loss1234
RF
Audio files: 28
Posted: Fri Aug 08, 2008 9:26 pm Post subject:
Hi loss1234
If you check the earlier picture I posted - that is pretty much the patch - although I had been moving a couple of the patch cords... and changing the clock speeds...and it changed into that output. I can't tell you exactly what was happening off the top of my head - but here's what was patched.
The top left of the case are 40106 osc's patched into the Data and Clock input of a 4094 8 stage Shift Register (2nd module from left). Next module to the right is a dual 4015 4 stage shift register. The horizonatal panel on the bottom is a 555 based VCO and 6 40106 clocks - I'm using one of those to clock the 4025 divider/Sub Osc. (4th Module from the right)
Some of the outputs from those modules are are patched into the far right hand module - which is an R/2R Ladder. Output from the ladder is a CV voltage sent to a 555 based simple VCO.
That's about all there was going on there.
Hope that helps a little - just start patching til something happens.
I've got another patch going right now that just keeps morphing as I move a patch cord or change the clock speed... at times its very cool...other times kind of annoying.
Good luck!
bruce |
loss1234
Posted: Sun Aug 10, 2008 8:48 am Post subject:
"- I'm using one of those to clock the 4025 divider/Sub Osc"
you are using a 4025 or a 4024? you mentioned it both ways.
also, i count 5 modules plus the lower clock/555 module.
let me see if i get the order
1 is 40106
2 is 4098
3 4015
4 4024 (you say 4th module from the right...but i thought the 4015 was the 3rd module?)
blank panel
5. r2r
bottom is more 40106's and 555???
i am sorry for being a pain but i think if i can understand your patch, i will be able to understand more about how to make my own permanent lunetta
it sounds like you are going
40106 into 4098
4098 into 4024 or
4024 into R2r
r2r into cv in of 555
and 40106 into 4015
4015 into ???
i just am not sure where the 4015 is coming in or what the 4024 is doing.
also, are you using a mixer or just taking an out straight from the 4024?
thanks _________________ -------------------------------------------- check out various dan music at: http://www.myspace.com/lossnyc
http://www.soundclick.com/lossnyc.htm http://www.indie911.com/dan-snazelle |
loss1234
RF
Audio files: 28
Posted: Sun Aug 10, 2008 11:33 am Post subject:
Hi Dan -
It's 5 volts for the logic - although I do have +- 12 volt for a couple op amps I have in there.
I will post the specifics I have in the case a bit later... I'm off to the lake for a few hours of sailing
bruce |
loss1234
RF
Audio files: 28
loss1234
Posted: Sun Aug 10, 2008 10:07 pm Post subject:
it helps a lot!!
thanks for taking the time to help me out
i have built almost ALL of these modules separately on the breadboard at one time or another but I need TO GET busy making them permanent because obviously, the sum is worth more than the parts!!!
i have been playing around with the external voltage in on cmos chips myself lately and its wild!
also, that 4051 is a great chip!
i love your suitcase setup. this might be just the way to keep my wife from complaining about space!
anyway...off to test some of this out
thanks thanks thanks _________________ -------------------------------------------- check out various dan music at: http://www.myspace.com/lossnyc
stolenfat
Joined: Apr 17, 2008 Posts: 476 Location: Sunny Oakland California
Posted: Sun Oct 12, 2008 9:11 am Post subject:
oh man, how did i miss this forum. very very very cool, very very inspiring
Question though, i noticed in that suitcase set up you have a 4011 ring mod, could i look at a schematic? |
RF
Audio files: 28
stolenfat
Posted: Mon Oct 13, 2008 7:40 pm Post subject:
so with this schematic, you could technically set up 2 ring mods, with 4 inputs using pins 1,2,5,6,8,9,12,13?
If so, best ring mod schematic i've found yet. |
aerogramma
Joined: Feb 27, 2008 Posts: 156 Location: Roma, Italy - London, UK
Audio files: 15
RF
Audio files: 28
Posted: Thu Oct 23, 2008 5:29 am Post subject:
Thanks for the clip! It's great to hear what you are up to.
Isn't that Mankato a nice filter?
You mention trying to get sine waves - how are you going about trying that? What sort of sucess are you having?
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
aerogramma
Audio files: 15
synthmonger
Posted: Thu Nov 20, 2008 1:45 am Post subject:
Here is a sample of two of my 40106 vco's been driven by one of my 4024 pattern generators.
Some parts get a tad bit boring, so you should download it and skip around. ;D
EDIT: forgot to mention this was recorded on the fly with just random knob twiddlin' and switch flippin'. _________________ Youtube!
modular demos!
Whacky tunes! Last edited by synthmonger on Sun Jun 07, 2009 9:12 pm; edited 1 time in total |
RF
Audio files: 28
Posted: Thu Nov 20, 2008 6:11 am Post subject:
Great to hear some more Lunetta's! Thanks for posting that.
I liked the stereo bits - I need to do some of that with mine.
Joined: Jan 31, 2003 Posts: 18506 Location: Durham, NC
Audio files: 266
Posted: Thu Nov 20, 2008 1:27 pm Post subject:
| synthmonger wrote: | | ecorded on the fly with just random knob twiddlin' and switch flippin'. |
Sounds great to me...
Lunetta's seem to always have a happy sound. Anyway, I can't tell you how happy it makes me to hear such sounds.  _________________ --Howard
my music and other stuff |
synthmonger
Posted: Fri Nov 21, 2008 1:01 pm Post subject:
| mosc wrote: | | synthmonger wrote: | | ecorded on the fly with just random knob twiddlin' and switch flippin'. |
Lunetta's seem to always have a happy sound. Anyway, I can't tell you how happy it makes me to hear such sounds.  |
Glad ya like it Mosc!  |
telstarmagikistferrari
Joined: Jun 16, 2008 Posts: 280 Location: Indianapolis, Indiana
Audio files: 43
Posted: Tue Nov 25, 2008 8:28 am Post subject:
Great thread. lunetta1_184.mp3 is inspiring and entertaining. I love the idea of just letting stuff run and letting the circuit you designed surprise you.  |
Lofi Ninja
Posted: Sat Nov 29, 2008 12:17 pm Post subject:
The 2N5172 NPN transistor in that schematic can it be replaced by something else? Like say BE357/BE347/2N3904 ? |
slacker
Posted: Sat Jan 03, 2009 6:44 am Post subject:
Here's a quick clip of something I was messing about with last night.
Lunetta clip
It's just some oscillators clocking a little note generator made out of a 4017 and 4051. It's basically the multidivide from this thread http://www.electro-music.com/forum/topic-28792.html but using clocks on the data pins instead of switches. The ENA and INH pins can also be used for different sounds. |
Audio files: 353
Posted: Sat Jan 03, 2009 7:14 am Post subject:
| slacker wrote: | | Here's a quick clip of something I was messing about with last night. |
Nice one! |
RF
Audio files: 28
Posted: Sun Jan 04, 2009 9:01 am Post subject:
Yea - That's the stuff! Post some more!
Audio files: 43
Posted: Sun Jan 04, 2009 8:57 pm Post subject:
thanks.. i love those crispy sounds!
mark
slacker
Posted: Mon Jan 05, 2009 1:39 pm Post subject:
Thanks for the comments.
Here's another clip
The 2 sections are the same setup just patched differently, bit of knob twiddling at the end.
Really enjoying messing around with these things  |
