 Forum index » Online Music
jaunty jaunt
Page 1 of 1 [3 Posts]
A E J O T Z
Audio files: 148
PostPosted: Thu Jun 09, 2016 12:02 pm    Post subject: jaunty jaunt
Subject description: It's made of two notes. Everything else is harmonics, modulation and flanger.
This one is different.
An error in playing suggested the sequence to me. I keyed the two-note (A and A#) sequence into the microbrute and started playing with settings. When I had a pretty nice sound I enabled the flanger on my BR-600 recorder. Suddenly, I was joined by Pete Townshend and the ghost of Nicky Hopkins.
OK, slight exaggeration. But seemingly out of nowhere I'm hearing chords and arpeggios that I'm not playing! All the harmonics are audible and the flanger is filtering them in and out, and even left and right - quite a neat trick for a monophonic synth!
I recorded a couple of versions where I also manually adjusted cut-off but I like this "unassisted" version best. Once everything was set up, all I did was hold down a key for ten @#$% minutes.
If you want it to sound like redundant shite, put it on the speakers and go in the other room. If you want hear it like I did, listen through some good headphones.
jaunty jaunt.mp3
Two notes on a Microbrute, sequenced and modulated then recorded on a Boss BR-600 using its built-in stereo flanger.
 Filesize:  10.26 MB
 Viewed:  3313 Time(s)
AEJOTZ is pronounced "A-Jotz"
retro-futurism now
electronics = magic
free albums at http://aejotz.bandcamp.com
listen to genre-defying synthetic music at http://sat-5.com
Audio files: 353
PostPosted: Thu Jun 16, 2016 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I listened a bit in between on crappy headphones .. works nice :-)
A E J O T Z
Audio files: 148
PostPosted: Thu Jun 16, 2016 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
retro-futurism now
electronics = magic
