Nord Lead 2
Page 1 of 1 [6 Posts]
Fiuza
PostPosted: Tue Feb 26, 2008 9:50 pm    Post subject:  Nord Lead 2
Subject description: My NL 2 is acting up!
Hi everybody,
My Nord Lead 2 is acting up lately.When I´m playing any patch,the sound start changing its filter suddenly without me touching anything.Is there a way I can reinstall the Operating System?I tried to contact Clavia,but they never answered me back.It looks like they aren´t giving any support to discontinued stuff.I really like my NL 2,it´s my favorite synth.I would appreciate it very much if someone could help me with this.
Thank you,
Fiuza
Drone
PostPosted: Tue Feb 26, 2008 10:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did you try & hit the panic button ? Hold down Shift + Distortion & some of the parameters will be reset.
It is at least ten times more difficult to get a good synthesizer sound than on an acoustic instrument. - Giorgio Moroder
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Feb 26, 2008 11:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome Fiuza, all be it with a sad post...
Once I had almost the same problem, but it appeared to be caused by the random setting of LFO1, but it happened only with one sound/Program. If any Program has the same problem, it surely means there is something wrong... Crying or Very sad
If it only shows up at the Filter parameter, it could be the pot is bad. I would bring it to a repair shop to replace it...
Wout
Fiuza
PostPosted: Wed Feb 27, 2008 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Wout!
I tried the panic button and I even tried holding shift and mod env fm osc2 together.The second seemed to work for a bit then the problem persisted.
Anyway,sorry for my english....but what´s the ''pot''?
Sometimes the LFO 1 is acting up too.It slows down suddenly when I use the modulation.Anyway,isn´t it possible to reinstall the OS?
Best,
Fiuza
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Feb 27, 2008 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Fiuza wrote:
... but what´s the ''pot''?
Potentiometer, the variable resistor at the other side of the knob, inside the synth. It's the electronic devise which makes the value of the parameter.
Most likely, when it happens to other parts of the synth, it is your power supply, which doesn't give the right voltage. It could be also instability of the 230/115 Volt of the electricity network, which is doubtful, because it works a long time alright. I think you better take the synth to your repair man.
Fiuza
PostPosted: Fri Feb 29, 2008 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Wout,what up?
Man,I think u're right about the ''pot'',I´ll have someone checking it next week.Thank you very much,I think you saved my good ol' Nord!!!
Best,
Fiuza
