So installed Chuck last night...
Page 1 of 1 [11 Posts]
Low Note
PostPosted: Sun Aug 12, 2007 7:24 am    Post subject: So installed Chuck last night...
Subject description: getting started
a few questions:
I found miniaudicle to be a more immediately convenient. Is there any reason I would be better off using the command prompt other than stability? From my perspective, if my long term plans are to use miniaudicle, I'd be better off getting comfortable in it. Would I be able to ignore the developer aspects of Audicle? (a software developer I am definitely not!)
I went through the starters tutorial with a lot of ease. It seems very intuitive. But now I seem to be at a loss. Should I read the manual? I opened up two the examples, and they didn't seem the most informative of things.
Finally, I know the languages are new, but for those of you who have been writing using chuck - when you compose for live use, how have you been storing your material for later use? A simple list of actions? Do you save your files and then just call them up? It seems easy enough to program on the fly, but I would want some sort of "sheet music" to keep track of what to do next.
PostPosted: Mon Aug 13, 2007 4:20 am    Post subject: Re: So installed Chuck last night...
Low Note wrote:
a few questions:
I think you should be fine with the Mini. The Mini is quite stable and usable these days.
I reccomend looking at the "otf" examples, running those then "remixing" them. After that a good choice might be starting a simple project; somthing small yet practical that you can use for your music like a joypad to MIDI converter. Those will give you speciffic questions. I recomend looking up the answers to those in the eaxmples and the manual.
I've tried two aproaches, I like both and will do both some more in the future. First of all I wrote my own sequencer in ChucK, I use that one to play live music and when I do I don't see any of the code and don't write any (but all of the actual music is completely improvised). I like that because in ChucK I could make my sequencer exactly like I want it. I've also written small pieces on stage directly in ChucK. This is also fun because you have such complete freedom. In the first case everything was prepared, in the second there were no files though I had a set of techniques that I had practiced and could combine or improvise around. Mixtures are definately possible too and could also be a lot of fun. This choice will depend completley on your own temprament and what you enjoy; experiment!
Welcome on board!
kijjaz
PostPosted: Mon Aug 13, 2007 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Kassen, yes, that is a very useful idea for practicing & preparing for live use.
Playing around with both sides is very beneficial, and I'm trying to learn by this method also.
At first I was not totally understanding each examples,
but with some basic understanding I started with the tutorial,
and with modifying the examples,
I can think up many more ideas on what I'd like to try with what I've known
(or what I guess it can be done)
Enjoy experimenting also!
Low Note
PostPosted: Mon Aug 13, 2007 8:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I went through the OTF examples, and got into the MIDI examples. I think I've experienced overload.
I understand all the steps to getting MIDI to work, though I wish the examples didn't use those prebuilt instruments and instead used a simple Sine oscillator with a gain dependant on velocity, or something like that. If I have time tomorrow, I'm going to mess around with that, see if I can make it work on my own.
As far as the OTFs go, everything seems to make perfect sense to me as long as I don't try to explain ever line of code. The biggest hang up being right now the way it all syncs together. I understand that this:
Code:
// this synchronizes to period
.5::second => dur T;
T - (now % T) => now;
will cause all of my shreds to sync up if it is present in all of them, but I can't really explain the whole modulo operator. Could anyone rewrite that a little more algabraically?
If I understand the concept correctly, one is trying to say, allow a shred to jump onto a moving train (the virtual machine). This bit of code allows it to line up with the train's door so it can get on.
From a completely practical perspective, I know that as long as I put that in each of my shreds, I can keep things time synced, but I'd really like to understand the nuts and bolts of what's going on.
I really appreciate the elegance of how chuck can imitate natural performances with the randomization. Seems almost too easy.
PostPosted: Tue Aug 14, 2007 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
That's not cool, let's see what we can do about that. Let's start at teh beginning and deal with the OTF question.
Code:
modulo works like this; you have two numbers, let's call them x and n. For the moment let's asume both x and n are positive.
what x % n (pronounced "x modulo n") means is basically that we substract n from x untill x is smaller then n. You can also say we devide x by n and then take the remainder.
So;
5 % 3 = 2
5 % 4 = 1
5 % 5 = 0
and
13 mod 4 = 1
(make sure you understand this, the rest depends on it)
So, if T is a period of time that translates to one "beat" and "now" is the current time then we now know that "now % T" means "the amount of time that has past since the last beat (or click of the metronome). in that case "T - (now %T)" refers to the amount of time that will have to pass untill the next beat, because all beats have the same length and they don't stop.
