Happy New Year 2008 Patches
Page 1 of 3 [63 Posts]
Goto page: 1, 2, 3 Next
kijjaz
PostPosted: Thu Jan 03, 2008 9:01 am    Post subject: Happy New Year 2008 Patches
Subject description: Let's chuck to celebrate!
Let's share some celebration patches.
I've got this singing patch to sing for you for the New Year:
Code:
Step f => LPF f_f => SinOsc s => LPF s_f => TriOsc ws => PRCRev r => dac;
f_f.set(50, .2);
s.gain(.6);
s_f.set(500, .5);
ws.sync(1);
r.mix(.1);
r.gain(.5);
int A[200];
for(int i; i < 200; i++) maybe => A[i];
0 => int a;
do
    0 => a;
    for(int i; i < 200-1; i++) A[i] ^ A[i+1] * maybe => A[i] +=> a;
    a - 36 => Std.mtof => f.next;
    s.phase(0);
    Math.pow(a, 3)::ms / 4000 => now;
while(a > 10);
another modified one with more folkish behavior.
Code:
f_f.set(100, .2);
s.gain(.5);
s_f.set(500, .5);
ws.sync(1);
r.mix(.1);
r.gain(.5);
int A[20];
for(int i; i < 20; i++) maybe => A[i];
0 => int a;
do
    0 => a;
    for(int i; i < 20-1; i++) A[i] ^ A[i+1] * maybe => A[i] +=> a;
    a + 60 => Std.mtof => f.next;
    s.phase(0);
    Math.pow(a, 3)::ms / 2 => now;
while(a > 2);
Frostburn
Audio files: 9
PostPosted: Thu Jan 03, 2008 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
This one is a bit long:
The sound of the Lorenz attractor controlled by the mouse:
Linux users may need to allow ChucK to acces hid:
Code:
chmod a+r /dev/input/*
Give your mouse's device number to the code as an argument:
For example:
chuck moused_lorenz.ck:1
Opens mouse 1
Code:
//Mouse controlled Lorenz attractor
500.0 => float time_scale; //Time speeds up by this factor... A mock frequency of sorts for the attractor...
time_scale*samp/second => float delta_t; //Define the time step
0.1 => float mouser_scale; //How much an unit movement of the mouse changes the parameter it's bound to.
//Create three integrating circuits using the Euler's method for solving differential equations.
Impulse dxdt => OnePole x => blackhole;
Impulse dydt => OnePole y => blackhole;
Impulse dzdt => OnePole z => blackhole;
delta_t => x.b0 => y.b0 => z.b0;
-1.0 => x.a1 => y.a1 => z.a1;
//Let's hear something!
x => Gain gl => dac.left;
y => Gain gr => dac.right;
0.01 => gl.gain; //Oh my, we're a bit loud aren't we.
0.01 => gr.gain; //Hush!
//dac => WvOut w => blackhole; "foo.wav" => w.wavFilename; //Write the insanity to a file!
//Time. The attractor is time invariant so this is not used; Provided for experimenting purposes.
0.0 => float t;
//Just start somewhere...
0.5 => float initial_x;
0.1 => float initial_y;
0.2 => float initial_z;
//These are the "default" values that make the Lorenz attractor chaotic (making it a strange attractor)
//The mouse is rigged to modify these:
10.0 => float sigma; //modified by the x-axis
28.0 => float rho; //modified by the y-axis
8.0/3.0 => float beta; //modified by the mouse-wheel y-axis
50.0 => float limit; //Contain the attractor in a box to keep it stable.
initial_x/delta_t => dxdt.next;
initial_y/delta_t => dydt.next;
initial_z/delta_t => dzdt.next;
samp => now;
true => int we_are_on;
0 => int mouser_device;
if( me.args() ) me.arg(0) => Std.atoi => mouser_device;
spork~mouser(mouser_device); //Wave the mouse around for sounds!
while(we_are_on){
    //Lorenz attractor definition:
    sigma * ( y.last() - x.last() ) => dxdt.next;
    x.last() * ( rho - z.last() ) - y.last() => dydt.next;
    x.last() * y.last() - beta * z.last() => dzdt.next;
    //Don't overflow:
    if ( Std.fabs(x.last()) > limit ) -x.last() => dxdt.next;
    if ( Std.fabs(y.last()) > limit ) -y.last() => dydt.next;
    if ( Std.fabs(z.last()) > limit ) -z.last() => dzdt.next;
    delta_t +=> t; //Not used for anything at the moment.
