ian-s
Audio files: 43
G2 patch files: 626
Posted: Mon May 10, 2004 8:09 pm Post subject:
bounce |
Here is a Nord G2 variation on the Bouncing Ball effect discussed elsewhere. It does not use samples because us poor old G2 people have to synthesise everything from scratch (luckily, that's what I prefer to do anyway).
Basically, an incoming trigger from the keyboard kicks off a series of triggers, which also clock a binary counter/DAC combination, which is used to shorten the time between triggers. When the time 'decays' to shorter that the Min_ms pulse time, the triggering stops.
OK it's a little silly but fun to play.
BTW Howard, how do I put images in the body of the message?
43.1 KB |
| Viewed: |
14354 Time(s) |
 Download (listen) |
| Filename: |
bounce.pch2 |
1.92 KB |
| Downloaded: |
2591 Time(s) |
Joined: Jan 31, 2003 Posts: 18516 Location: Durham, NC
Audio files: 266
Posted: Mon May 10, 2004 8:34 pm Post subject:
Cool...
To put images in the body of a message the image must be uploaded to a web site. Then, just type in the URL of the image and use the IMG, LEFT, or RIGHT tags.
If you don't have a web site to upload images to, then you are stuck with doing what you did, attach the image with the attachment mechanism. |
AngusHastie
Joined: Aug 04, 2004 Posts: 136 Location: London, England
Posted: Thu Aug 12, 2004 7:50 am Post subject:
bounce |
How do the BinCounter and DAConv modules work? The manual is not much use to the uninitiated. I can probably work out the rest if I understand how these modules funtion.
Angus |
Audio files: 266
Posted: Thu Aug 12, 2004 8:43 am Post subject:
The binary counter is an emulation of a logic circuit. It counts in binary arithmetic. There is a bit for each binary "digit". Hook up an LFO to one and watch the lights (set the LFO at a slow frequency). You'll see an interesting side effect - each output is running at 1/2 the frequency of the previous one.
The DAC, digital to analog converter, takes in 8 inputs and puts out a singal that corresponds to the binary number of the inputs. If you put in the output of a binary counter, then the output of the DAC would be a ramp. |
Kraken
Posted: Thu Aug 12, 2004 9:51 am Post subject:
Salud!
Great info and great effect, thanks a lot. This G2 thing sometimes gets really eldritch. |
AngusHastie
Posted: Thu Aug 12, 2004 10:27 am Post subject:
| What's edlritch? |
Kraken
Posted: Thu Aug 12, 2004 10:37 am Post subject:
Salud!
eldritch (adj.) spooky, unearthly, weird |
cristian
Posted: Fri Aug 13, 2004 7:10 am Post subject:
Eldritch is a cool word.
Whats the Spanish equivalent? Inquieto? _________________ www.no-future.com |