Because "second => now;" means "wait for a second" we can see that
"T - (now %T) => now;"
Actually translates to "wait untill then next beat". This is actually exactly what you'd do when playing in a band.
Make sure you also understand how the OTF examples mean Ge likes composing music at 120 BPM.
Recomended exersise; change then numbers in those examples and see what happens. Determine what each number refers to, try to change the numbers to remix the piece.
Low Note
PostPosted: Tue Aug 14, 2007 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
makes perfect sense now. thanks!
To double check:
When the manual says "advances time" for a line of code like:
Code:
1::second => now;
What it means is that the machine will wait until that time has elapsed until it moves on in the code?
(Going back into miniaudicle...)
When using the SndBuf uGen, chuck will automatically read it? That is why in the time loops, all you have to do is reset the sample to 0 (or at any point in the sample) for it to play again?
PostPosted: Tue Aug 14, 2007 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Code:
1::second => now;
It means that that section of code will wait for a second. Other pieces of code that might be running at the same time might do a lot of stuff in the meantime and the Ugens will keep calculating their sound as well. Advancing time just makes execution of that speciffic shred (thread) of code pause for a second before it goes on. so that's a "Yes", I think :¬).
Yes! exactly! SndBuf will calculate sound on it's own and only needs atention to be given new instrutions. The following will generate a tone (at the default frequency) that lasts for a hour, without needing any attention;
SinOsc s => dac;
hour => now;
That's a bit exagerated but it does demonstrate how it works nicely.
kijjaz
PostPosted: Tue Aug 14, 2007 8:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have one idea for understanding the "advance time" issue.
at first I didn't have experience in this type of programming also
(was playing around puredata and csound hahah)
After I get to understand what I can do with ChucK,
I imagine like this:
ChucKing UGens: means connect signal wires.
ChucKing other values: tweak some knobs:
Advancing Time: wait and hear
So actually, we can just hear the result of the system only when we wait and hear out.
Without advancing any time, everything'd end suddenly.
I like this time advancing idea, it's so easy to implement, and I like it when I can dynamically control how often I want to update some control in the program.
^_^
fight fight.
Low Note
PostPosted: Tue Aug 14, 2007 11:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
speaking of csound, is there way to work with increments of time in a tempo fashion?
I mean - its easy enough to just compute everything relative to seconds, but it would nice to be able skip that step in certain situations, I'd imagine.
I could define variables for beats and measures and use those variables rather than increments of time, I suppose. Its probably too late for me to be thinking about things like this.
PostPosted: Wed Aug 15, 2007 12:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Not too late at all. Defining beats and measures is a good idea, you can also have ChucK calculate how long a beat is for a given amount of BPM and update that if the BPM would change. "dur" for duration is a variable, just like "int" and can be modulated in the exact same way.
kijjaz
PostPosted: Wed Aug 15, 2007 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes! Not too late hehe. I was a classical-jazz instrumentalist, so I was thinking like you,
but thanks to ChucK and basic Physics, implementing that is easy & easy to understand:
(although very dynamic scoring on ChucK might require a more complex system)
If you wanna work with beat, tempo (beat per minute), measures..
you can calculate just like Kassen's suggestion:
Code:
120.0 => float BPM;
minute / BPM => dur beat; // comment: minute / BPM = beat duration
<<< "1 beat lasts", beat/second, "seconds" >>>;
4.0 => float BeatPerBar;
BeatPerBar::beat => dur bar;
<<< "1 bar lasts", bar/second, "seconds" >>>;
for example, I can program rhythms into array of floats:
Code:
120.0 => float BPM;
// connect SinOsc to dac
SinOsc s => dac;
// prepare melody (in semitone)
[12, 0, 3, 4, 0, 6, 7, 8, 7, 4, 3] @=> int melody1[];
// prepare rhythm (as duration in beats)
[1.0, 1, .5, .5, 1, .5, .5, .5, 1, .5, 1] @=> float rhythm1[];
48 => int BaseNote; // melody = 0 means C below middle C
do
    for(int i; i < melody1.cap(); i++)
        Std.mtof(melody1[i] + BaseNote) => s.freq;
        rhythm1[i]::beat => now;
    bar => now;
} while(true);
I guess this is can let us put in musical durations rather easily.
I mainly use this method for simple melody / groove patterns in ChucK.