    samp => now;
//w.closeFile();
fun void mouser(int device){
    //Modified from /examples/hid/mouse.ck
    // make HidIn and HidMsg
    Hid hi;
    HidMsg msg;
    // which mouse
    //0 => int device;
    // get from command line
    //if( me.args() ) me.arg(0) => Std.atoi => device;
    // open mouse 0, exit on fail
    if( !hi.openMouse( device ) ) me.exit();
    <<< "mouse '" + hi.name() + "' ready", "" >>>;
    // infinite event loop
    while( true )
        // wait on HidIn as event
        hi => now;
        // messages received
        while( hi.recv( msg ) )
            // mouse motion
            if( msg.isMouseMotion() )
                if( msg.deltaX )
                    //<<< "mouse motion:", msg.deltaX, "on x-axis" >>>;
                    mouser_scale*msg.deltaX +=> sigma;
                if( msg.deltaY )
                    //<<< "mouse motion:", msg.deltaY, "on y-axis" >>>;
                    mouser_scale*msg.deltaY +=> rho;
            // mouse button down
            else if( msg.isButtonDown() )
                //<<< "mouse button", msg.which, "down" >>>;
                //If it gets stuck just click on the mouse
                Std.rand2f(-10.0,10.0)/delta_t => dxdt.next;
                Std.rand2f(-10.0,10.0)/delta_t => dydt.next;
                Std.rand2f(-10.0,10.0)/delta_t => dzdt.next;
                samp => now;
                if(msg.which == 1) false => we_are_on; //The right mouse-button turns things off
            // mouse button up
            /*else if( msg.isButtonUp() )
                <<< "mouse button", msg.which, "up" >>>;
            // mouse wheel motion
            else if( msg.isWheelMotion() )
                /*if( msg.deltaX )
                    //<<< "mouse wheel:", msg.deltaX, "on x-axis" >>>;
                if( msg.deltaY )
                    //<<< "mouse wheel:", msg.deltaY, "on y-axis" >>>;
                    mouser_scale*msg.deltaY +=> beta;
moused_lorenz.ck
 Filename:  moused_lorenz.ck
 Filesize:  4.43 KB
 Downloaded:  545 Time(s)
Audio files: 373
PostPosted: Thu Jan 03, 2008 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some pathetic fireworks in the distance. Smile
Code:
Noise noize;
dac;
10 => int VOICE_AMOUNT;
BPF hpfs[VOICE_AMOUNT];
Envelope highEnvelopes[VOICE_AMOUNT];
Pan2 highPans[VOICE_AMOUNT];
for (0 => int i; i < 10; i++) {
   0.002 => highEnvelopes[i].time;
   0 => highEnvelopes[i].value;
   0.2 => hpfs[i].gain;
   noize => hpfs[i] => highEnvelopes[i] => highPans[i] => dac;
fun void moveHPFFreqs() {
   while (true) {
      for (0 => int i; i < VOICE_AMOUNT; i++) {
         hpfs[i].freq() + Math.randf()*0.001 => float freq;
         freq => hpfs[i].freq;
      1::ms => now;
spork ~ moveHPFFreqs();
0 => int nextHighVoice;
Event sprinkleEvent;
fun void sprinkle() {
   while (true) {
      sprinkleEvent => now;
      for (0.4 => float volume; volume < pi / 2.0; 0.02 +=> volume) {
         1.0 => highEnvelopes[nextHighVoice].value;
         0.0 => highEnvelopes[nextHighVoice].target;
         Math.randf() => highPans[nextHighVoice].pan;
         hpfs[nextHighVoice].set(3000.0 +Math.randf()*1000.0 + Math.sin(volume)*1000, 6 + Math.randf()*4);
         if (++nextHighVoice >= VOICE_AMOUNT) {
            0 => nextHighVoice;
         35::ms + Math.randf()*17::ms => now;
spork ~ sprinkle();
LPF lpfs[VOICE_AMOUNT];
Envelope lowEnvelopes[VOICE_AMOUNT];
Pan2 lowPans[VOICE_AMOUNT];
   0.05 => lowEnvelopes[i].time;
   0 => lowEnvelopes[i].value;
   noize => lpfs[i] => lowEnvelopes[i] => lowPans[i] => dac;
0 => int nextLowVoice;
while (true) {
   if (Math.randf() > 0.9) {
      1.0 => lowEnvelopes[nextLowVoice].value;
      0.0 => lowEnvelopes[nextLowVoice].target;
      Math.randf() => lowPans[nextLowVoice].pan;
      lpfs[nextLowVoice].set(100.0 +Math.randf()*90.0, 6 + Math.randf()*4);
      if (++nextLowVoice >= VOICE_AMOUNT) {
         0 => nextLowVoice;
   if (Math.randf() > 0.998) {
      sprinkleEvent.signal();
   10::ms => now;
Edit: Disabled HTML to fix broken code.
