widdly
Posted: Thu Apr 10, 2008 12:11 am Post subject:
Keeping different looped parts in sync |
Hi, I'm wondering how people go about playing/editing different parts and keeping them synced. "Replace Shred" is no good because it just starts anywhere.
I've worked out a system using machine.add and different files. This way I can edit each file and when I save the next loop will play the new file. I don't think this is a good system because of all the disk file reading going on, especially for small loops.
Is there some way of using events to do this?
Here's an example of my method. Load the loop.ck and it will do the rest. You can edit the other files independently.
| Description: |
 Download (listen) |
| Filename: |
loop.ck |
| Filesize: |
110 Bytes |
| Downloaded: |
319 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
kick.ck |
| Filesize: |
611 Bytes |
| Downloaded: |
355 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
hihi.ck |
| Filesize: |
555 Bytes |
| Downloaded: |
324 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
drum_mach.ck |
| Filesize: |
1.28 KB |
| Downloaded: |
345 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
snare.ck |
| Filesize: |
694 Bytes |
| Downloaded: |
319 Time(s) |
widdly
Kassen
Posted: Thu Apr 10, 2008 12:15 am Post subject:
Re: Keeping different looped parts in sync |
| widdly wrote: | Hi, I'm wondering how people go about playing/editing different parts and keeping them synced. "Replace Shred" is no good because it just starts anywhere.
Hi, Widdly!
Have a look at the "otf" examples in the /examples/ dir, there are 6 of those that can be run together, started at any moment and they'll sync up in a really cleaver way, check it out.
(hint, the percentage (%) sign refers to "modulo") _________________ Kassen |
widdly
widdly
Posted: Thu Apr 10, 2008 3:12 am Post subject:
Any tricks for removing shreds in sync?
I'm thinking you could write a file that takes a shred id as an argument then removes the shred using the modulo time trick.
if ( me.args() == 1)
me.arg(0)=>string text;
Std.atoi(text) => int shred_id;
.5::second => dur beat;
8::beat => dur bar;
bar - (now % bar) => now;
Machine.remove( shred_id );
} Last edited by widdly on Thu Aug 05, 2010 10:15 pm; edited 1 time in total |
radarsat1
Posted: Fri Apr 11, 2008 9:55 am Post subject:
for keeping in sync i usually have a common clock based on broadcast events. each of my loops waits for a clock signal with a certain modulo before starting.
for removing i just try to time it by ear, or turn down the volume on that shred first. |
widdly
Posted: Fri Apr 11, 2008 8:17 pm Post subject:
How do you turn down the volume on an individual shred? Last edited by widdly on Thu Aug 05, 2010 10:15 pm; edited 1 time in total |
Kassen
Posted: Sat Apr 12, 2008 5:03 am Post subject:
| Code: | Gain master_fader => dac;
stuff => master_fader;
more_stuff => master_fader => dac;
.5 => master_fader.gain; |
Where "stuff" refers to the Ugens you are using. _________________ Kassen |
radarsat1
Posted: Sat Apr 12, 2008 9:05 am Post subject:
| exactly. in other words, you just program the shred so you can turn it down. i do a lot of my chuck control over OSC and MIDI, so "turning down the volume" amounts to turning a physical knob to the left. |
