General Oscillator Base Class
Page 1 of 1 [6 Posts]
Frostburn
Audio files: 9
PostPosted: Tue Mar 18, 2008 1:53 am    Post subject: General Oscillator Base Class
Subject description: with phase, frequency, width and amplitude modulation
I thought about the issue of having a general base class for oscillators. I don't really see the need to have only one sync mode active at a time because they are not mutually exclusive.
I had to use a control loop ticking at samp intervals because phase modulation and frequency modulation are broken with Phasors and width modulation is non existant.
Anyway, here goes:
Code:
class OscBase{
        Gain PM => blackhole;
        Gain FM => blackhole;
        Impulse phaseWarper => Gain phasor;
        Gain WM => blackhole;
        Gain AM => Gain out;
        3 => AM.op;
        //This is bugged:
        //FM => Phasor FMphasor => Phasor PMphasor => phasor;
        //PM => PMphasor;
        //2 => FMphasor.sync;
        //1 => PMphasor.sync;
        phasor => TriOsc triosc => SinOsc sinosc; 1 => sinosc.sync;
        1 => triosc.sync;
        phasor => PulseOsc pulseosc;
        1 => pulseosc.sync;
        220.0 => float freq_;
        0.0 => float phase_;
        0.5 => float width_;
        samp/second => float delta;
        Sin(); //Default SinOsc
        spork~control_shred();
        //Presets:
        fun void Sin(){
                disconnect();
                0.25 => triosc.gain;
                sinosc => AM;
        fun void Tri(){
                disconnect();
                1.0 => triosc.gain;
                triosc => AM;
        fun void Pulse(){
                disconnect();
                pulseosc => AM;
        fun void disconnect(){
                sinosc =< AM;
                triosc =< AM;
                pulseosc =< AM;
        fun void control_shred(){
                while(samp => now){ //Note that this will advance time once before doing anything
                        (FM.last() + freq_)*delta +=> phase_;
                        phase_ + PM.last() - Math.floor( phase_ + PM.last() ) => phaseWarper.next;
                        width_ + WM.last() => triosc.width => pulseosc.width;
        //UGen imitation:
        fun float gain(){
                return out.gain();
        fun float gain(float _gain){
                return _gain => out.gain;
        fun float freq(){
                return freq_;
        fun float freq(float _freq){
                return _freq => freq_;
        fun float width(){
                return width_;
        fun float width(float _width){
                return _width => width_;
        fun float phase(){
                return phase_;
        fun float phase(float _phase){
                return _phase => phase_;
//Plain sinewave:
OscBase sin;
sin.out => dac;
second => now;
sin.out =< dac;
second => now;
//Triangle wave FM modulated by a sinewave
OscBase tri;
tri.Tri(); //Call the preset
tri.out => dac;
sin.out => tri.FM; //Simple enough
300.0 => tri.freq;
tri.freq()*5.0 => sin.freq;
tri.freq()*3.0 => sin.gain;
second => now;
0.0 => tri.width; //Change it to a saw wave
second => now;
//Rape it with ringmodulation
OscBase sqr;
tri.freq()*0.25 => sqr.freq;
sqr.Pulse();
sqr.out => tri.AM;
second => now;
tri.out => Gain PM => tri.PM; //Self phase modulation
0.25 => PM.gain;
second => now;
//Let's try some of that width modulation
0.5 => tri.width; //Center at 0.5
SinOsc widthModulator => tri.WM;
0.5 => widthModulator.gain; //Modulate between 0.0 and 1.0
1.0 => widthModulator.freq; //Not too hastily though
3::second => now;
To boldly go where no man has bothered to go before.
kijjaz
PostPosted: Tue Mar 18, 2008 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow..! This is a very great idea.
I will become handy soon. I see it's gonna be more generalized than the original basic oscillators.
I'm gonna take some more time to investigate into the code also..
and I'll come up with some ideas ^_^"
for now I'm gonna start a "Sine Oscillator made from Gains" hahah
I got the idea from doing the Mass-Spring simulation.
Inventor
Audio files: 270
PostPosted: Tue Mar 18, 2008 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
That oscillator class looks like the perfect thing for Synth Lab. Though I need to understand it better before I can use it. I'll study the code more. I noticed, now that I have Synth Lab up and it is easy to switch oscillators, that modulation doesn't seem to work.
Maybe this is a ChucK bug or a Synth Lab bug, I dunno but if I have a ring of say 3 oscillators, all sine waves and I have them making some funky sound, then I change any of the oscillators the oscillation stops. I can muck around with the sliders all I want and still get no oscillation. Then when I click it around back to sinosc, my oscillation begins once more.
Is modulation broken in ChucK? Maybe this is on the known bug list and I'm just learning about it?
kijjaz
PostPosted: Tue Mar 18, 2008 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm thinking of a way to generalize this but with an existing UGens and very minimal connections:
Here's my idea
(but it's not as extensible as yours)
Step freq => Phasor p => WhateverBasicOscYouHave;
1 => WhateverBasicOscYouHave.sync;
1. set the center frequency by freq.next()
2. any FM.. chuck into p (so it adds to frequency automatically)
3. any PM.. chuck into WhateverBasicOscYouHave
4. if you need phase sync, set p.gain = 0
Frostburn
Audio files: 9
PostPosted: Wed Mar 19, 2008 1:13 am    Post subject: Reply with quote  Mark this post and the followings unread
It's a ChucK bug.
If you give phase modulation outside of the [0.0,1.0] range it wont warp back to it. This breaks every oscillator except SinOsc.
If you do FM and the total frequency is negative it will break everything except SinOsc.
I took a look in to the source and all of the oscillators use the same code, SinOsc just uses Math.sin(...) and it doesn't care if the phase is outside the range.
Code:
//Works fine:
SinOsc m => TriOsc c => dac;
2 => c.sync;
c.freq() - 1.0 => m.gain;
second => now;
//Busted!
c.freq() + 1.0 => m.gain;
second => now;
That's why I have to keep the phase manually in the 0.0 to 1.0 range by invoking foo - Math.floor( foo ) => foo_with_a_bounded_phase.
kijjaz wrote:
Here's my idea
It's a good idea but Phasor is sync bugged too so that'll only work with small modulations.
Inventor
Audio files: 270
PostPosted: Wed Mar 19, 2008 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
A ChucK bug???
Code:
    '-.__.-'
    /oo |--.--,--,--.
    \_.-'._i__i__i_.'
fsc
Oh my!