Frostburn
Audio files: 9
PostPosted: Fri Jan 04, 2008 3:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Antimon wrote:
Some pathetic fireworks in the distance. :)
Code:
Noise noize;
dac;
for (0 => int i; i <10> highEnvelopes[i].time;
Can't get it to work... even that first 'for' statement seems to be missing a right parenthesis.
It's good practice to preview the post once and copy the code back to ChucK to see if it renders properly.
To boldly go where no man has bothered to go before.
Audio files: 373
PostPosted: Fri Jan 04, 2008 7:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the good practice tip. Embarassed I had forgotten to disable HTML. Sorry about that.
/Stefan
Inventor
Audio files: 270
PostPosted: Wed Jan 16, 2008 10:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
What a cool effect, experiencing science through audio. Nicely done, Frostburn, and nice image too. I suggest adding to the Lorentz attractor so that it attracts blondes and brunettes also. Preferably ones with either straight or wavy hair. When you get that one working you will earn an honorable place among ChucKists indeed.
Inventor
who misses his ChucK buddies alot!
Frostburn
Audio files: 9
PostPosted: Thu Jan 17, 2008 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, your image is a nice one too. Smile
Is it a photo or a ray-trace rendering?
The Lorentz attractor needs no additions. In low frequencies it attracts brown noise (brunettes) and when pitched beyond reason it attracts white noise (blondes). Too bad they don't have hair, be it straight or all wavely.
Inventor
Audio files: 270
PostPosted: Thu Jan 17, 2008 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for asking, Frostburn, my image is a close-up photo of a chainmaille sphere. I created the math that says how many rings per row to make a nearly perfect sphere, so I'm proud of my little creation. It was sort of math meets art and coexists for a change, lol.
Kassen
PostPosted: Thu Jan 17, 2008 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
What? Math & art are fine together! :¬).
Serious mathematicians strive for beauty in proofs and where would painting be without perspective? I don't think there is the slightest issue between them. Without going into fields where it's obvious like our own or architecture to me it's quite clear that all art depends on ratios, the artist may not consciously be treating those like fractions but that doesn't mean there's no math there. Without creativity, on the other hand, you can forget about solving complex issues and without a sense of style you will likely drown in their solution, lot of art in math, I say.
We could do a theme project about the mathematics of beauty and the beauty of equations!
I like the image too, BTW ;¬)
Kassen
Frostburn
Audio files: 9
PostPosted: Thu Jan 17, 2008 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice idea Kassen! Count me in.
Inventor
Audio files: 270
PostPosted: Thu Jan 17, 2008 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll go for that also.
Inventor
Audio files: 270
PostPosted: Thu Jan 17, 2008 10:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here, I have made the first contribution to our math meets art effort. I propose we make a song with the sounds of mathematics in it. In the spirit of songs like "Girls, Girls, Girls" by Motley Crue, I suggest we begin the song with the sound of a revving engine. It is thematic because the musical instrument patches mathematically model the system, and make it sound close to the real thing so the model is a good one. It's math making music with a rock-and-roll flair to it. Should make a nice song intro.
If you agree that we shall make a song, then what do you suppose your contribution will be?
rev_engine_intro.ck
Revs a throaty musclecar V8 from 0 to max along a sinusoidal profile of rpm. Makes a great song introduction.
 Filename:  rev_engine_intro.ck
 Filesize:  520 Bytes
 Downloaded:  422 Time(s)
Inventor
Audio files: 270
PostPosted: Fri Jan 18, 2008 3:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, I'm having trouble getting it to record. It makes a screeching sound in the wav file for some reason. Not sure what the problem is, sigh. Also I'm not too pleased with the revving sequence, it should have multiple revs of different final amplitudes, and should not decay after the peak of each rev sequence. I'll fix that later after I get your thoughts on it.
