June Solstice Concert
Page 2 of 3 [54 Posts]
Le DJ Abstrait
PostPosted: Tue Jun 09, 2026 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you all!
this is all very exciting!
DJ Abstrait, musique concrète
Le DJ Abstrait
PostPosted: Wed Jun 10, 2026 5:51 am    Post subject:
Subject description: confusion
hey, it's me again...
A little confused here: I'm wondering which port to use for the concert...
On Concert Schedule, I'm listed with port 8134.
On server info https://electro-music.com/wiki/pmwiki.php?n=Radio.RadioInfoSrv2 , I'm listed with port 8090 assigned, and the mention "failed to open"...
WTF?
thanks!
schugosonic, my broadcast test was mostly a Wren patch from Blue Hell...
phobos
Audio files: 728
PostPosted: Wed Jun 10, 2026 7:12 am    Post subject:
I had you scheduled for 8134, but mosc assigned you to 8090 which you tested with.
I just had a look and apparently that port was switched off, it should work now and I've changed it on the schedule.
The Golden Shrimp Guild
Audio files: 266
PostPosted: Mon Jun 15, 2026 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Phobos, two more people are coming over to chez mosc for the Solstice concert. Jill Christensen and Doug Llewellyn who with me are known as Waste, Fraud, and Abuse.
If you have to edit the beautiful poster again, please substitute Twyndyllyngs with Chez Mosc. That will cover who ever happens to show up here. No biggie if you don't get around to that though.
We'll be having a party over here...
Audio files: 163
PostPosted: Thu Jun 18, 2026 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi folks, I've managed to log in via a friend's computer , my home pc connection to EM has been banned for nearly 5 weeks with a brief 2 days s I got in to sign up, I can't give my IP address just now as I need to check it at home , is there any way of unbanning ip near Edinburgh region UK, also there is no way to let anyone know on the frozen banned page that it has happened.
Thanks
Epicyclus Dave
Audio files: 282
PostPosted: Thu Jun 18, 2026 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've just recorded my set, wanted to do it as close to the Solstice as possible, where should I upload it?
Former site admin
Audio files: 353
PostPosted: Thu Jun 18, 2026 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok .. got back home a couple of hours ago ... where i had ripped up my audio and instrument and computer setup - rebuilding it now .. I do have stream again .. with a limiter / compressor even .. but did not check levels yet .. and the software routing is not handy now for that .. but there is time :)
phobos
Audio files: 728
PostPosted: Fri Jun 19, 2026 1:41 am    Post subject: Reply with quote  Mark this post and the followings unread
That's great, thanks! Very Happy
Since you usually upload your sets to the event threads anyway you might as well just add it to this one.
phobos
Audio files: 728
PostPosted: Fri Jun 19, 2026 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks
Epicyclus Dave
I am not the IP guy so I hope Howard can look into that, I send him a pm.
No idea if a whole region can be (un-)banned.
Audio files: 282
PostPosted: Fri Jun 19, 2026 3:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I was considering that, will add it here in a bit Very Happy
Audio files: 282
PostPosted: Fri Jun 19, 2026 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's my set for the June Solstice, recorded on the evening of the 18th June, using: op-1, minifreak, microfreak, chirper, hydrasynth and elz_1
If someone could play it for me at the alloted time I would be most grateful Cool
modulator_esp_e-m_june_solstice_180626.mp3
 Filesize:  54.93 MB
 Viewed:  882 Time(s)
setup 1
 Filesize:  304.86 KB
 Viewed:  101 Time(s)
setup 2
 Filesize:  265.31 KB
 Viewed:  104 Time(s)
Banjo
PostPosted: Fri Jun 19, 2026 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Late as usual. Put me in wherever you want please.
1. Preferred Start Time (Please use GMT/Military Time): Any
2. Set Length (30 or 60 minutes): 30-60 whichever fits or can be tolerated
3. Artist Name (For displaying on the poster):Things in Dave's Carpet
4. Chat Name (if different from artist/forum name):Banjo
6. Description (Style/Genre/Equipment, etc. - Optional)Confused??
8. Anything else you like to mention:Eurorack, Moog Matriarch, DIY modular and maybe some soft synths.
phobos
Audio files: 728
PostPosted: Fri Jun 19, 2026 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can move Modulator ESP to the start and schedule you at 20:00 GMT for an hour instead if that suits you.
phobos
Audio files: 728
PostPosted: Fri Jun 19, 2026 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice spaceship Jez
wave
Banjo
PostPosted: Fri Jun 19, 2026 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whatever works best for everyone. I am equally unprepared for 30 minutes as well as 60!
Thanks Pho!
deleted_user
Guest
PostPosted: Fri Jun 19, 2026 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Let's wait for the final schedule.
If you're moved to the beginning, I could stream it.
But at 20.00 GMT I want to watch the football game...
phobos
Audio files: 728
PostPosted: Fri Jun 19, 2026 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
good to know,. I could play it at any time but it would be more convenient if someone else does.
Audio files: 282
PostPosted: Fri Jun 19, 2026 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice spaceship Jez
wave
Indeed, I enjoy taking it for a spin Very Happy
Audio files: 282
PostPosted: Fri Jun 19, 2026 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also, I don't mind when my set gets played, but hopefully I'll find out in time if it moves so I can update my posts on social media with the correct time
phobos
Audio files: 728
PostPosted: Sat Jun 20, 2026 12:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't expect to make any more changes to the schedule, actually I closed the signup now.
deleted_user
Guest
PostPosted: Sat Jun 20, 2026 12:51 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, then I would start the concert with the modulator_esp stream if that's OK with you all?
(EDIT: Nice track, BTW. Good start into the longest evening of the year \o/)
Former site admin
Audio files: 353
PostPosted: Sat Jun 20, 2026 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
That was a nice set Jez Exclamation
/me applauds Cool
Former site admin
Audio files: 353
PostPosted: Sat Jun 20, 2026 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is my set - mostly taiga integrated with 0-ctrl .. not live .. some wave claying was involved .. and pre-recorded at my mother's place.
Posted Image
And there was a laptop to the left as well and an audio interface.
Posted Image
And ore zone is just an anagram of zero one .. where i had first recorded a zero part of a bit over 30 minutes and then the one part .. zero was for 0-ctrl, one came after .. and zero one seemed boring so I had some web site spit out anagrams of 'zero one' and then never realised that ore is something you'll find in the ground .. in some zone of the earth .. but .. the sleeve was done already :)
hmm .. zore eno, zone ero, oer noez .. it will all do
2026-06-20--Blue Hell--ore zone.mp3
blue hell - 2026 june solstice, ore zone
 Filesize:  57.5 MB
 Viewed:  867 Time(s)
Audio files: 282
PostPosted: Sat Jun 20, 2026 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks
Audio files: 282
/me applauds Cool
Thanks
