V it's OK. What does matter is the 250 mA bit and the size of course (the thing must fit) and that the fuse is a slow blow (T) type.
It is of course possible that the shop folks never heard of such a thing, but this is a bit odd for a shop selling electronics.
A 10 A rating for a power cable/plug is no problem, as long as it fits. The rule here is that there is a minimum Amperage for the cable/plug only (except that higher rated cables/plugs are thicker/larger and get impractical for really high current (Ampere) values).
WornVillain
PostPosted: Fri Nov 07, 2008 7:29 pm    Post subject:  God I'm useless at these things! Reply with quote  Mark this post and the followings unread
Hey dudes.
Yeah wout, I was talking about my power cable/plug. the one I purchased fits into my NLD2X but was worried about the readings on it as it was different to my original. I also got a usa adaptor just as a back up as well. Is there any specific 1 I should use dudes? My original power cable with the adaptor or the new power cable?
Thanks alot for helping out too Blue Hell. Pretty much all their fuses were 250V. I got confused as they were all like, 1.0a, 1.5a, 2.0a etc etc and I was looking for one stating 200ma, 250ma etc. The fuses I was looking at were all the same size as the one in my NLD2X. Ok. Would I be right in getting a fuse that is 250V - 2.5a or 0.25a? Sorry to be a pain in the ass dudes Laughing
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Nov 08, 2008 12:19 am    Post subject:  Re: God I'm useless at these things!
Subject description: Well, everybody has his good side
Ah! The power cable! Well, I was just tired playing the double bass yesterday evening, so I misunderstood. Gladly there's always Blue Hell Cool
0.25A = 0.250A = 250mA.
2.5A = 2.500A = 2500mA.
Any clue? Wink
My idea of that kind of pain is really something else Very Happy
Wout
Keyboard Cowboy
G2 patch files: 4
PostPosted: Sat Nov 08, 2008 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Wout,
I'm having a similar problem to the posts from Nord Lead 2X owners above. I bought a 2X off eBay that appears to be from the United States. I am in the United Kingdom and want to use the keyboard here. The voltage information at the back of the keyboard looks like this:
Posted Image
The fuse inside the keyboard looks like this:
Posted Image
The fuse also states:3/10A 250V 313
I have followed your instructions in the tutorial by opening up the keyboard and changing the switch from 115V to 230V. Please tell me - is this the correct fuse to be using or should I be using something else?
 Filesize:  110.43 KB
 Viewed:  232 Time(s)
 Filesize:  164.85 KB
 Viewed:  247 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Nov 08, 2008 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I assume you've been in the sticky thread already?
If so you know the fuse is only the end of the story...
3/10A means 'three-tenth Ampère' or 0.3A = 300mA
Change it to 230V - 125mA (or 150mA), after you set the internal switch richt!
Wout
Keyboard Cowboy
G2 patch files: 4
PostPosted: Sat Nov 08, 2008 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Wout - yes I did read the sticky topic on this, but the fuse I had was not marked in a language I could understand.
I have since gone to the electrical shop up the road from me and gave them your fuse recommendation - the gave me a 230V 150mA fuse, but it was smaller than the original one. The guy said it would still work.... Well, I fitted it in the keyboard and it's still not lighting up. Would the size of the fuse make a difference even if the the specs are correct?
Former site admin
Audio files: 353
PostPosted: Sat Nov 08, 2008 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Apparently Wink
You can just put in the old fuse as long as you don't have a fitting one, the old one has too large a value not giving full protection in the case of a device malfunction, but it will work.
Keyboard Cowboy
G2 patch files: 4
PostPosted: Sat Nov 08, 2008 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Blue Hell - thanks for your advice, though not sure what you mean by I can use the old one? The old one has the incorrect ampage.
I've attached this image to show you the size of the fuses. The new 150mA fuse is on the right and the old incorrect one is on the left. The new one doesn't fit properly in the holder as it's too small. Should I be looking for a fuse the same size as the old one? Can anyone point me in the right direction to find the exact fuse that I need?
 Filesize:  244.66 KB
 Viewed:  258 Time(s)