Frostburn
Audio files: 9
PostPosted: Sat Jan 19, 2008 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
For the beauty of math I'll look into quarternions. I always though they were beautiful. Time to see if they also produce beautiful sounds.
I just hope I don't fry my CPU with too many complex differential equations all dancing the Runge-Kutta.
Inventor
Audio files: 270
PostPosted: Sat Jan 19, 2008 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whoa, what a wicked Wiki page, those quarternions are hard to understand! Maybe they'll make nice music though.
Kassen
PostPosted: Sat Jan 19, 2008 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like the idea of making a song together but I have to think about what I'd contribute.... I was thinking about doing something with sonifying a sorting algorithm to morph noise to a saw but that will be heavy on the CPU so that's not such a social thing to do if we'll all share one song so one CPU.
I'd like to do something with DSP and sound though as I've been doing so much in ChucK with sequencing and samples that it would be nice to do something very different for a change.
Is there anyone who'd like to link math to music on a compositional level and keep the central overview over our song/project?
Kassen
Inventor
Audio files: 270
PostPosted: Sat Jan 19, 2008 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, i am not really the type to organize the efforts of a group, but perhaps I could do some of the job for us. I presume that in our song we will have some "mix" of the three (or more) tracks. Perhaps I could write the framework for doing that, i.e. the sequencer. But I don't really have any experience in sporking, functions, or well, in doing that at all. So IF i can do that I'll need some thoughts from you guys on HOW to do that. All I can say is I might give it a try.
Perhaps as well I could do some creative composition in terms of actually deciding what way to combine our sounds together. Should it tell a story? Will there be lyrics? Perhaps it could be an adventure, where some main character discovers math by listening to it somehow. Something like "Oblio and Arrow", I'm thinking. Or that could be another random thought that doesn't matter. I do have Audacity so I can record voice. Can't sing, so it would have to be a story narrative, but they say my voice is relaxing, or "hypnotizing" to hear.
Inventor
Audio files: 270
PostPosted: Sat Jan 19, 2008 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
How about a video for our project? I was thinking about maybe plotting the functions that we are listening to as we listen to them. I'm a very visual person, and math is often conveyed to us in visual form as function plots and such, so if we are portraying the beauty of math, then wouldn't it make sense to do so visually as well?
Now, that something I could contribute, because i have POV-Ray skills and all that. Hmm on a compositional level we now have motor sounds, quartnion-thingie sounds, and whatever I misunderstood Kassen describing. Perhaps we also want something simple like a sinusoid. Enter perhaps the Chakra tones, so pleasing to hear, that are just sinusoids at specific frequencies for throat, heart, etc. I think they go about 350 Hz or so.
One possible theme is "Oblio goes to college" in which we have our familiar character Oblio from the land of Point go to college and as he enters various classes or professor's offices in the math department, he hears the song of that encounter and we see its video. Just thinking out loud. Thoughts?
Frostburn
Audio files: 9
PostPosted: Sun Jan 20, 2008 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not a great organisator either and a joint production like this needs at least a common sequencing syntax. I'd like to go a bit experimental with everything so it propably won't be possible but let's work on our ideas, post them here and see if it's possible to work with them togerther.
On the CPU side of things quarternion differentials are way too heavy for realtime performance. If I stick with them, we can forget light-weight songs. But on the sine-wave side of things they're on the meat.
For example if we look at the equation dz/dt = i*z we get z = exp(i*t) which is known to be cos(t)+i*sin(t).
Another thing that I've looked in to lately is self modulating sine waves and different networks of them. I've managed to produce all kinds of sounds from horns to woodwinds and soft ethtearal pads. The only problem is that they're usually very much out of tune because the self modulation process changes the oscillation frequency in an unpredictable manner for complex networks. The good thing though is that they're very light computationally and can be done in plain chuck code.
I was also thinking of composing in ratios instead of absolute notes. So that there would be a main frequency and all the other voices would be small ratios of it in the form of p/q where p and q are integers. Also the changes of the main freq would be ratios. This would propably disturb people who are used to absolute pitch and sound generally wierd. I'll see if it's anything good.
On a final note I'd like to ask how you view mathematics.
For me she is an abstract world of her own and her beaty is reflected on the simple and yet deep identities and symmetries like the famous Euler's identity exp(i*pi)+1 == 0
kijjaz
PostPosted: Sun Jan 20, 2008 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm i'll let the algorithmic composition ideas to all you guys.
i'll design some mathematical sounding instruments for you to test.
yes i love self-modulating oscillators very much -_-"
I'll work out some new ones from the idea.
Frostburn
Audio files: 9
PostPosted: Sun Jan 20, 2008 4:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a quick demonstration of the simplest self modulating SinOsc playing a ratio based melody to get some feel of that too.
sm_sin_demo.ck
A cute little melody going in 3/4.
 Filename:  sm_sin_demo.ck
 Filesize:  7.42 KB
 Downloaded:  371 Time(s)
kijjaz
PostPosted: Sun Jan 20, 2008 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh yes.. that's one with a very nice sound.. (kinda like a wood trumpet I imagine hahah)
today I come back to play more with Self-FMing sine oscillator
I imagined that using negative feedback and delay
might help shaping the sound especially to keep it in tune while chaotically vibrating at the same time.
so here's the test sound.
it sounds quite acoustic
(or can be like distortion-guitar feedback)
Code:
// by kijjaz (kijjasak triyanond - kijjaz@yahoo.com)
// feel free to use, modify, and redistribute with credits of all contributors
// change these values to hear out some behaviors
440.0 => float MainFreq;
4.0 => float DelayMultiples;
-0.9 => float DelayFeedback;
120.0 => float RandomRange;
// note: after playing around sometimes, i notice that using negative DelayFeedback
// helps make the pitch more in-tune
// main SinOsc (s1)
// the output passes through a delay (d1) with feedback (d1_fb)
// the delay is then fed through a gain (d1_g)
// which will be used to FM s1
// lastly, s1 is added with reverb and then output to soundcard
SinOsc s1 => DelayA d1 => Gain d1_fb => d1 => Gain d1_g => s1 => NRev reverb => dac;
s1.sync(2);
d1.max(second);
d1.delay(second / MainFreq * DelayMultiples);
d1_fb.gain(DelayFeedback); // use negative feedback
d1_fb.op(3); // prepare for modulation for future extension
d1_g.op(3); // prepare for modulation for future extension
reverb.mix(.02);
reverb.gain(.5);
s1.freq(MainFreq);
// test drive
while(true)
    Std.rand2f(0, RandomRange) => d1_g.gain;
    800::ms => now;
Embarassed thanks.. i hope this kind of sound, maybe still quite simple,
can be of any use to the collaboration.
update:
this one has note attack envelope
it can shape more kinds of percussive sounds.
Code:
9.0/8.0 => float DelayMultiples;
-0.99 => float DelayFeedback;
440.0 => float RandomRange;
4000.0 => float NoteDecayTime;
// main SinOsc (s1)
s1.sync(2);
d1.max(second);
reverb.mix(.02);
reverb.gain(.5);
// note envelope: this value modulate feedback amplitude that's fed into s1
Impulse i2 => Gain g2 => Gain g2_fb => g2 => d1_g;
g2_fb.gain(1.0 - 1.0 / NoteDecayTime);
s1.freq(MainFreq);
// test drive
while(true)
    i2.next(1.0);
    250::ms => now;
Frostburn
Audio files: 9
PostPosted: Sun Jan 20, 2008 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
After playing around with rational frequencies I quickly found out that frequencies that are related by a ratio with a prime number bigger than five in the numerator or in the denominator sound discordant.
What we are left with is the limit 5 tuning. There all the frequencies are related by hamming number ratios.
I then thought that if hamming numbers sound good we need lot's of them! => Additive synthesis with hamming number harmonics. 8)
hamming_number_harmonics.ck
Plays an additive synth patch of hamming number harmonics at 220.0 Hz
 Filename:  hamming_number_harmonics.ck
 Filesize:  2.86 KB
 Downloaded:  332 Time(s)
Former site admin
Audio files: 353
PostPosted: Sun Jan 20, 2008 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for that link, the relation with Hamming numbers was new to me Very Happy
Kassen
PostPosted: Sun Jan 20, 2008 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
trivia;
Strictly speaking the Didgerido is a "wood trumpet". Really.
Kassen
